  • July 06, 2025, 06:22:14 AM
Author Topic: S T 60 venturi "O" rings  (Read 870 times)
Offline Bootlegger
« on: June 18, 2011, 11:31:49 AM »
   Guy's where can I find some "O" rings for the S T 60 venturi's???    Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: S T 60 venturi "O" rings
« Reply #1 on: June 18, 2011, 11:37:29 AM »
They'll be metric, but even so, you should be able to find them at the local O-ring store.  D>K Steve
Offline Jim Thomerson
« Reply #2 on: June 18, 2011, 12:06:47 PM »
He means any hardware store.  They all have an o-ring department. D>K
« Reply #3 on: June 18, 2011, 09:21:46 PM »
Actually, Jim, I was referring to anyplace you can buy O-rings. In addition to hardware stores, plumbing stores, hose & fitting stores, industrial fastener stores and some fishing tackle stores all carry O-rings, and let's not forget Carr-Lane and McMaster-Carr. Tackle shops will only carry one or two sizes, at best. Most will be neoprene, tho, which is what you want. What the heck is "Buna-N"?  H^^ Steve
