Good evening.
While I am building a Banshee to replace that wonderful Magician that bit the dust due to a battery box that came loose during flight, I have also built and flown a Baby Ringmaster to practice.
And that Baby Ringmaster has taught me a lot about control finesse.
As we know, Ringmasters are prone to stall when performing tight maneuvers or doing abrupt elevator inputs. After practicing dozens of loops and wingovers with the Baby, I have learned to keep the maneuvers very smooth and relatively wide, with smooth transitions. As a result, there is no stalling and the flight characteristics are predictable. All I have to do now is to learn the figure 8, which is something that I am kind of afraid of attempting. And then, inverted flight and the other maneuvers.
This is a Brodak Baby Ringmaster, which has rather wide spacing in the leadouts when built according to plans. The ribs are also perforated so the leadouts are wide spaced (about 3 inches or so-not like the Baby Clown, which are almost together). So, I decreased the sensitivity of the handle (a Renger one).
Lap time is around 3.5 seconds on 35 foot .008 lines, with a 6 x 4 EP electric prop. Total weight is 7.8 ounces.
I really am looking forward to flying the Banshee. I have seen them and I like the way they fly.
When I was learning to fly the Flite Streak Trainer (flat bottom solid wing) I was never, ever, ever able to do even one loop. It could do great wingovers, though. It would simply fall like a brick at the top of the loop and do figure 9s even with a relatively shallow angle of attack entry into the loop. And yes, the plane was properly balanced and had the specified amount of power. Yet, it was very heavy (21 ounces when built according to plan and with the electric gear in place).
