  • July 15, 2025, 12:37:48 PM
Author Topic: ringmaster imperial engine choice  (Read 1105 times)
Offline James C. Martin
« on: May 09, 2014, 01:47:55 PM »
Anyone have an opinion on witch os max 46 would a better choice for a ringmaster imperial I have a la-s .46 and a .46 fx converted to control line the ringmaster imperial has a 52 inch wing with flaps and built up fuselage and tail feathers  or is this too much engine for this aircraft?
Re: ringmaster imperial engine choice
« Reply #1 on: May 09, 2014, 02:05:47 PM »
I dunno about the FX, but the 46LA should work fine.
Offline steve bittner
« Reply #2 on: May 09, 2014, 04:04:23 PM »
   Any good running 35 or 40 will be just fine with 10-5 prop, maybe 10-4 if alittle to fast.
« Reply #3 on: May 09, 2014, 06:19:02 PM »
thank you for the info the 46 fx i have is new never seen fuel took a new venturi from a 46sf along with the needle and spraybar all fits the 46 fx very well do have a sig super chipmunk to be assembled thought about using the fx for this aircraft guess i need to bench run this engine ans see how it performs.
Offline Garf
    • Hangar Flying
« Reply #4 on: May 09, 2014, 06:31:12 PM »
It might prove a bit too much.
« Reply #5 on: May 09, 2014, 07:15:45 PM »
Hi James,
One problem is that the room for a fuel tank is pretty small in the Imperial.
 BIG Bear
RNMM/AMM
« Reply #6 on: May 10, 2014, 05:51:02 AM »
I'm using an Enya .29 at present, and probably gonna switch to the Enya .35 I got from Bill Little.[same size and mounting], it flies great, here's the maiden flight. P/S the little guy is my grandson who loves to trip the stooge:
« Reply #7 on: May 10, 2014, 08:29:43 AM »
I my self am finishing the first kit of the Ringmaster Imperial that Walter Umland produced.   It is shown with an LA .46 on the plans and that is what I am using.
