If you put the second layer on dry , with thinned dope , its just possable to remove it when you notice all the wrinkles , if you slap more dope on
as solvent .
Er Um . ! We wont say how we know this , .
One HAS to put it on WET , & use thinner , going from the middle outward .
Helps to pin it in a place or two . Can slide around so dont pre cut to tight on the outline .
Conversely its awkward to pull it around , damp . to align BEFORE the thinner goes on .
After that your stuck .
Youll also have well doped hands from smoothing it down out through and across , maybe lifting it in places as you go to avoid misalignment / wrinkles .
This only leaves the problem of blushing / Milky Colour from the moisture . Likely the thinners better for evaporateing it , thinned dope'd trap it ?? .
