  • July 03, 2025, 11:21:47 AM
Author Topic: Li-on vs Li-po?  (Read 628 times)
Li-on vs Li-po?
« on: June 29, 2025, 12:25:57 PM »
Does capacity change when going from Li-po to Li-on?
If I'm currently using a 5 cell 2800 Li-po 25c, would I use the same in a li-on pack?
Online Howard Rush
Re: Li-on vs Li-po?
« Reply #1 on: June 29, 2025, 12:56:50 PM »
Five Molicel P-30Bs should do the trick. I switched from 6-cell LiPo 2800 mA-hr batteries to 6-cell P-30Bs with no problem. I do have some space between cells for cooling.
Online Brent Williams
Re: Li-on vs Li-po?
« Reply #2 on: June 29, 2025, 03:21:24 PM »
If you are currently using a 5s2800 Li-po and are considering Li-ion, plan for a move up to a 6 cell setup.  The weight of the 6s li-ion pack is about the same as a 5s Li-po, and you get the benefits of the increase in system voltage and much lower amp draw.
As Howard mentioned, the P30b is a great cell and prices are coming down, thankfully.  You will get good results from the P28a and P28b, but the P30b is the best current 18650 cell offering.
I'm still running the older p26a cells, but my Hubin FM9 system and BA wood 2-blade prop doesn't demands as much as the active Igor/Fiorotti systems and 3 blade props.
« Last Edit: June 29, 2025, 04:53:24 PM by Brent Williams »
Re: Li-on vs Li-po?
« Reply #3 on: June 29, 2025, 03:38:27 PM »
They are pretty close to the same.  Two differences I have noticed, and they are somewhat related.  First the Li-Ion will allow you to practically run it down to zero capacity and not damage the battery.  On Lipo I tried to keep my reserve around 20% depending on the wind.  On Li-Ion I go down to about 3% with no problems.  The other is that Li-Ion are not as even over the run as Lipo.  They will start to "sag" some (about .1 Lap time) towards the end.  The timer will keep that under control but I have found that the boost is not as fast starting after the hourglass.  You can also set your low voltage cutoff to 2.8 vs 3.0, in fact you should.  AND...the weigh less.
Re: Li-on vs Li-po?
« Reply #4 on: June 29, 2025, 03:48:08 PM »
Let me guess, you have printed separators.....  Does it help?  I am finally recognizing that everything I knew about IC is just taking up space in an aver shrinking memory bank.  Battery cooling is a real art form and a lot of our planes really don't do it very well, especially conversions.    Anybody that can feel 1 gram of tip weight in wind has to have a better battery box.  Pictures?  or not.
Re: Li-on vs Li-po?
« Reply #5 on: June 29, 2025, 07:26:02 PM »
  I last worked part time at the local hobby shop in 2015. Leading up to that, we carried all sorts of batteries for all sorts of uses. We had a display for a long time that was just for Li-on batteries, that were flat packs, mush like the typical Li-po's are. I don't think we ever sold a one of those in any size. I tried to find out information about them so I could try to sound intelligent about them if someone asked,  but really couldn't nail down the "why" we even stocked them. I think they were eventually sent back for credit and they haven't had anything like that since. Then fast forward to recent times and many stunt grunts are using Li-on batteries. So, what goes around comes around again someday?
   Who's got a quick, short history on who started using these first and when? My memory of them is being mention by Paul Walker a few years ago, but is that where the use started ? Is any other part of the hobby using them for flight packs? The R/C pattern guys maybe?? I'm just curious to know.
Re: Li-on vs Li-po?
« Reply #6 on: June 29, 2025, 07:31:29 PM »
Dan
I think the FPV quad guys use them. Propbuster (aka - Ryan) flys FPV quads and he uses a few along with Li-Po's
I think they want them for long range.
Re: Li-on vs Li-po?
« Reply #7 on: June 29, 2025, 08:36:04 PM »
Dane Martin got the ball rolling on Li-ion's for serious stunt in 2020-early 2021.  Paul was one of, if not the first big-gun to go all in.  https://stunthanger.com/smf/gettin-all-amp'ed-up!/newer-li-ion-batteries/msg612392/#msg612392
Long range FPV planes and non-racing drones use them.  It sometimes simply comes down to the amp draw that one needs to satisfy the task at hand.  Li-ion has some limitations in that regard, but the technology is getting better all the time.
« Last Edit: June 29, 2025, 09:24:25 PM by Brent Williams »
Re: Li-on vs Li-po?
« Reply #8 on: June 29, 2025, 10:13:16 PM »
       The way that went was Ted and I were wandering by the circle during a Howard practice flight, and I guessed that he needed about 2 grams, just casually eyeballing it. He added 3, then it started hinging the other way.
    I had nothing to do with it, so I will let those involved show what they want to. It is not a trivial difference - I think Dennis and Jim saved something like 2 ounces and the gaps kept the cells much cooler.
Online Dennis Nunes
Re: Li-on vs Li-po?
