  • July 06, 2025, 12:51:45 AM
Author Topic: Saito FA 40CL  (Read 3136 times)
Offline Leester
Saito FA 40CL
« on: May 06, 2008, 03:08:37 AM »
I just checked Horizons site and under news they show a Saito FA 40CL Coming Mid May.
Leester
ama 830538
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Saito FA 40CL
« Reply #1 on: May 06, 2008, 05:49:22 AM »
Yep it was announced in another thread a couple weeks ago. Sure tickles me, the 40a will handle anything an LA 46 would normaly go on and until the rule changes allow 15 thousands lines. I have three converted RC versions, two with UHP manafolds and one with a new insert for the RC carb I made myself.
Great little engine..
Offline Scott Hartford
Re: Saito FA 40CL
« Reply #2 on: May 06, 2008, 06:22:55 AM »
I got one from Bob and put on an ARF Nobler to try out. VERY IMPRESSIVE!!! It's now my best-flying plane!
Offline Ralph Wenzel (d)
Re: Saito FA 40CL
« Reply #3 on: May 06, 2008, 08:29:52 AM »
How in the world did you balance the thing??? Tail-weight box? The Saito is at least 5 oz heavier than a Fox, and 4 oz. heavier than a B.40 or OS.40LA.
Ralph Wenzel
AMA 495785 League City, TX
Offline Bob Reeves
Re: Saito FA 40CL
« Reply #4 on: May 06, 2008, 08:50:58 AM »
Not sure if Scott did anything... An interesting phenomenon about 4 strokes that was discussed to death several years ago is the CG can be farther forward and the airplane will still turn. Not sure anyone came up with a scientific explanation but allot of theories were floating around. My Twistmaster with a Saito 40 balances on the wing leading edge and will still turn with the best of the Twisters ever built.
Re: Saito FA 40CL
« Reply #5 on: May 06, 2008, 09:24:39 AM »
Saito 40A rocks. I did a report on one in this forum some time ago. The weight difference is irrelevant. What does matter is that you stick one of these things in a well built Nobler and serious business is going to get takin care of.  I consider them a replacement for my ST 46's.
« Last Edit: May 06, 2008, 09:59:58 AM by proparc »
Offline Leester
Re: Saito FA 40CL
« Reply #6 on: May 06, 2008, 12:58:39 PM »
I sure missed the thread saying it was going to be available. What forum was it on ? Engines or the main one ?
Leester
ama 830538
Re: Saito FA 40CL
« Reply #7 on: May 06, 2008, 01:17:51 PM »
HI
They  are due in mid to late May. I have all of the other 4 cycles here in stock, and the 40 Saito's  will be in stock when the importer gets them in.
By the way if your counting that will make   5  NEW  Control line 4 Stroke engines in the past few months made for C\L  flyers
www.aeroproducts.net
Re: Saito FA 40CL
« Reply #8 on: May 06, 2008, 02:35:00 PM »
The picture on the front of the ARF Nobler box shows one equipped with a LA 40 with stock muffler. The Saito 40 weighs about the same. The run is unbelievable. You would just have to try it to see....... H^^
Re: Saito FA 40CL
« Reply #9 on: May 06, 2008, 08:42:03 PM »
I certainly wasn't quibbling about the quality of the FA40a or its running characteristics - I have 3 of 'em! But you may have just explained what was wrong with my #2 Cardinal. I shortened the nose of the ARC to accomodate the added weight (as compared to a B.40) and it was practically a Free-Flight plane. I added a 2 oz. Higley Hub, and the improvement was significant. Now I think I should try another, leaving the nose stock length, but add a tail-weight box "just in case". I must have missed the discussion about "nose-heavy but still turns"; thanks for the info.
Ralph Wenzel
