  • June 27, 2025, 08:58:56 AM
Author Topic: Stevens Aeromodel spool up stooge  (Read 1210 times)
Offline YakNine
« on: February 27, 2012, 06:39:11 PM »
I saw this thing on you tube it looked pretty neat. T.J.
AMA 85135        GSCB
Re: Stevens Aeromodel spool up stooge
« Reply #1 on: February 27, 2012, 07:00:09 PM »
I have heard of something like this in the past. My only concern with something like this is you can not raise your arm and raise the lines if you are flying off grass.
I like to do this right before a launch to try and prevent a line snag.
Here is the link...
« Reply #2 on: February 27, 2012, 08:47:50 PM »
meh..... we used to do the same thing using a tetherball pole at the local schoolyard.
(edit: pole, not poll. oops.)
« Last Edit: February 28, 2012, 07:26:03 PM by Clint Ormosen »
« Reply #3 on: February 28, 2012, 08:16:08 AM »
That stooge will work with IC engines also. H^^
Offline richardhfcl
  • AMA 82448
« Reply #4 on: February 28, 2012, 08:45:47 AM »
Gents,
     The local version of this launch at Ned Brown Woods is accomplished with a 55 gal. trash barrel to function as the pivot point.
Two out of three launches are successful.
Richard Ferrell
AMA 82448
