  • June 23, 2025, 11:37:07 PM
Author Topic: source round cowl  (Read 936 times)
Offline sleepy gomez
source round cowl
« on: September 20, 2012, 09:16:52 AM »
I need a source for a round engine cowl between 6.75 to 7.25
 in diameter, the lighter the better.  sleepygomez@gmail.com  863-899-0656
Offline Clancy Arnold
Re: source round cowl
« Reply #1 on: September 20, 2012, 09:39:56 AM »
Sleepy
Start measuring the round plastic jugs in the supermarket.  For example a 3 quart Clorox bottle is 6 1/4 inch dia.
Clancy
Clancy Arnold
U/Tronics Control
Offline Douglas Ames
« Reply #2 on: September 20, 2012, 10:05:13 AM »
Or try a thrift store/ junk shop that has an old aluminum pot. The newer ones are sorta thin and cheap.
AMA 656546
Online Tim Wescott
« Reply #3 on: September 20, 2012, 10:43:27 AM »
The pessimist says "thin and cheap".  The optimist says "thin and light".
Try these folks.  I haven't used them, but they have a good reputation: http://fiberglassspecialtiesinc.com/.  Ask about weight if it makes a difference to you -- they may be, um, "thick and solidly built".
Offline builditright
  • So happy to be alive!
« Reply #4 on: September 20, 2012, 11:55:30 AM »
try
park flyer plastics
http://www.parkflyerplastics.com
Thank you and God Bless
Walter
aka/ builditright
Offline jjorgensen
« Reply #5 on: September 20, 2012, 12:03:05 PM »
Roll your own out of 1/32 ply. I did one for a galloping comedian that came out lighter than the kit aluminum cowl. Took about 15 minutes to make it up once I had the inner ply and the 1/2 inch balsa front circles cut to wrap the ply around.
Jim Jorgensen
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #6 on: September 20, 2012, 04:30:08 PM »
I have several cowls from Fiberglass Specialties, they have lots of cowls, even some stock round cowls, very good quality.
http://www.fiberglassspecialtiesinc.com/
Fred Cronenwett
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #7 on: September 20, 2012, 09:47:20 PM »
 I just might have a real nice one for you, I'll have to take a look.
« Reply #8 on: September 21, 2012, 05:49:24 PM »
Thank you all.  As per a suggestion I have found a round cowl the right size at the grocery. It is a plastic bowl that is rigid enough and still light enough.  The TRILOGY is in the monocote stage now.  It is going to make its target weight of 64 ounces @ 890 sq areas.  When it is done and flying I'll post photo.  Thanks for your help.  SLEEPY
