yes, but you are better off with the phenolic ones are they are thinner...
to mount them with the post, make up bearing blocks out of a hardwood (pine works too) and make them into a elongated diamond. cut holes to match the diamond shapes in your cores.....glue the bellcrank post to the blocks. When you assemble the wing, glue the blocks into the holes you made....make sure they are flush with the top of the foam.
When you sheet over the middle section, the blocks will glue to the sheeting also.....I have pics....,that would be easier
