  • July 25, 2025, 12:17:42 AM
Author Topic: rojett 61  (Read 2735 times)
Offline Steve Bakac
rojett 61
« on: March 21, 2016, 02:50:34 AM »
Hi all
        I'm thinking of purchasing  a Rojett 61 now do I ask for a Brett Buck 61 ready to go or do I have to have it modified by someone else .Also will to Rojett pipes work ok with it or go with one of Randy's
   Cheers Steve
Re: rojett 61
« Reply #1 on: March 21, 2016, 07:25:49 AM »
What mods does it need?
Re: rojett 61
« Reply #2 on: March 21, 2016, 08:00:34 AM »
The engine is superb as you get it and needs nothing.  I do use a .205 Venturi over the stock .180 but that's a preference.  Either pipe works fine.  I could be wrong but I think there was a running change on port timing a few years ago which may be the Brett version but I have both the oldest and newest versions and find very little difference though I think the older one is a bit stronger.  Just order the stock BSERE.
Re: rojett 61
« Reply #3 on: March 21, 2016, 09:23:36 AM »
  Order the "Brett Version" just to be sure.
Re: rojett 61
« Reply #4 on: March 21, 2016, 09:26:39 AM »
Hi all
   Cheers Steve
  DO NOT, repeat, DO NOT have the engine modified by someone else. Buy it directly from Dub Jett and ask for RO-Jett 61 BSE "Brett Version". Then just run it.
   I use the Randy/Billy 50-61 "slimline" pipe from the early '00's. Ask Randy for the nearest equivalent, but it must have the largest exhaust outlet.
Re: rojett 61
« Reply #5 on: March 21, 2016, 09:39:38 AM »
Does the 65 come in Brett version?
Re: rojett 61
« Reply #6 on: March 21, 2016, 09:42:42 AM »
   Get the 61, as noted.
Offline Balsa Butcher
  • High Desert Flier
Re: rojett 61
« Reply #7 on: March 21, 2016, 11:13:26 AM »
As has been reported and discussed previously; the 65 is no longer in production, 61 does just fine... 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Gerald Arana
Re: rojett 61
« Reply #8 on: March 21, 2016, 01:13:53 PM »
Hi all
   Cheers Steve
If the 61 isn't enough poop for you, I suggest you install a "Buick V-8"  LL~ LL~ LL~ LL~ LL~ LL~ LL~
That ought to be enough power!  LL~
Jerry
Offline Steve Bakac
Re: rojett 61
« Reply #9 on: March 21, 2016, 02:10:06 PM »
Thank you guys for all the input I understand what I need to order now
 Cheers Steve
Offline Paul Allen
Re: rojett 61
« Reply #10 on: March 21, 2016, 02:59:31 PM »
        I guess you are not building the Vector!
Offline Steve Bakac
Re: rojett 61
« Reply #11 on: March 21, 2016, 06:12:00 PM »
Hi Paul
   Well you can never have to much horse power up front haha
Narrr its for the other project thats coming i told you about chupim60
 cheers Steve
Offline Richard Field
Re: rojett 61
« Reply #12 on: March 22, 2016, 03:44:53 AM »
Hi Steve,
Good to see you've also put yourself down for the Chupim60. Hopefully we can have 2 flying in NSW without too much delay!
I've just scored a NOS (2012) Ro-Jett 67 with Header/Pipe set that may yet find it's way into my Chupim60. Let me know if you want any info on the 67 - I'll be measuring it up tonight.
Cheers,
Richard
Offline dale gleason
Re: rojett 61
« Reply #13 on: March 22, 2016, 12:04:58 PM »
Weigh that pipe...you will be pleasantly surprised.
« Last Edit: March 22, 2016, 03:03:41 PM by dale gleason »
Re: rojett 61
« Reply #14 on: March 22, 2016, 11:13:25 PM »
The pipe weighed a mere 1.35oz, only marginally more than the bubble wrap it came in..
As the tape label shows it's the pipe for a 67-76, so a 61 pipe could be less again?
