  • July 07, 2025, 01:32:41 PM
Author Topic: Samuel's New Birds  (Read 1551 times)
Offline mike londke
Samuel's New Birds
« on: September 01, 2016, 08:06:12 PM »
Sam has beat up just about all his planes to the point they reall don't fly well anymore. In addition he's running the same Foxes I had when I was a teenager. They are pretty clapped out so its time to get this boy some better gear.  I built 2 of Phil Cartier's Rugged Stunt Trainers in two days. They are ready for final color dope and engines. They will both get new engines. One an FP .25 the other a K&B Sportster .28. My friend's flies really well on the .28 and I expect the .25 to be more than adequate.
Re: Samuel's New Birds
« Reply #1 on: September 01, 2016, 08:17:31 PM »
   Hi Mike;
    Great to see you and Sam at Paducah. Sam looked like he really liked that Skyray .35 that he was pushing around like a wheel barrow! My son Sean used to do the same thing. When Sam gets to a point where he wants to glue a few pieces together to build an airplane. check out that thread on the Lew Woolard Spider here on the list somewhere. It's an old slow combat model that had a neat airfoil, and is designed to be built from 4 sheets of standard size balsa! The plans show how to lay out the parts on the sheet. Very nicely engineered, and with a few touch ups and personal preferences, a pretty nice looking airplane also. I ran off some plans and thinking about whipping one up just for a fun fly airplane. As designed, a .25 should allow room for a tank to do the pattern and if not,just stretch the nose a bit then the tail to match. I was just really impressed with the whole design concept, and being a combat flyer yourself, I think you'll see what I mean! Phil Cartier's stuff is pretty nice and may get one of those for the shelf myself also.
Offline mike londke
« Reply #2 on: September 01, 2016, 08:55:14 PM »
 Thanks Dan I'll check out the Spider. Phil's RST is a steal at $59.
« Reply #3 on: September 02, 2016, 09:36:46 AM »
Phil's planes should be a good match for the young man.  Also the wings are replaceable.  I have been flying the big Streak of his,
Offline Fredvon4
  • Central Texas
« Reply #4 on: September 02, 2016, 10:57:45 AM »
I know Mike knows this but if you build the RST with typical Combat wing conventions it is nearly indestructible
Phil's recommendations are good...SLC pieces...but tedious to do   (for me)... So I used .75 FG cloth (nose and forward area of wing tips, and the heavier CF veil...aft center TE area out 4 " either side of Fuse ,and Kevlar cording from wing tip to Fuse along TE
As soon as Phil responds to my current order I plan to get another RST... danged good flying plane for not much $$....and as Mike posted , easy and fast to build if you don't get anal about the finish
Fred von Gortler IV
Online kenneth cook
« Reply #5 on: September 03, 2016, 02:58:20 AM »
            Mike, if your in need of another K&B .28 I have one. I believe it's in very good condition. The engine has the r/c carb on it currently. If you need it, it's yours. Ken
Offline mike londke
« Reply #6 on: September 03, 2016, 07:28:34 AM »
PM Sent
« Reply #7 on: September 04, 2016, 09:17:35 PM »
Fly on and fly tough Sam))))))) Doing great.
