  • July 20, 2025, 07:15:49 AM
Author Topic: Wheels keep popping the spar on the lower wing! On landings....  (Read 2458 times)
« on: December 10, 2011, 01:02:20 PM »
I have patched the spar on the bottom wing on my Bi-Slob more then once. On one side it even broke a rib. I am trying to figure out how to keep this from happening.
Any ideas?
Offline John Kelly
Re: Wheels keep popping the spar on the lower wing! On landings....
« Reply #1 on: December 10, 2011, 01:54:11 PM »
   Hey Paul...  Simple, build it the way we did with both the original SLOBS and BI-SLOBS. Eigth inch ply l.g. former, angled forward.
AMA 11416
Offline greg maclachlan
« Reply #2 on: December 10, 2011, 02:10:36 PM »
This is what I did after rebuilding the spar/front end a couple of times.
Online dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #3 on: December 10, 2011, 02:59:23 PM »
I don't know.  Land softer  y1
Dave Siegler
NE9N extra class
AMA 720731
Offline Garf
    • Hangar Flying
« Reply #4 on: December 10, 2011, 03:45:45 PM »
1/4 scale R/C gear and 4" balloon wheels.
Offline Bill Hodges
« Reply #5 on: December 10, 2011, 03:47:50 PM »
Use the alum gear from an All American or Barnstormer kit.  We have been doing that for quite a while and it solves the broken spar problem.  You can get them from Brodak.
Bill Hodges
Bill Hodges
AMA 12450
Offline Zuriel Armstrong
« Reply #6 on: December 10, 2011, 03:56:57 PM »
Stop letting me fly it and stop hitting the ground VD~
Zuriel Armstrong
AMA 20932
Offline Russell Shaffer
« Reply #7 on: December 10, 2011, 08:52:37 PM »
If it is from the gear spreading too much, solder a spreader bar of 1/16 wire between the gear legs.  Two wires are much harder to bend than one.
Russell Shaffer
Klamath Falls, Oregon
« Reply #8 on: December 10, 2011, 09:31:44 PM »
Land softly.  LL~ LL~ LL~ LL~ LL~
Online kenneth cook
« Reply #9 on: December 11, 2011, 05:32:10 AM »
               Paul when Dan and I were flying our slobs we would get carried away hitting the ground too hard and that would always happen. I repaired it and it did it again and again. I asked him what should I do with it. He tried using spruce on his bottom spar and it still did it. He said pull out the broken pieces and cover over it. I had to laugh. Ken
Offline Lester Nicholson
« Reply #10 on: December 11, 2011, 06:02:06 AM »
With mine I put in 1/8" balsa plates between spars and it broke again on next landing so then I added a 1/8" ply plate and used an aluminum R/C gear I had laying around from who knows what. End of problem until a wind gust threw the airplane half way across the circle at me. At 65 I'm unable to run fast enough to keep the lines tight. Need to build another but the gear/spar assembly survived. lol     Nick
« Reply #11 on: December 11, 2011, 08:37:11 AM »
Any ideas?
Hi rootbeard!
Like the guys say, an aluminum gear mounted sorta like the one in the Vector you just did. ;D
Big Bear
« Reply #12 on: December 12, 2011, 02:00:34 PM »
Yep. Think that is what I will do....
