  • June 17, 2025, 09:08:52 PM
Author Topic: Ringmaster with a modern twist  (Read 3135 times)
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« on: April 11, 2016, 12:46:05 PM »
hello guys!
here´s the Ringmaster electrified
i have built this one for a fellow modeller, Rogerio Fiorotti, and as he´s 100% electric flyer, this one was tailored for him!
kit is the Brazilian Seritec cersion by Cremon, very well done and great materials
finish is translucent red ultracote and fuselage was painted with automotive paint
electric set up
engine 3520/1110kV
ESC Talon 35 – Castle Creations
Timer by Fiorotti (yes he developed an awesome timer, you should try!)
Bateria Hyperion 3S – 2200mA – 45C
Hélice Mytech Carbono 11x5 cortada para 10X5
final weightl 850g.
kit Seritec
Re: Ringmaster with a modern twist
« Reply #1 on: April 11, 2016, 12:52:48 PM »
Fred,
Outstanding as always. You do professional quality work.  H^^
I'm guessing you used your covering and paint application system on this fine model?
Charles
Offline James Holford
Re:
« Reply #2 on: April 11, 2016, 01:25:20 PM »
It's beautiful
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline John Tate
« Reply #3 on: April 11, 2016, 09:34:35 PM »
Great looking motor mount. Did you make it?
« Reply #4 on: April 12, 2016, 06:03:09 AM »
thanks a lot James and John!
the beatyful mount was machined by the plane owner, Rogerio Fiorotti, he´s here at Stunthanger too, besides the engine mount he sells the timer as well
Charles, you´re very kind as always! yes, this one was the first i´ve tried the finishing method, no clear on the wings, i have just masked 1/8 past the silver and apllied the clear, but served as a test for the Thundergazer. give it a try!
Online Motorman
« Reply #5 on: April 12, 2016, 08:34:27 AM »
Where did you put the sensor?
« Reply #6 on: April 12, 2016, 08:39:21 AM »
I have to ask Rogerio, he did the electric installation, probably under the wing near CG
Offline Phil Hawkins
  • 909 276 0283
« Reply #7 on: April 15, 2016, 08:20:03 PM »
Wow! never say "It's just a Ringmaster" around you!
« Reply #8 on: August 12, 2016, 10:23:50 AM »
unfortunately it´s a client´s plane, but yes, i hope they never say that
or "oh no, another ring.."
« Reply #9 on: August 13, 2016, 05:53:32 AM »
Fred, Interesting that 1/8" clear overlap of the color.
I used to do custom van painting and we would only put clear on the painted areas with that 1/8" overlap.
These were production vans and I sometimes did as many as three or four a day.
The clear we shot was not a 2 part clear. The account always looked for the less expensive way out.
Plenty of detail even in your profile models.  H^^
Charles
« Reply #10 on: August 29, 2016, 04:32:16 AM »
Charles
Charles, to be hones, i only sprayed the clear to the painted areas to avoid polishing the wing, wich i really hate to do...lol
3 vans a day? wow man!
