  • July 17, 2025, 06:41:07 PM
Author Topic: Rib cutting  (Read 3929 times)
Offline Shorts,David
Rib cutting
« on: January 06, 2021, 11:22:14 AM »
Hi, I've used Ed at Lazer Works in the past, but had to mail him my plans.
Does anyone have a favorite vendor or person who can take a pdf plan and cut the ribs out for me. I tried the sandwich method but the wing taper is too extreme. I'd prefer not to print plans and mail them if possible.
Re: Rib cutting
« Reply #1 on: January 06, 2021, 11:30:50 AM »
Time to get your own laser cutter. H^^
Online Brent Williams
Re: Rib cutting
« Reply #2 on: January 06, 2021, 11:48:15 AM »
You might contact John Miller.  He could loft the ribs properly and produce a dxf file that you could send to Brodak, RSM, or some of the balsa suppliers to laser.  John is a vendor on here. CADClassics.
« Last Edit: January 06, 2021, 02:07:42 PM by Brent Williams »
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
Re: Rib cutting
« Reply #3 on: January 06, 2021, 12:55:59 PM »
You could check around in your area for a laser cutting 'club'.
There is a club here that instructs use of the cutters and how to process your original plans for use with the machines....and....unlimited use of the cutters for $200 per year.
There are several guys in the model clubs here that are members of that laser club....bring your own wood.
Re: Rib cutting
« Reply #4 on: January 06, 2021, 01:54:50 PM »
That's a pretty clever idea. I might bring that up next time we get together.
Re: Rib cutting
« Reply #5 on: January 06, 2021, 03:13:41 PM »
Pat Johnston at patsplans@yahoo.com. Pat can laser cut about anything.
Dennis Leonhardi
Re: Rib cutting
« Reply #6 on: January 06, 2021, 07:13:17 PM »
Aren't we living at a GREAT time!?!  Now, back about 70 years ago ... No Thanks!
Dennis
Offline Dave Harmon
Re: Rib cutting
« Reply #7 on: January 07, 2021, 12:30:22 AM »
Dennis
I bought a couple of Oriental profile kits that instantly transported me back to 56' with the horrible die cutting. I had to make a lot of new parts....the wood was good though....still got that wood in the scrap box.
I understand now those same kits are laser cut.
Re: Rib cutting
« Reply #8 on: January 07, 2021, 10:34:49 AM »
Let's include Pat King, also.
Re: Rib cutting
« Reply #9 on: January 07, 2021, 12:43:50 PM »
Hey, we of the older generation learned how to cut, sand and build those kits when die cutting was the latest thing.   Try a printed balsa sheet some time?    Also remember double gluing on some parts.  Wonder how we didn't have stress lines before Epoxy came to be.  My brothers showed me some of the glue they had to mix themselves that came in a little packet.  No I will not go back to that way again. D>K
Re: Rib cutting
« Reply #10 on: January 07, 2021, 01:51:59 PM »
How about contacting Mr. X-acto.
Motorman 8)
Yeah, my first attempt was pretty bad, but that's always a possibility. I was hoping someone would say they had a magic wand that turned pdfs into lazer cut wood.
Offline George Truett
Re: Rib cutting
« Reply #11 on: January 07, 2021, 04:11:29 PM »
Rob at The Balsa Workbench cut some parts for me from digital files I supplied.  http://www.balsaworkbench.com/
Online Howard Rush
Re: Rib cutting
« Reply #12 on: January 07, 2021, 11:47:17 PM »
I've done that, and cut the stringer notches with a #16 X-Acto blade.  I prefer the smoke-and-mirrors solution.
Online 944_Jim
Re: Rib cutting
« Reply #13 on: January 08, 2021, 07:08:48 PM »
And I used a guy up in Canada to custom-cut a FROG 36" DH Mossie a few months back. He used the Outerzone copy to do the work. We tossed a few emails back and forth as I asked for certain parts to be reduced in thickness. The short kit appears to be well done, but cnc router-cut. I'll know more after I start the build...Mark Winstanley of Kanata Aircraft Models. PM if you want his email address.
Also Dave Cowell of DPCModels in New Mexico may help. I know he does older Sterling, Scientific, OOP Guillow's for FF and CL. I worked with him to reproduce a few Scientific kits (I bought the original kits, he reverse-engineered them for short-run laser-cut productions).
Re: Rib cutting
« Reply #14 on: January 09, 2021, 10:52:03 AM »
Great, thanks guys. I think I may have it worked out now, in fact, maybe too much. I may have a couple sets of ribs coming if I'm not careful.
Dennis Leonhardi
Re: Rib cutting
« Reply #15 on: January 09, 2021, 07:35:12 PM »
Dave Cowell does beautiful work but will be out of action for awhile.  I wish him the Very Best!  He bends over backwards to be helpful.
http://dpcmodels.homestead.com/index.html
Offline Paul Wescott
Re: Rib cutting
« Reply #16 on: January 12, 2021, 03:58:00 AM »
And the solution is...?
Re: Rib cutting
« Reply #17 on: January 12, 2021, 09:09:41 AM »
Yes, so, I mentioned it to Rob at Balsa Workbench and he said he'd cut them from pdf for me, but didn't give me a quote, so I'm not sure where that's at. I got an email from another guy saying he'd do the job but I asked him to wait until Rob gets back to me. If neither of those, then, I'll ask Pat. If not pat, I could have taken out the exacto blade by then and just done it old school. So, that would be my next step.
Re: Rib cutting
« Reply #18 on: January 12, 2021, 05:35:41 PM »
Rob's prices have always been so good, if he tells me he can cut something from my files, I'm comfortable telling him to cut it and send me an amount.  The only problem I can think of is grade of wood, if you want something very light it is unlikely he will have 6 lb or less wood.  Most of his business is RC and they're not so picky.
