  • August 02, 2025, 10:04:27 PM
Author Topic: removing the blue  (Read 3037 times)
Offline Bootlegger
removing the blue
« on: November 03, 2018, 11:32:04 AM »
  Fellow's what is the best way that you have found to remove the blue from O S max L A engines?   Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Gerald Arana
Re: removing the blue
« Reply #1 on: November 03, 2018, 12:02:57 PM »
I have done several of them. First, I crock pot it in Prestone (aluminum friendly) anti freeze. Then I soak it in straight acetone.
With an acid brush cut down to 3/8" long (the bristles), I brush off as much as I can. I also use a bamboo skewer sharpened on one end and flattened on the other. Make it flat enough to go between the head fins, and sharp enough to go into the small space in "OS" on the head.
Use acetone!
Good luck, Jerry
« Reply #2 on: November 03, 2018, 02:28:22 PM »
  Have you tried ordinary paint remover or paint stripper?  If you have any pieces of a broken blue case, try a propane torck and see how hot you have to get it before the coating blisters. Keep the torch moving when you heat it, and heat it slowly at first to get it near operation temps. I don't like the blue color either (what was OS thinking!!! maybe just a blue head??" but don't know if it's worth the trouble to get it off.
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: November 03, 2018, 04:02:17 PM »
I did a couple with glass bead blast. Leaves a nice satin finish.
MAAC 8177
« Reply #4 on: November 03, 2018, 05:30:27 PM »
I paint all my engines...
Online Bill Ervin
« Reply #5 on: November 03, 2018, 05:32:07 PM »
Hi Gil, here’s one I did a couple years ago using the orange based eco paint stripper and a toothbrush.  It left a nice citrusy scent to the engine and breath.  When a club member asked why I would do such a thing I told him “ so the engine might regain some self respect”.
Offline George Albo
« Reply #6 on: November 03, 2018, 09:31:18 PM »
Bill would you post a picture of the product used or give the name of it?
Online Bill Ervin
« Reply #7 on: November 03, 2018, 09:43:55 PM »
You bet
« Reply #8 on: November 03, 2018, 09:55:50 PM »
If'n you don't like "OS Blue", try spraying with some yellow.
Yellow + blue = green
Green is a more pleasing color, anyway.
(might start a trend)
Offline George Albo
« Reply #9 on: November 04, 2018, 06:01:44 AM »
Offline Terrence Durrill
« Reply #10 on: November 04, 2018, 12:06:51 PM »
You guys have got it all wrong...........the best way to "remove the blue" is to VOTE 100% RED on Tuesday, November 06 !  We ain't tak'in no prisoners !  ...   y1
Offline Fredvon4
  • Central Texas
« Reply #11 on: November 04, 2018, 12:55:46 PM »
wat he said!
veto BETO!
Fred von Gortler IV
Offline Target
  • C/L Addict
« Reply #12 on: November 04, 2018, 01:22:55 PM »
I never realized my OS .46LA was democratic.....
Chris
AMA 5956
Online Bill Ervin
« Reply #13 on: November 04, 2018, 01:55:53 PM »
Giveaway number one is that it’s not just an O.S.46,  it’s an O.S. ”LA” 46.
Giveaway number two is it’s wearing blue fingernail polish...
« Reply #14 on: November 04, 2018, 02:24:44 PM »
I am with Floyd. Green is better.
« Reply #15 on: November 04, 2018, 02:40:46 PM »
I just crock potted mine. D>K
« Reply #16 on: November 04, 2018, 03:32:57 PM »
Allergic to blue Gil?  No pun intended.
Offline Target
  • C/L Addict
« Reply #17 on: November 04, 2018, 03:37:02 PM »
I live in the wrong metropolis!
Chris
AMA 5956
Offline Carl Cisneros
« Reply #18 on: November 04, 2018, 08:59:41 PM »
I use Hoppe's #9 and also their Gun Scrubber spray and an acid brush cut to about 3/8".
works great.
Carl R Cisneros, Dist IV
Control Line RB
« Reply #19 on: November 10, 2018, 09:11:08 PM »
I like it! You could paint it red. Somebody offered powder coated engines 10+ years ago, but I doubt the heat transfer would be as good as the enamel that OS used. I'm not a fan of anodizing for engines, because it tends to fade and any minor scratches look terrible. However, you can buy small powder coat kits from fishing tackle places, like Barlow's. H^^ Steve
Offline Dane Martin
  • heli pilot BHOR
« Reply #20 on: November 10, 2018, 09:14:54 PM »
Lol. Gil's blue LA 46 ain't a pretty blue la 46. Stripping it would be doing it a favor! But they come out very nice looking when stripped
Offline richardm
« Reply #21 on: November 10, 2018, 09:50:26 PM »
Or run it untill it turns black.................working on it
Richard Mc Fadden
Online M Spencer
« Reply #22 on: November 11, 2018, 04:20:16 PM »
This'd be Quicker .  ;D
Kal Guard ! is the Yoshimura GS 1000 military spec coating . Heat Dispersant ,
Some micro fibre finish to multiply the surface area .
Top of page 93  here : https://books.google.com.au/books?id=i8_7wR77B1UC&pg=RA4-PA93&lpg=RA4-PA93&dq=black+heat+dispersant+paint+.+yoshimura&source=bl&ots=5_Pc6of8zY&sig=QUhLA43uZ-NAIZhTJSuEEsOo0Cc&hl=en&sa=X&ved=2ahUKEwi7jpjCv83eAhVWFHIKHYDiCioQ6AEwE3oECAAQAQ#v=onepage&q=black%20heat%20dispersant%20paint%20.%20yoshimura&f=false
Offline Istvan Travnik
« Reply #23 on: November 11, 2018, 04:49:55 PM »
I do not know which oven grease remover is available in the States, but there are some strong, aggressive brands, containing 10-20% caustic potash (Potassium Hydroxide), surely. It removes anodized surface* of any color. Use rubber gloves and safety glasses!
After using rinse immediately with hot water, maybe with  some vinegar.
*it works on Castor oil's residues, too
« Reply #24 on: November 11, 2018, 05:19:09 PM »
Might work anyway...the OS LA engines are painted. It would be nice to know what kind of paint, but current info suggests enamel is likely.  H^^ Steve
Offline Bootlegger
« Reply #25 on: November 11, 2018, 07:37:34 PM »
   Dave T yes indeed I am VERY allergic to blue..  So be it..
Gil Causey
AMA# 6964
« Reply #26 on: November 11, 2018, 08:26:14 PM »
   It's an old plastic modeler's trick to use Easy Off Oven cleaner to take paint off of old car bodies and such for repainting. It takes the paint off, and does not harm the plastic. But it says right on the label not to let it come in contact with aluminum. It would really play heck with an engine crank case. This definitely wasn't one of OS's best ideas. If the engines didn't work so well, it would only make them easier to ignore!
