  • July 18, 2025, 09:22:23 PM
Author Topic: rubber powered models  (Read 3166 times)
Offline Bootlegger
« on: April 23, 2019, 06:14:36 AM »
 As I am having health problems, I am looking at flying rubber powered models instead control line, are there any web sites that a fellow can search for these?  I am interested in scale and larger high wing as well as WW II models..
  Larger is 38"-- 52"  wing span..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline James Holford
Re: rubber powered models
« Reply #1 on: April 23, 2019, 06:17:13 AM »
https://dpcmodels.homestead.com/ is my favorite. Primarily WW1 kits but he does laser cut alot of sterling, conet, and Cleveland Short Run kits.
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Joe Ed Pederson
« Reply #2 on: April 23, 2019, 06:24:10 AM »
A good place to start would be http://flyingacesclub.com/      Brodak also sells some Free Flight Scale rubber models by Mike Midkiff and others.
Joe Ed Pederson
Offline Ara Dedekian
  • Ara Dedekian
« Reply #3 on: April 23, 2019, 06:33:52 AM »
        http://www.hippocketaeronautics.com/hpa_forum/index.php
        Go to the free flight section, then to rubber scale.
        You're in good company, there's a bunch of rubber scale builders lurking about here on Stunthangar. Show us what you'll be building.
        Ara
Offline badbill
« Reply #4 on: April 23, 2019, 07:43:00 AM »
Bill Davenport
AMA 28141
Offline Norm Furutani
« Reply #5 on: April 23, 2019, 11:11:17 AM »
Bob Holman has excellent laser cut short kits. http://bhplans.com/OTS.html
Norm
« Reply #6 on: April 23, 2019, 11:23:54 AM »
Ara beat me to the recommendation for Hippocket.  I like Easybuilt for rubber-specific stuff (and Esaki tissue, which is good for 1/2-A).  Dunno if they have jumbo scale stuff.  Hippocket has a nice plans section.
Online Dan Berry
« Reply #7 on: April 23, 2019, 11:37:29 AM »
National Free Flight Society is freeflight dot org
Flying Aces Club you already have.
Ross Janke and Dick Mathis fly on a sod farm near Baton Rouge.
Snider Swamp Free Club is their facebook group.
Online 944_Jim
« Reply #8 on: April 23, 2019, 12:15:50 PM »
https://dpcmodels.homestead.com/ is my favorite...
NFI, Dave cuts great kits, although mostly the smaller stuff! He has done some one-off work for me too.
Offline Walter Hicks
« Reply #9 on: April 23, 2019, 03:01:18 PM »
Easy built good wood and nice kits, I have several big ones, and lots of other kits. I am saving them for when we do not have many folks still flying control line.  I am 64 my flying buddies are 80,76 and 72. Penn Valley Hobbies used to make great kits I have lots of those. They are no longer in business. Herr Engineering makes some nice 30" planes laser cut, and well as Dumas very nice kits. But the big ones 50" or so Easy Built.
Miss America 50" I think Bob Holman makes short kits, Lots of Rubber Free Flight stuff still available. With laser cut kits and now using Uhu glue stick to apply tissue Free Flight is very attractive. Bob Hunt has a great video on applying Japanese Tissue , shows all the methods including Uhu glue stick.
« Reply #10 on: April 23, 2019, 05:00:06 PM »
I used to fly lots of FF rubber.  However, after losing a couple to winding explosions, and losing several more to thermals, I took the easy way out...with electric motor and R/C assist.  No more blown motors and no more chasing through alligator-infested swamps.  Still get to fly some great old time models.
« Reply #11 on: April 23, 2019, 05:00:59 PM »
   Rubber power models are the biggest bang for your buck in model aviation. Limitless number of kits and designs out there. Current production stuff plus lots of old kits, plans and pattern of old kits also. I did a Comet Taylorcraft from the old dollar kit series with the 54" wingspan once and will do another some day. $ loops of SIG rubber, and scratch built larger prop, and plug in wings help with transport and storage. On a calm evening, it would do a minute plus and never get higher than 50 or 60 feet. Not much in the way of special equipment is needed if you can make stuff yourself. If not, sell off some engines and that should get you supplied with some winders, stooges and such. Don't limit yourself to outdoor rubber either. Get a rubber stripper and find yourself some plans for Mini-stick and parlor mite models and any living room can be a flying site. Your first efforts won't be world beaters but you'll see improvement as you build and fly more. Make it a goal to get a one minute flight in your living room. If you make that, you will have learned the basics needed for more elaborate indoor models. Free flight tow line gliders are fun also and lots of old stuff can be rudder R/C assist to help avoid the chasing. You can build some that will be under that magic 8 ounce weight limit and thumb your nose at the FAA!!!! The late Jim Thomerson was going this rout when he got to a point where he couldn't fly C/L any more and refused to give up modeling. Hang in there, and the free flight world is your oyster!!
