  • June 29, 2025, 12:04:26 PM
Author Topic: Evo 36 and LA .40  (Read 927 times)
Online Paul Taylor
Evo 36 and LA .40
« on: June 01, 2009, 07:59:41 AM »
Anyone know if the lug holes are the same?
Re: Evo 36 and LA .40
« Reply #1 on: June 01, 2009, 09:50:04 AM »
No, they are not.  The Evo is narrower across the case and the bolt holes are closer together for and aft.
          case   lateral    longitudinal
Evo       30     38        15               millimeters
LA40-46 32     40.5      17.5
the Evo is more a 25 size case punched out to a larger displacement.  It will just about drop in where an LA 25 was, except the bolt holes are .5 mm farther apart.(and it's 2.5 oz. heavier)
Willis Swindell
« Reply #2 on: June 01, 2009, 09:55:09 AM »
The lugs and shaft length are exactly the same as a Saito 40.
 Willis
Offline Bootlegger
« Reply #3 on: June 01, 2009, 10:24:09 AM »
   Also match an OS 32 SX to a tee...
8th Air Force Veteran
Gil Causey
AMA# 6964
