  • July 19, 2025, 02:38:06 PM
Author Topic: S T venturi?  (Read 1009 times)
Offline Bootlegger
S T venturi?
« on: February 17, 2011, 05:04:41 AM »
   n~   Guy's what size venturi do I need in  S T 60 with it being a "true venturi", in other word's NOT going thru the venturi, but behind it?    :!
         Thanks a lot
  Oh, how do I set up a "sprinkler" venturi?  I'll need to know what parts and where to get them.. y1
   Thanks again,
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bill Hummel
Re: S T venturi?
« Reply #1 on: February 17, 2011, 06:09:32 AM »
Hi, Gil, I've used true venturis from Randy Smith, Eric Rule, Byron Barker, and I think others...I like about .180 on my ST 60's, then
fine tune with filters.  Funny, as long as I've been flying ST 60's, I still can't see a difference between the true venturis and the
standard restrictors.  I do like Randy's NVA's, they seem to eliminate the problem of small air leaks at the NVA.
ama 72090
Offline W.D. Roland
Re: S T venturi?
« Reply #2 on: February 17, 2011, 12:57:24 PM »
hi Gill
Hope things are settling down after the recent double.
I am close to machining ventures for a S.T. blue head .60 for use in the FW project.
Best I can tell this is same venture as for the S.T. V .60( small case) and will make a few for this engine also.
The plan is to make them annular(sprinkler?) discharge using the G21. 35 as pattern enlarged to fit the .60
The reason for wanting this is mainly for the FW where I screwed up the tank location and need the spray bar as
close to the crank C/L as possible.
This work is probably a month or so away so like I think I mentioned you are welcome to come use the machines
here to make what you need.( not hard to do)
And I do wish you would let me send you 10 or so sheets of this silk span to try.
If you do come bring something to fly. The field is ready( If the rain treats it good!)
David
David Roland
51336
Dave Adamisin
Re: S T venturi?
« Reply #3 on: February 17, 2011, 02:23:52 PM »
I liked 0.180 to 0.185.
Offline Bootlegger
Re: S T venturi?
« Reply #4 on: February 18, 2011, 04:47:33 AM »
 y1     Thanks Guy's, sure do 'ppreciate the help..      #^
Gil Causey
AMA# 6964