Offline Phil Krankowski
« Reply #12 on: April 23, 2019, 09:06:55 PM »
https://outerzone.co.uk
While dominated by RC, there is a plethora of CL and freeflight plans here.  The tag matrix breaks out rubber powe with over two thousand entries.
Phil
Offline Warren Wagner
  • Bradenton, FL
« Reply #13 on: April 24, 2019, 12:42:33 PM »
Don't forget Guillows.
...they are still in business and have a large
product line.   I just purchased an Aeronca Champ from them, to
relive a childhood dream.   Hopefully, with what I've learned about
modeling over the past 75 years, it will show up in getting more than
10 feet of altitude !!!
http://www.guillow.com/index.aspx
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
« Reply #14 on: April 25, 2019, 02:09:18 PM »
You'll want to visit the Flying Aces Club Non-Nats July 17 to 20 in Geneseo New York (near Niagara Falls).  Sort of like Brodaks Fly-In except free-flight.
Offline Bootlegger
« Reply #15 on: April 29, 2019, 10:01:00 AM »
   Thanks a lot guy's, I sure do appreciate the help, look forward to returning the favors...
Gil Causey
AMA# 6964
Online Dan Berry
« Reply #16 on: May 02, 2019, 07:56:42 PM »
Hey Gil. Check your messages.
Offline Bill Adair
  • AMA 182626
« Reply #17 on: May 03, 2019, 10:09:22 AM »
Bought a Fokker D-8 short kit recently from Dave at DPC, and it is one of the nicest FF kits I've ever seen! I own several of the premium FF rubber scale kits, and they are a hard act to follow, but Dave's kits steal the show!
In addition, Dave included a CD with tons of articles pertaining to FF, and even prop carving instructions. Hell of a deal for the FF enthusiasts. Check his web site below to see all the great kits he offers.
Online 944_Jim
« Reply #18 on: May 12, 2019, 05:18:40 PM »
DPCModels!! Yay!
I have a custom cut 85% size Brown Novotnik Mosquito from him. The build log is on RCG now. The wing is papered and doped as of today. This kit is "schweeet!" While the original is sized for .049 Babe Bees, this one will be fitted with a pair of .020 Pee Wees.
There is a Guillows group on FB. One of the guys does Guillow's/DPCModels Reproduction builds on the group page. Phenominal work. I know of one mistake in one of the Reproductions. Mr. Bill, if you use FB it might be worth checking the group page out to ensure there are no errors. iSTR, the error was with the wing saddles on one of the WWI biplanes. The rear of the saddle needed a notch cut into the bulk head the saddle terminated on.
Offline Bill Adair
  • AMA 182626
« Reply #19 on: May 12, 2019, 09:40:05 PM »
Jim,
Wow, that sounds like a great FF project!
I think you will find that the Pee Wee .020 is nearly as powerful as the Babe Bee, and probably saves some weight (plus better ground clearance with .020 size props).
That Pee Wee was the first Cox engine I ever flew, and it hauled a Larry Scarinzi Queen Bee around with more than enough power to hover, and climb away (with less dithering at the handle). Wish we had Spectra lines back then, as the cotton  lines had tons of drag, stretch. We lived in Denver at the time, but the Pee Wee might be too powerful to hover at sea level. I have the plans for the Queen Bee, but doubt I could do a tissue finish, as I'm not as steady with my hands these days.
I have to check out the FB site you mentioned, but that may tie up my interest for days after !!!  ;D
Later pal,
Offline eric greeson
« Reply #20 on: May 13, 2019, 08:35:48 AM »
I was looking into some FF there for awhile and Hippockets  Forum has some really nice and helpful people on there , alot of good kits too as you probably know by now .
