  • July 19, 2025, 05:23:52 PM
Author Topic: Scott Bair  (Read 1024 times)
Offline Bootlegger
Scott Bair
« on: July 22, 2018, 06:46:40 AM »
  If memory serves this fellow built a stick and tissue stunt model called Stunt Fire.  I would like some info an how to build this fuselage, or one using his technech .
  Any help will be appreciated..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Scott Bair
« Reply #1 on: July 22, 2018, 01:45:07 PM »
Buy the  plan  You can get it at the  AMA  plan site,  and  it was  much more than a stick model, front is very well designed with molded solid skin, the rear of the fuse  had bulkheads and stringer construction with paper covering, wing was ribs  with LE and  TE sheeting, but has  Spruce spars,  Stab elev  are built up with paper covering
Scott had  FSR 56s , ST 60s, Homemade 64s   65s   74s and  88s  in them , and   13 to 16 inch diameter props
Re: Scott Bair
« Reply #2 on: July 22, 2018, 04:44:28 PM »
 Apropos of the other thread, Scott probably came the closest of anyone to achieving minimum corner radius with an otherwise competitive airplane.
Offline Bruce Shipp
Re: Scott Bair
« Reply #3 on: July 22, 2018, 05:52:05 PM »
Offline Bootlegger
Re: Scott Bair
« Reply #4 on: July 22, 2018, 06:03:58 PM »
   Guy's I sure do appreciate all the help..
Gil Causey
AMA# 6964
