  • July 21, 2025, 11:31:55 PM
Author Topic: RSM Mosquito Build (pics)  (Read 3820 times)
« on: August 09, 2009, 01:09:31 AM »
finally have the construction done on the Mosquito - Build article is 80% complete - will be 100% tomorrow and should be uploaded onto the RSM website soon
I still have the fillets to do - and a whole heap more sanding
Had a few challenges along the way and have some improvements to make to the kit - but all is well otherwise.  I can recommend this kit to anyone that wants a smart looking twin
Offline Bill Hummel
Re: RSM Mosquito Build (pics)
« Reply #1 on: August 09, 2009, 05:18:44 AM »
Wynn, bloody brilliant!  Looks awesome!  What engines?
ama 72090
Offline Leester
« Reply #2 on: August 09, 2009, 06:54:47 AM »
Looks great Wynn, will be looking forward to the build article as I have the kit.  I'm planning on L&J Fox 35's. What props do you have there  ??? ???
Leester
ama 830538
Offline Jim Oliver
« Reply #3 on: August 09, 2009, 07:21:16 AM »
Guys,
Would two Brodak .25's work on the Mosquito? Just wondering, since I have a couple looking for a home........
Jim
Jim Oliver
AMA 18475
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #4 on: August 09, 2009, 10:53:17 AM »
Wow, that's SWEET!
« Reply #5 on: August 09, 2009, 10:59:38 AM »
OUTSTANDING!
« Reply #6 on: August 09, 2009, 02:38:14 PM »
thanks guys -
Bill - engines are undecided at this stage - I set it up for OS LA25s - but might put 46s in it  >:D   Then thinking last night I might go for Evo 36s, or Enya 30s.
Lee - the build article I should get around to doing today (I hope) I will ask Eric Rule if I can e-mail you a copy. the props are 10 x 7 master airscrews - only for show at the moment.
Jim - Brodak 25s would be a great combo for this plane I believe
Offline Balsa Butcher
  • High Desert Flier
« Reply #7 on: August 09, 2009, 02:42:09 PM »
Very Impressive - might be a good candidate for the Nostalgia 30 class  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Robertc
« Reply #8 on: August 09, 2009, 03:40:47 PM »
Built my pre-RSM kit several years ago and powered with Thunder Tiger 25s.  More than enough power and an excellent flying plane.
« Reply #9 on: August 09, 2009, 04:03:11 PM »
 Looks great Wynn! I would suggest more oomph than .25's though. Keith Sandberg in our club used to fly one with two O.S..35-S's on it I think it was. He also used black Tornado 10x4's. It did REALLY well. The thing was a blast to watch go through the pattern. I just always feel that more power is good because you can always tune it back, but if you don't have enough to start with then it's a bigger headache.
 Now, about that B-25... ;D S?P ;D
« Reply #10 on: August 09, 2009, 07:54:59 PM »
WOW Wynn !!!!
I know you will put a kewl finish on it. Very well done.
Please keep us posted.
Offline Matt Colan
« Reply #11 on: August 10, 2009, 07:24:43 AM »
Wynn, that looks pretty darn good!  I'm sure you could come up with a pretty good paint scheme for this plane.
Eric Viglione
« Reply #12 on: August 10, 2009, 09:33:30 AM »
I spoke with Jack when he built the first RSM proto, and he said he had 2 Fox's on there... and when one engine quit, he was pleasantly surprised that the plane was still "sorta stuntable" on one Fox. Based on that, I wouldn't put any boat anchors or hot rods in there. A pair of Brodak 25's or similar small light engines would probably be more than fine.
EricV
« Reply #13 on: August 10, 2009, 03:25:40 PM »
The Mosquito looks great.
I've had one of these kits for a couple of years (I think).  Jack's original had two Fox 29's in it and had plenty of power.  Two LA25's are planned for mine and I feel they have a lot more power than the Fox 29s....maybe even 35's.
I used a LA25 on a Ringmaster for OT Stunt for quite a while and it worked at least as well as any Fox 35.....lighter too.
Seeing this one boosts my interest in completing mine.
Offline Martin Quartim
    • StuntHobby
« Reply #14 on: August 10, 2009, 05:59:28 PM »
So nice to see models like this been built.
I use the Enya SS30, it is inexpensive and it runs so smooth with an APC 10.5x4.5. No need to change a thing to get repeatable steady runs. If you have any questions about the engine I'll be glad to help.
FWIW, Enya has a reverse crank for the SS30 and Zinger has quite a selection of props to make a pair work for you.
Windy said that having the engines spinning in opposite directions made a big difference on his B-25.
Martin
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #15 on: August 10, 2009, 06:20:44 PM »
Very nice work. Looks like a fine kit.
I've seen Robert Compton's Mosquito fly and it is an impressive model.
L.
"Before you put on a frown, make absolutely sure there are no smiles available." -Jim Beggs
