  • June 21, 2025, 08:20:08 PM
Author Topic: Fox 35 heads and their use  (Read 873 times)
Offline Allen Brickhaus
  • ACE
« on: May 31, 2012, 07:59:09 AM »
I have a Fox .35 head with the plug aimed across from side to side and is pointed toward the fuel intake. Is this used for side mounted engines or upright/inverted engines?
I have a similar head but the plug is aimed forward. Is this one used for side mounted Foxes or upright/inverted?
Re: Fox 35 heads and their use
« Reply #1 on: June 01, 2012, 07:04:27 AM »
Contact Bigiron, alias Marvin Denny.  I bet he would know.   On my Fox .35 Stunt the head has the plug pointing to the rear.   I beleive it was a Larry Foster design for RSM Dist., alias Eric Rule.   It was supposed to be for side mounted Fox Stunts, but is working great on the ISW. H^^
Offline YakNine
« Reply #2 on: June 01, 2012, 06:52:23 PM »
Larry Scarinzi is a fox encyclopedia too
AMA 85135        GSCB
