  • July 18, 2025, 02:44:28 AM
Author Topic: RSM Ringmaster  (Read 2067 times)
Offline Shawn Kuntz
  • Ringmasters Forever!
RSM Ringmaster
« on: March 03, 2007, 10:44:16 PM »
Anybody out there ever build one of these?  How is it compared to the original design?  Thanks.
Shawn Kuntz
Bismarck, North Dakota USA
Offline Bootlegger
Re: RSM Ringmaster
« Reply #1 on: March 04, 2007, 06:40:56 AM »
  I am finishing one up now (clearing) and it is identical as far as I can see. The wood is of course much better.  Right now mine weighs in at about 11,5-12 oz minus hdw.  I expect about 25 oz finished which is heaver than some, but ok with me.
 Power will be an OS 25 FP with the boost port blocked. I plan to fly with an APC 9x5 prop, and hope to go to Houston Tex next month for the all S-1 Ringmaster contest put on by Dee Rice and David Gresens.
  Good luck with yours........... H^^ H^^ D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Leester
Re: RSM Ringmaster
« Reply #2 on: March 04, 2007, 07:26:37 AM »
Shawn: The kit is excellent, all laser cut all hardware included with allowable upgrades, tip box adjustable lead outs etc. I have a stock Fox 35 on mine and really enjoy it. It's also sturdy, I've planked mine  several times with nothing more than bent needle and torn silkspan.
Leester
ama 830538
Offline Bob Disharoon
Re: RSM Ringmaster
« Reply #3 on: March 04, 2007, 03:43:10 PM »
I am just finishing an S1 ringmaster from original plans. how does this compare, or are they the same?..sorry to ask so many dumb???s, but been out of the hobby for 30 yrs.  thanx! BOB.....btw, Is the kit available?
Offline Leester
Re: RSM Ringmaster
« Reply #4 on: March 04, 2007, 04:04:41 PM »
Far as I know there the same plane. Yes on the kit availability, www.sshobbies.com
Leester
ama 830538
Offline Phil Coopy
Re: RSM Ringmaster
« Reply #5 on: March 04, 2007, 08:24:04 PM »
The RSM kit builds great and flies great...
Phil
« Last Edit: March 08, 2007, 07:13:19 PM by PHIL COOPY »
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Re: RSM Ringmaster
« Reply #6 on: March 05, 2007, 06:19:09 AM »
Pat Johnson has done a nice plan for a Ringmaster "Lite".  It shows the orginial S1 OTS design but also shows enhancements that can be made to make a light weight version. e.g. 1/16" formed LE or cutout LE, alternative wing spar design or original, carbon fibre pushrods, honey combed plywood parts etc These mods are intended to get the finished all up weight to around 23-24 oz and make it only suitable for a .25 engine or smaller. And it is still OTS and PAMPA legal.
Cheers
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Steve Holt
Re: RSM Ringmaster
« Reply #7 on: March 06, 2007, 02:24:08 PM »
The latest version of the RSM kit uses a built-up LE with a vertical sheet spar so that the LE is now a "D" tube the same size and shape as the old solid carved piece.  Stiffer and stronger as well as lighter.  It is a little more work, but worth it.  Eric will also supply 1/32 plywood cheeks if you are going to use a modern 25 engine.  If a really light engine like the Brodak 25 is used with a light tongue muffler, it is possible to build one at 20 oz.  Mine weighed 21 oz with an FP20.  Still OTS legal.
Re: RSM Ringmaster
« Reply #8 on: March 06, 2007, 05:37:03 PM »
WOW..that is lite...have you checked out the" brotherhood of the ring"?...these guys really build light and are can answer any RM question you can think of...BOB
Re: RSM Ringmaster
« Reply #9 on: March 09, 2007, 06:16:46 PM »
Phil..that looks like an older fox with the 2 hole vertical mounting screws..if so, what length and size hardware did toy use to mount it to the engine?
