General control line discussion => Open Forum => Topic started by: Bootlegger on October 01, 2020, 04:11:23 PM
Guy's I am looking for some line retainers that are used on the sig line reels. They appear to be about1/2" wide and go from side to side, to keep the lines on the spool, any help will be 'ppreciated..
Melvin Schutte at MBS 3025 Line Reel Clip - 2 ea. 1.50
http://mbsmodelsupply.com/Catalog.pdf
Lots of line related goodies. Good people, good prices, good service.
Bend up your own from metal strapping scrap. Easy to do. y1 Steve
Brodak's sells them too! Check out their web site FlyIn@Brodak.com.
Phil Spillman
I make my own lines reel. I use velco dots and velco straps to keep the lines tight on the reel.
Roger
I was looking for these, too, for the big reel. Every response to this question was good. Thanks, guys.
And obviously, SIG sells them separately also, for both widths of line reels.
A #64 rubber band and a piece of a flip flop.
First thanks to everybody for your replies, Dan I tried Sig and was told that they would call back, but they haven't yet, will try again...
Thanks again one, Bubba
Sullivan sellows the reel and clip for $5.14 cant beat that and no hassle of "building" a simple reel! http://sullivanproducts.com/product-category/control-line/page/2/
Lost count of how many line sets that the clip was too hard to remove or even put on the reel. So I in my miserly way drill holes through the side of the reels. A piece of wire through the line clips and the other end threaded through hole in reel. Loop wire through hole several times. So far have never had a set of lines come loose on the reel. D>K
I have found the best source has been to use a metal detector in the pit area of a contest after it is over. LL~
Seriously, I have gone to the rubber band already mentioned.
H^^ Guy's I found some, and have them on order. Thanks to everybody D>K
Mr. Roger,
Can you described be your construction method? It appears to be PVC pipe and plexiglass sheet.
TIA,
Jim in MS
