  • July 17, 2025, 01:36:59 AM
Author Topic: Salem Fall Follies this weekend  (Read 8805 times)
Re: Salem Fall Follies this weekend
« Reply #50 on: October 05, 2015, 12:50:07 PM »
Hey Will, your timer survived.
Online Mike Haverly
« Reply #51 on: October 05, 2015, 03:23:42 PM »
The timer survived, but what about the divot?  Really unfortunate.  A few of us were watching the last flight and commenting on the unhappiness of the airplane.  Turbulence above 45 deg. was particularly nasty at times.  The top of the hourglass got to Randy.
« Reply #52 on: October 05, 2015, 03:35:49 PM »
I wish I'd taken a picture of the divot (there was a spinner-shaped, half inch deep divot in the pavement in the middle of the debris field).  I've never seen that before.
Here's the battery -- I was kind of surprised that it didn't burst into flame.  Life can be boring that way, sometimes.
Offline Dave Royer
« Reply #53 on: October 05, 2015, 03:44:49 PM »
Dave Royer, I see you won old time, did you happen to fly with a certain Merco again? y1
Yes indeed! Still singin' my favorite song.  y1
Offline Fred Underwood
« Reply #54 on: October 05, 2015, 03:46:08 PM »
Survived to visual inspection, or functions electronically?  Sorry about the plane, seemed to be flying well.
Fred
352575
« Reply #55 on: October 05, 2015, 06:13:05 PM »
 Whoah, doesn't look like much else did though Randy, what happened?
« Reply #56 on: October 05, 2015, 06:22:07 PM »
Downdraft or turbulence.  I just heard the "thud", but my wife saw it go entirely slack on the lines in the top of the hourglass, and one of the spectators saw the wind streamer going straight down right after the crash.  (She's learning the pattern: "lessee, that's triangle, round eights, square eights, hourgla -- smack!! -- hmm, I don't think that's scanning right").
« Reply #57 on: October 05, 2015, 07:45:41 PM »
Well, upon further examination, the timer did not survive. Weirdly, the Cobra motor did. Guess the spinner saved it. The prop fractured but was still in one piece. Everything else is dead. And the plane is now salvaged (motor, control system and leadout slider).
Offline Paul Walker
« Reply #58 on: October 05, 2015, 07:51:30 PM »
Sorry to hear about the loss. It was a very promising plane.
« Reply #59 on: October 05, 2015, 07:56:50 PM »
Paul, there will be more to come.   ;D
John Leidle
« Reply #60 on: October 06, 2015, 12:59:20 AM »
  Randy's plane didn't look to be powering through the wind & such in either flight ,, I  think I woulda turned up the rheostat a bit or dewound the rotor a few windings ..  & if you go up in the hour glass underpowered in wind & garbage they end up like a" loose leaf. "
   You guys believe what pleases you, low power = loose lines in the wind & bumps. Overpower & it burrows through the wind & crap. I've proved this several times & I don't even have an Engineering degree.
  At the 2007 Nats in Classic it was crappy & windy lots of guys simply couldn't do the pattern I had a killer Magnum.53 in my Nakke & it went though it with room to spare.  This is a concept Paul Walker told me at a Funfly in 2001 ...
           John L.
Offline Doug Knoyle
« Reply #61 on: October 06, 2015, 02:45:28 PM »
John, you are right , but I think Randy would have needed more than a modestly over-powered ship. I was eyeballs-on-the-plane from approximately 100 feet from the edge of the circle. During Randy's corner #2 of the Hourglass the plane was SUDDENLY "hit" - and while it bobbled slightly, from my vantage point the INSTANT loss of altitude (sliding wingtip first) was obvious. During the 40 point divot-making "Pile-Drive" maneuver I was thinking "how big will this debris field be?"; THEN, over the next full 2 seconds after the smash my eyes were drawn to Howard's streamer, which just happened to be directly in line between me and the crash. That streamer SLOWLY rose from straight down against the pole to its normal horizontal nature. (Note: Streamer pole position: edge of circle; Crash spot was closer to streamer pole than farther).
