I've built 3 Banshees. One for me, one for a friend and one for my daughter when she was 7 years old.. Each one had a few modifications, but all retained the "stock" moments. The only one of those three surviving today is the one my daughter has and it's closing in it's 29th birthday. On it, I used 1/16 birch ply doublers. I "hollowed out" the fuse behind the wing hingeline, installed 3/32 bulkheads (if you can call them that) at angles to the thrustline in hopes of adding some stiffness. I then sheeted the fuselage behind the ply doublers with 1/16th balsa. I increased the stab span to 21", increased the stab thickness to 1/4", and sanded a slight airfoil shape into the elevators.. I added i-beam style half ribs in all the spaces between the ribs. Lastly, I moved the landing gear wire away from the wing slot and made it sit more upright to help stop landing rebound.. It's been recovered a couple times over the years and I don't remember the final weight, but it is light enough that it's powered by an out of the box stock OS Max-S 35 and 10 X 6 Zinger wood.... Oh, one more thing, would you guys believe it still has the original Fox box wedge 4 oz tank on it?
Nick
