  • June 21, 2025, 03:19:24 AM
Author Topic: Arming plug  (Read 754 times)
Offline Glen Meador
Arming plug
« on: December 10, 2024, 07:33:34 AM »
What is everybody using for an arming plug setup on the side of a built up electric model?
Offline CircuitFlyer
    • www.circuitflyer.com
Re: Arming plug
« Reply #1 on: December 10, 2024, 08:15:20 AM »
I soldered up an XT-60 type plug.  I found it a little more compact on the inside than the more popular Deans type.  I could probably reduce the size of the wire loop and use a heat shrink end cap to cover the exposed ends.
Paul Emmerson
Offline John Rist
Re: Arming plug
« Reply #2 on: December 10, 2024, 08:58:47 AM »
I have used this type of arming plug an all of my models.  It works great.  However i hang the plug on a piece of spider wire flight line so that it doesn't get lost.
Offline Doug Moon
Re: Arming plug
« Reply #3 on: December 10, 2024, 09:02:11 AM »
This looks nice.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Doug Moon
Re: Arming plug
« Reply #4 on: December 10, 2024, 09:03:41 AM »
Sometimes I see fliers using a bullet connector as their arming plug. I am curious of anyone that is using that can show how they mount the connector on the inside of the fuse?
Doug Moon
AMA 496454
