  • July 13, 2025, 09:16:54 PM
Author Topic: Ringmaster Oldie  (Read 7587 times)
Offline Dave Moritz
Ringmaster Oldie
« on: July 10, 2024, 12:25:41 PM »
Hello to the bros here:
Looking for some advice or perspective on flying this model for fun. It was saved from the dumpster and is older than the hills, with original tissue/dope. I scrounged up a Veco 19 for power. It's scary weak on the wingovers and loops. Here are the stats:
- 32 oz. weight
- 10,500 rpm takeoff
- 5.2 second laps
- 58 feet of .014 stranded
- prop 9 x 3.5 (Top Fite 10" cut to 9")
- Fuel 8-24
I could go through a bunch of permutations but thought I'd check here first. My inclination is that I need more horsies up front (Fox 35 perhaps).
What do you think?
Dave Mo...
Re: Ringmaster Oldie
« Reply #1 on: July 10, 2024, 12:34:42 PM »
Yes more ponies always helps.  However that is an awful flat pitched prop too.  Try a 9-5 or 9-6.   That's what we used on a lot of .19s--accept Enya .19.  These can go like a bat out of haties with an APC 9-4.  Another option would be to go with 55' or 56' lines.   I'm flying my Fox .35 classic airplanes on 56' and like it.
Offline Dave Moritz
« Reply #2 on: July 10, 2024, 07:23:40 PM »
A couple of very good suggestions there - more prop and shorter lines. Perhaps that’ll do the job.
Many thanks.
Dave Mo…
« Reply #3 on: July 10, 2024, 08:09:10 PM »
- 32 oz. weight
- 5.2 second laps
- Fuel 8-24
What do you think?
Dave Mo...
   9-4 APC!
    A Fox 35 is *not* more horsies, I would guess a Veco 19BB in proper condition and set up correctly is 25% more powerful.
« Reply #4 on: July 11, 2024, 07:58:54 AM »
Dave,
The Ringmasters like a little bit more speed than you are flyng speed on 58' lines about a 4.8 sec ish lap time. If your Veco 19 is the later BB version it can do the APC 9x4 set for a 2-2-2 run style. If it is the original Veco plain bearing go with the APC 9 x 5-6 still set for the 2-2-2 just on the rich side (use fuel with at least 25% total oil, 50/50 is OK).
Best,   DennisT
Offline Dave Moritz
« Reply #5 on: July 11, 2024, 11:14:07 AM »
Dennis and Brett
My Veco is the BB version, so I take it that a Fox 35 would be a step down. The standard APC 9-4 comes to the rescue again. Thanks, Brett.
Dennis, I wasn’t aware this model likes faster laps. I’ll gladly shoot for that number.
Much obliged to both brothers of the ring!
Dave Mo…
Offline Dave Moritz
« Reply #6 on: July 14, 2024, 06:09:32 PM »
Success! The 9X4 APC and 55-feet lines did the trick. In spite of my making two changes at the same time, I’ve got a sweet fly in’ model now. You gents’ experience and generosity really helped. Thanks.
Dave Mo…
« Reply #7 on: July 14, 2024, 06:26:06 PM »
Dave Mo…
   55 foot lines!!! That's got to be crazy short lap times.
Offline Gary Dowler
« Reply #8 on: July 15, 2024, 01:44:29 AM »
On top of anything Brett tells you to do, Id suggest going back to 60' lines, straighten out any rudder offset and engine offset and try it again.  Rudder offset is counterproductive to maintaining line tension overhead. It hurts more than it helps.  Getting the aircraft to fly as tangent to the circle as reasonably possible is what you want.  Yaw increases drag which kills energy, especially overhead where you need it the most.  Speed is your friend here, which yaw kills.
Gary
Offline Mike Griffin
« Reply #9 on: July 15, 2024, 04:46:42 PM »
I was thinking the same thing Brett.
Offline Dave Moritz
« Reply #10 on: July 18, 2024, 04:17:06 PM »
Gents
Will need to fire ‘er up and check out line lengths. Stay tuned.
Dave Mo…
Online Dan Berry
« Reply #11 on: July 18, 2024, 04:33:50 PM »
Gents
Dave Mo…
Be aware that the best Ringmaster flyer ever uses 57 ft lines.
Offline Dave Moritz
« Reply #12 on: July 19, 2024, 05:49:18 PM »
Gents: Here is the latest.
Flight One
- lines 55'
- 11,300 launch RPM
- laps 4.8 seconds
Flight Two
- lines 60'
- 11,900 RPM
- laps 5.1 seconds
Sorry about changing both the line length and the launch RPM, but it was just eating too much fuel on Flight One, so turned the needle in 1/8.
I like the feeling of Flight Two as the wingover resembles the feel of my Skyray / OS 20FP combo.
Dave Mo...
« Reply #13 on: July 19, 2024, 09:13:41 PM »
Flight Two
- lines 60'
- 11,900 RPM
- laps 5.1 seconds
    That's more like it, although still pretty slow. But yes, for something like this, theres so much excess power that the airplane is just there to aim the engine in the right direction.
Online Motorman
« Reply #14 on: July 22, 2024, 07:30:16 PM »
Is that eyelet to eyelet or handle to thrust line?
Online Dan Berry
« Reply #15 on: July 22, 2024, 07:40:19 PM »
Eyelets
Offline Dave Moritz
« Reply #16 on: July 23, 2024, 09:36:37 PM »
Decreasing the lap time to 4.8 was much better for handling. Thanks.
Dave Mo…
« Reply #17 on: July 23, 2024, 10:01:52 PM »
Dave Mo…
   Yes, they aren't going to do too well flying like Noblers. As I am sure you have found out, *reducing the control rates*, that is, making the elevator move very slowly for a lot of handle motion, is the key to getting them to fly decently.
Offline Dave Moritz
« Reply #18 on: July 24, 2024, 09:27:01 AM »
 I certainly did as you’d recommended this in another thread some time ago. Double thanks.
Dave Mo…