« Reply #9 on: June 30, 2025, 04:59:53 AM »
As usual, Brett is correct. I was using Thunder Power ProLiteX 6-cell 2800 mAh batteries in my Circulas 61e. I have some of the older TP 6-cell battery that weigh 12.30 oz. Thunder Power's current 6-cell batteries weigh 13.00 oz. This is .7 oz heavier and .125" taller than the older packs. Some modelers, with tight clearances for their batteries, found out the hard way when they received the new TP batteries and would fit in their models.
My latest Li-Ion 6-cell battery packs that I've made weigh 10.70 oz. These packs use the Molicel INR-18650-P30B 3000 mAh cells. These packs are 2.30 oz. lighter and have more capacity than the TP packs, which is substantial. These packs, so far, have worked extreme well.
One clarification, Jim (Uncle Jimby) and Howard Rush have made 5-cell and 6-cell Li-Ion packs with end caps (no shrink wrap around the pack) that create space between each cell for cooling. I'm still making the "traditional" triangle shape 6-cell packs with shrink wrap (no spacing).
Dennis
ps: I have 8 Used Thunder Power ProLiteX 6-cell 2800 mAh batteries with XT-60 connectors in good condition for sale. See https://stunthanger.com/smf/classifieds-92/8-used-thunder-power-prolitex-6-cell-2800-mah-batteries/ for further information.
« Last Edit: June 30, 2025, 09:03:27 AM by Dennis Nunes »
Online Howard Rush
Re: Li-on vs Li-po?
« Reply #10 on: June 30, 2025, 12:01:45 PM »
Some pictures are at https://stunthanger.com/smf/plotters-and-cut-files/what-have-you-printed-lately/
My P30Bs end a flight at just over 3.5 volts/cell.  As I recall, they get to about 120 degrees F.  At lower voltages internal resistance, hence heating, goes way up.
I didn't like the way people were making Li-ion batteries. They wouldn't fit in my airplanes, they were of inconsistent shape, they were covered in heat-shrink blankets, they had balance cables of no use in flight, and they had unnecessarily heavy and long wires.  Printing the end caps (Brent's idea, I think) allowed space for cooling (not as necessary as I feared), allowed the balance connector to be mounted on the battery, allowed mounting provisions to be printed in, and made the overall battery shape consistent.  Consistent shape made mounting them easier.  I am still figuring out better ways of holding them down, and the closer tolerance of printed parts really helps.
Re: Li-on vs Li-po?
« Reply #11 on: June 30, 2025, 12:04:55 PM »
Is there a commercial vendor selling the Li-on packs?
Best,   DennisT
Re: Li-on vs Li-po?
« Reply #12 on: June 30, 2025, 01:14:56 PM »
You are feeding my overwhelming desire to make absolutely everything adjustable.  Endgame 5 is on the drawing board.   Is there any reason the power wires to the esc could not just plug into an XT60 that is part of the pack like your balancing plug which is way cool!  With the fuselage nose designed right you could have a drop in power pod like a lawnmower.  You make a valid point.  We design batteries to fit our planes.  Wrong! I am going to design to fit the battery this time.  Going to be fun!
PS - are there dimensions for those caps?  I need to design the mounts for the leads and the battery.
Re: Li-on vs Li-po?
« Reply #13 on: June 30, 2025, 09:24:33 PM »
    And, whatever the effect (weight or, more likely CG), it flies much better now!
Online Howard Rush
Re: Li-on vs Li-po?
« Reply #14 on: June 30, 2025, 10:17:29 PM »
Good idea. If you don’t have a separate arming plug and the battery is enclosed by a hatch, though, you would need to open the hatch to disarm the system. You could mount the arming connector on the battery and have a window on the side of the plane for the plug.
Another consideration is the ability to change an LRU in time for your next flight if you take an attempt.   I think this is Paul Walker’s requirement.  This causes extra connectors. Putting more stuff in the battery assembly might be a better way to meet this requirement.
Do you have CAD?  If not, remind me of your postal address.
Offline bill bischoff
Re: Li-on vs Li-po?
« Reply #15 on: July 01, 2025, 03:10:59 PM »
Howard, which costs more if you leave it at the field?  VD~
Re: Li-on vs Li-po?
« Reply #16 on: July 01, 2025, 06:46:40 PM »
A full can of fuel!
Online Howard Rush
Re: Li-on vs Li-po?
« Reply #17 on: July 01, 2025, 11:39:01 PM »
You’re mean.
Re: Li-on vs Li-po?
« Reply #18 on: Yesterday at 02:50:11 PM »
Not meant to be mean, Howard, just "jiving" with you.  :)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Li-on vs Li-po?
« Reply #19 on: Yesterday at 06:37:22 PM »
The big thing is the 25c.  You have to look at the discharge rate
Li-ion typically Lithium nickel manganese cobalt oxides (NMC) has a slight lower discharge rate for the same size, and can  e a little heavier.
Li-po has the highest discharge performance, then Li-ion, then LI-Fe.  But to compare exactly the same batteries with different chemistries is not easy.
But while in theory LI-Po are higher performance fort the weight and discharge rate, the NMC cells are catching up.  NMC cylindrical cells have several fail safe features that i think make them worth the slight dip in performance.  NMC is the choice for high discharge applications like power tools.
We routinely put 200+ cells in a single battery assembly and I would never to do that with a lipo.
Dave Siegler
NE9N extra class
AMA 720731
