  • June 14, 2025, 12:18:05 PM
Author Topic: Arf Flight streak.  (Read 1018 times)
Offline Randy.Birt
Arf Flight streak.
« on: February 25, 2020, 07:38:30 AM »
Greetings all, quick question.  Putting an OS fp 25 on my Arf flight streak. Am I correct that a 9x4 is the appropriate prop. If not, what else would you recommend? Thanks y'all
Offline Randy.Birt
Re: Arf Flight streak.
« Reply #1 on: February 25, 2020, 08:25:02 AM »
Thanks Ty, we already found that out, the 16 year old son lawn darted it and I am having to do repairs. I never really like the fox 25 that was on it, so as i am having to take everything off the nose to fix it, I figured i would put on a better motor. I have two FP 25 and two fp 20. I figure one of them will work well for this plane.
« Reply #2 on: February 25, 2020, 08:35:05 AM »
   I would suggest a 20FP and an APC 9-4. Everything else on the engine should be *stock*, repeat, *stock* out of the box, exactly as it came, with all the parts including the muffler.
Offline Randy.Birt
« Reply #3 on: February 25, 2020, 09:58:01 AM »
Thanks Brett, I will do that. I appreciate the input.
V/R
Randy Birt
Online Perry Rose
« Reply #4 on: February 25, 2020, 02:17:34 PM »
I put a 1/2 inch thick cheek piece on the non engine side for strength.
« Last Edit: February 26, 2020, 01:38:02 PM by Perry Rose »
Offline Leester
« Reply #5 on: February 25, 2020, 02:29:32 PM »
where's the engine ?  on the inboard side ??
Leester
ama 830538
« Reply #6 on: February 26, 2020, 11:12:55 AM »
APC 9-4 is a good prop. The 9-4 master airscrew will be a little less pitch and less load if you want to slow it down a bit.
   The APC is *much less* load in the air than the Master Airscrew, that's why it works. The key to the entire system is to get it revved up enough to run smoothly.
Offline Randy.Birt
« Reply #7 on: February 26, 2020, 11:51:26 AM »
Brett, while we are on the topic, any recommendation for fuel tank set up for this engine? Muffler pressure or no?
« Reply #8 on: February 26, 2020, 12:30:05 PM »
  No topic has ever been covered better than how to set up a 20FP, to the point that everyone has long since gotten sick of it, but quickly:
   BOX-STOCK OS 20FP ABC with STOCK E2030 Muffler and NO, repeat NO modifications of any type. Break in per directions
   OS Glow Plug (as supplied)
   APC 9-4 prop
   VP/Powermaster 10% fuel (any 10% RC-type fuel will do, 15% will also work)
   Stock Sullivan SS-4 clunk tank set up per instructions for a 3-tube system (hard uniflow into "bump", overflow into inner/upper/right corner, clunk pickup), flat side of tank set up against fuselage and centered on engine, uniflow vent plugged and overflow open to get suction tank. Muffler pressure into overflow. You will need about 2.0 ounces of fuel on a broken-in engine, WAY more when it's still tight.
  Your tank should be no wider than 1.5" from the bottom of the engine lugs to the pickup, less is better.
   I will elaborate later when I get home.
Offline James Holford
« Reply #9 on: February 26, 2020, 07:01:56 PM »
A thunder tiger pro .25 with a 8x5 makes it a hoot to fly :):)
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Gary Dowler
« Reply #10 on: February 27, 2020, 03:20:41 AM »
Agreed!  Ive been following this very advice for some time now, and it works!  The FP's thrive on RPM. Don't try to 4 cycle them, or you will loose all of the advantages they bring.  Lean it out, then just open the needle until you hear a slight RPM drop (on my 20FP's this is around 12,300) and go. This set up replaced the Fox 35 on a couple of my planes and improved things noticeably.  Now if I could just get the idiot behind the handle to catch up with the airplane.......LOL
Gary
Offline Steve Dwyer
« Reply #11 on: February 27, 2020, 06:35:40 AM »
It took me a little coaxing from friends to try an OS LA 25 with a 9x4 prop on my latest build Flite Streak instead of one of the tried and true Fox 35's I have been using on several OTS models.
The 25 or 20 with a 9x4 is a great combination, for a perfectly consistent strong run. And yes we can fly without the coveted Fox 4-2-4 break.
Offline Randy.Birt
« Reply #12 on: February 27, 2020, 09:10:01 AM »
Brett, I found and printed out the 2006 Posting from Dan Rutherford. It is a several page discussion, and answers just about all my questions. Thanks for the heads up.
V/R
Randy Birt
