  • June 30, 2025, 09:35:17 PM
Author Topic: Fox 15  (Read 1772 times)
Offline Elwyn Aud
    • Inferalandings Photo Page
Fox 15
« on: January 29, 2009, 04:08:02 PM »
What is the size of the back-plate bolts on the old Fox 15?
Re: Fox 15
« Reply #1 on: January 29, 2009, 04:50:22 PM »
Just shooting a best guess... 3-48?   From what I've seen when Fox uses something smaller then 4-40 it's usually 3-48.
Re: Fox 15
« Reply #2 on: January 29, 2009, 05:12:11 PM »
Andrew is right Elwyn. If it is an old steel fin, or the later slant plug, it is 3-48. I just checked mine. I think the head bolts are 3-48 also, but who can get those little buggers out with their little bitty phillips heads all stripped out. You might have to go to McMaster Carr to get them as 3-48's are scarce as hens teeth anymore.
Offline Tom Luciano
Re: Fox 15
« Reply #3 on: January 29, 2009, 05:17:47 PM »
the size is a odd ball phillips that strip very easy LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
Sorry Elwyn I couldn't resist but I will be doing the same on the head of a 36x
Tom
AMA 13001
Offline Bill Gruby
Re: Fox 15
« Reply #4 on: January 29, 2009, 05:31:27 PM »
 Elwyn;
 Yes 3-48 is the size.  I get mine from Ro Brand. I believe you can get them from Fasten All to.
 "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Offline Tom Luciano
Re: Fox 15
« Reply #5 on: January 29, 2009, 05:53:03 PM »
Elwyn,
I just looked at microfasteners.com they have 3-48 various Lengths in stock. you can order in qty. of 10 or fifty I buy all my bolts from them.  I have not experienced any problems with their products.
Tom
AMA 13001
Offline De Hill
Re: Fox 15
« Reply #6 on: January 29, 2009, 08:17:52 PM »
How many do you need, Elwyn?
De Hill
Offline De Hill
Re: Fox 15
« Reply #8 on: January 29, 2009, 08:50:42 PM »
Are you coming out to the field on saturday or sunday?
I can bring you 4 of them then.
Do you need gaskets?
De Hill
Offline Elwyn Aud
Re: Fox 15
« Reply #9 on: January 29, 2009, 09:25:17 PM »
Hope to get out Saturday. The gaskets are still good.
Offline De Hill
Re: Fox 15
« Reply #10 on: January 29, 2009, 10:25:46 PM »
See you saturday.
Bring the engines!
De Hill
Offline dennis lipsett
Re: Fox 15
« Reply #11 on: January 30, 2009, 03:08:00 PM »
Elwyn,
It's usually better to replace the gaskets if you take the engine apart. Old fibre , paper, cork, gaskets
usually are compressed when used and don't as well if reused, The correct screwdriver is I believe a #1 phillips.Duke used to sell screwdrivers for his engines to deal with the complaints of stripped heads on the screws.
dennis
Offline Elwyn Aud
Re: Fox 15
« Reply #12 on: February 02, 2009, 10:58:42 PM »
This sure doesn't look right. I was going through a few Fox 15's the other day and noticed 2 of them had an exceptionally small inlet hole on the needle valve assembly. One of the 15's was an older one with a pressed in needle valve assembly and the other was a later model with a screwed in nva.  I don't think I've ever ran the ones with the small inlet hole but it sure looks incorrect. Here's a picture with normal looking inlet hole with one of the smaller holes.
Re: Fox 15
« Reply #13 on: February 03, 2009, 02:50:25 AM »
I've got a couple of both... I just assumed Fox machined them differently at some point.
Alan Hahn
Re: Fox 15
« Reply #14 on: February 03, 2009, 12:35:07 PM »
I think the small hole was special for the Fox15 hurl contest---it keeps the dirt clods out of the spraybar and the small hole doesn't interfere with the aerodynamics of a spinning Fox.
Actually it looks like they forgot a step in the machining process. That small hole represents the seating diameter, where the needle pokes through. Normally you would open up the hole on the fuel tube side. I know that because I made a few $100 spraybars with my mini lathe. y1
