  • June 30, 2025, 02:16:24 PM
Author Topic: Ringmaster/Fox 35  (Read 1850 times)
Offline Sam Laughery
  • ACE
    • laurelhighlandsrc.com
Ringmaster/Fox 35
« on: October 14, 2007, 06:54:20 PM »
I bought a Fox 35 and a Mcoy redhead NIB at a flea market a couple of years ago for $50.  Not a bad deal.  They both run great.  I finally took my LA 25 off my Ringmaster and put the Fpx 35 with an APC 10X5 on it.  It flies great just like I remember the Ringmaster back in the 50s.  The only problem I had today was that the engine slowed down a little anytime I did an outside manuver.  I have a feeling it may be the tank or tank placement.  It is slightly higher than the center of the engine.  Any suggestions?  I also need to know where the CG is for the ringmaster and what the best fuel is for the Fox.  Thanks for your help.
Sam
Offline Phil Bare
Re: Ringmaster/Fox 35
« Reply #1 on: October 14, 2007, 07:08:01 PM »
Puting the tank on centerline is worth a try and as for balance, I think that the RM will do well balanced about 1 3/4 back .....and as for fuel, the Fox will give you excellent service on Fox Super fuel.......5% nitro, 29% castor oil, and the balance methanol....I would stay away from any synthetics myself...Regards, Phil
Offline Marvin Denny
« Reply #2 on: October 14, 2007, 07:20:47 PM »
  The slowing of the Fox during outside maneuvers is common on profile type mountings.  It can sometimes be a little disconcerting.  Try moving the tank  up some more and if it gets worse, go back down.  move the tank about 1/16th inch at a time for these adjustments.  Try different plugs and different props to see if that cures it.
  I run Fox super fuel for both of the engines you listed.
  Going up in nitro on the fox to 10% won't hurt it as long as you stay with high oil content--- STAY AWAY FROM SYNTHETICS on that engine.
  Bigiron
marvin Denny  AMA  499
Offline Joe Messinger
« Reply #3 on: October 14, 2007, 08:43:23 PM »
Sam,
Check your personal messages.
Joe
Joe Messinger
« Reply #4 on: October 14, 2007, 10:22:32 PM »
I run several Fox 35's on profiles.  I mount my tanks about 3/8" above the centerline of the engine.  As for the CG, I couldn't really tell you.  I've never checked it.
« Reply #5 on: October 15, 2007, 08:16:50 AM »
You say it is slowing down,  does that mean its rich or lean.  If rich, then raise the tank alittle.  If lean then you have to lower the tank.  I have a profile with an Enya 35, Adimisin muffler that the tank is a good 1/2 inch below the center line.   You also don't say if it runs the same upright as it does inverted.  Somewhere on this site Bob Z. has a procedure for setting proflie mounted engines on the ground.  Have fun,  DOC Holliday
« Reply #6 on: October 15, 2007, 09:11:22 AM »
H iSam,
The gurus have spoken!  Marvin knows more about a Fox 35 than Duke did. y1 ;D
25%-29% castor oil for both engines, that's for sure.  Adding an ounce or two (no more) of Klotz to a gallon of fuel is often recommended to help keep excess varnis build up from happening.  I really like to add an ounce of Randy Smith's Aero-1 (Snake Oil! LOL!!) to my gallons of fuel.
One hint: don't let the McCoy ever get a real lean run...........
