  • July 23, 2025, 10:15:52 PM
Author Topic: Shark 45 Question  (Read 1400 times)
Offline Michael Massey
Shark 45 Question
« on: October 04, 2011, 09:36:54 AM »
I am starting a Shark 45.  I have an old Jetco kit and I am using the parts as templates.  I see that RSM has a Shark 45 kit and they list the fuselage as 41 inches (and some change) whereas the Jetco kit is 47 inches.  That is a substantial difference.  Can anyone "fill in the gaps" and explain the difference, or perceived difference?  Thanks.
Eagle Point, Oregon
AMA 914713
Re: Shark 45 Question
« Reply #1 on: October 04, 2011, 09:53:55 AM »
I thought this had already been covered??? VD~
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: October 04, 2011, 10:47:08 AM »
Look in the Classic section, "Shark 45, Jetco vs RSM". It's right at the top.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Larry Fernandez
« Reply #3 on: October 04, 2011, 10:50:06 AM »
John,
 I know you like to reply to EVERY post , but I really dont think that this was the answer Mr. Massey was looking for.
Larry, Buttafucco Stunt Team
« Reply #4 on: October 04, 2011, 11:09:33 AM »
Actually I did read the thread on the Classic section but missed the brief comment about the fuselage length difference.  I understood the comments about wing area differences but the fuselage length was not really addressed.  Since that changes the moments of the airplane and there was a comment on the Shark 45 moments being competitive in modern stunt, I guess I was looking for a little more detail.
Eagle Point, Oregon
AMA 914713
  • High Desert Flier
« Reply #5 on: October 04, 2011, 12:12:41 PM »
Your explanation piqued my curiosity so I broke out my RSM Shark 45 plans. From the nose ring to the furthest aft point of the fuselage is 45". Add two inches for a spinner and you have a 47" nose to tail. That is how it was probably measured on the Jetco Shark. It looks as if both fuselages are very close to identical in length and the 41" is a mistake or typo on the RSM site. Good luck with the project.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: October 04, 2011, 12:49:38 PM »
Thanks very much Pete.  I broke out the plans from Jetco and measured 44 3/4 from the nose ring to the furthest part of the tail.  Measuring from the spinner they show on the plans it came to 46 1/2.  As you point out, it seems as the two fuselages are pretty close to the same.
Thanks again.
Eagle Point, Oregon
AMA 914713
« Reply #7 on: October 04, 2011, 08:43:14 PM »
Mike,
Measure hingeline to hingeline and the nosering to the leading edge of the wing to see what the differences really are there on the fuselage regarding moments. I'll bet they're not far off.
Chris...
« Reply #8 on: October 05, 2011, 12:00:48 PM »
Good idea Chris.
Measured from the Jetco plans:  Nose ring to LE is 10 3/8.  Hinge line to hinge line is 17 5/8.
Eagle Point, Oregon
AMA 914713
  • High Desert Flier
« Reply #9 on: October 05, 2011, 01:11:43 PM »
Pretty close to the RSM plans which show: nose ring to LE:10.5", Hinge line to Hinge line: 17 7/8".  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #10 on: October 05, 2011, 01:46:18 PM »
Good info.  Thanks all.
Eagle Point, Oregon
AMA 914713
Tags: Shark 45