Cheers,
Doug
« Last Edit: October 06, 2015, 03:34:40 PM by Doug Knoyle »
AMA 60591
« Reply #62 on: October 06, 2015, 07:12:10 PM »
The prop was probably a bad choice (in retrospect), but not much you can do when the plane simply drops 10 feet. I hit the second turn of the hourglass and the plane dropped about 10 feet. After that I was a spectator. The plane was overweight, but not that much.
John Leidle
« Reply #63 on: October 06, 2015, 09:37:05 PM »
  The sad part is we never found out just how good the package would of been.
« Reply #64 on: October 06, 2015, 11:56:05 PM »
well,, I know what your saying John,,
Randy had the same power system as I do in  my Impact/Prey,,except he had a different prop,,
my Prey is another 50 inches of wing and 10 ounces heavier,, mine drove the wind pretty solid,, both in Salem and in Muncie where it was even nastier,,
well it did as long as the battery was still connected LOL
« Reply #65 on: October 07, 2015, 10:35:51 AM »
Curious about the props, what was being used on each?
« Last Edit: October 07, 2015, 11:20:31 AM by Fred Underwood »
Fred
352575
Offline Pat Chewning
« Reply #66 on: October 07, 2015, 11:18:06 AM »
I was sitting right near that when it happened.  There were lots of small turbulent thermals marching across the the flying circles every 2 minutes or so.   The associated wind direction and magnitude shifts were fairly large.
« Reply #67 on: October 07, 2015, 06:45:28 PM »
I use the APC 13x4.5 P ( or F2b I guess its called now)
« Reply #68 on: October 07, 2015, 06:50:25 PM »
There is a 13x4.5 F2B and 13x4.5 that is not F2B and they are different even if both Pusher.  I use that F2B cut to about 12 for clearance and to same a few amps, not drain the battery.  Do you know what Randy had?
Fred
352575
« Reply #69 on: October 07, 2015, 07:41:15 PM »
i\Randy had a standard rotation 3 blade carbon prop , I dont know the origin,,
the first 13x4.5 was labeled a P,, the newer one was the EP,, and then they reissued the P as the F2B,,, there is about 1200 rpm difference between the two types on y setup,, I currently turn about 11,300 with the P ( F2B) and was over 11, 450 with the EP
by the way,, you have progressed a lot since the last time you came from church to beat me LOL,,
« Reply #70 on: October 07, 2015, 10:15:05 PM »
Mark, I can't make sense of the numbers and 1200 rpm difference.  I turn the F2B about 10300 - 10400 on 66 ft lines and turned the non-F2b about 11,400+.  Was the 11,300 with the F2B supposed to be 10,300?
Thanks, you have progressed as well, as we should have.  That was the Fall Follies a year ago.
Fred
352575
« Reply #71 on: October 08, 2015, 07:36:57 PM »
yeah I got dumb fingers,, the F2B/P is 10300,, the other one ,, the EP is 11,400-500
sorry for the confusion
« Reply #72 on: October 08, 2015, 07:39:14 PM »
Thinking I may need to start going to church again LOL,,
I have actually just in the last month been able to dedicate some time to practice,, between Salem last year and the Nats I had exactly 12 flights,, then in the last month I have stacked in a bunch,, but I have made dramatic changes to my setup,, straight handle,, much more sensitive setup,, and its taking time to get my muscle memory to learn the new system,,
Next year,, muah hahaha,, Watch out LOL H^^
« Reply #73 on: October 08, 2015, 07:42:14 PM »
Add to that your trip(s) to the Stunt Ranch.  I am sure that you will be ready.
Fred
352575
« Reply #74 on: October 08, 2015, 07:46:18 PM »
Stopped at the Salem field today. Set my plane down almost on the Randy spinner hole.  We picked up the battery, still looked like the photo sitting there at the circle edge in gravel.
Fred
352575
« Reply #75 on: October 08, 2015, 08:13:28 PM »
Randy mentioned to me,, ( after I was already home) that he forgot to do something with the battery,, I thought Tim woudl take it to experiment with or something,,
THat was a pretty awesome divot huh,, perfect spinner hole,, and the spinner didnt even look deformed,,
I hope to get more time at the WSR, I learn tons every time I go up there,, Lots left to learn,,
