  • June 20, 2025, 06:54:19 AM
Author Topic: Reinventing the wheel  (Read 2676 times)
Offline Ara Dedekian
  • Ara Dedekian
« on: September 30, 2016, 10:17:24 AM »
       My wife made me do it!
Offline Randy A. Dailey
Re: Reinventing the wheel
« Reply #1 on: September 30, 2016, 12:09:36 PM »
What a great Idea!!!!!!!!!!
     Thanks for the Post, Randy
Dwayne
« Reply #2 on: September 30, 2016, 03:44:49 PM »
DITTO, What a great idea!!
 H^^ H^^ H^^
Offline Brent Williams
« Reply #3 on: September 30, 2016, 04:15:34 PM »
Good use of space!  Run a strip of the aluminum on both sides of the beam and you will have an automatic stagger to the planes.  This might give a little bit of extra space for the vertical fin.
Offline Russell Shaffer
« Reply #4 on: September 30, 2016, 04:49:20 PM »
And they all seem to have engines mounted!!!  Great job.
Russell Shaffer
Klamath Falls, Oregon
« Reply #5 on: September 30, 2016, 08:51:56 PM »
Is that the attic?
Oh-oh!
Drip...drip...drip...
"Hey honey, did you notice those spots on the living room ceiling?  I wonder what they're from?"
 ;D
« Reply #6 on: September 30, 2016, 08:59:07 PM »
 C/L genius. y1
« Reply #7 on: September 30, 2016, 09:01:28 PM »
Wot About The DROPPINGS .  S?P mw~
  • Ara Dedekian
« Reply #8 on: September 30, 2016, 10:19:05 PM »
« Reply #9 on: October 01, 2016, 07:56:29 AM »
Talk about smart airplanes!  Not one of them opened the paper to the comics section!
« Reply #10 on: October 01, 2016, 08:36:26 PM »
Hope there's plastic under the paper.   I try to wrap my engines with shop towels..
  • Ara Dedekian
« Reply #11 on: October 05, 2016, 10:51:13 AM »
Is that the attic?
       Nope. The garage loft.
Oh-oh!
       Not to worry. Forty two years ago, my wife, after learning of the existence of model airplanes, issued an edict: "The house is my space, the garage and cellar is yours". We've been peacefully coexisting ever since.
      Ara
Offline Fredvon4
  • Central Texas
« Reply #12 on: October 05, 2016, 11:42:56 AM »
My only concern (from experience) is if or if not the garage loft if heated or cooled...I suppose in Maine, the cooling is not too critical but I highly suspect winter extremes in the LOFT
I have ample attic storage here for my ever increasing fleet, but due to the temp extremes would not consider ever hanging my hard work in a 160-F or near zero-F environment
As it is, we had to suck up the cost of electricity for my Building barn/shop to cool ME to a comfortable 80 in the summer (105-F outside). And at least 60F in the winter ( 25-F~45-F typical)... supplies, paints, glues, balsa stock, kits to consider---but more importantly I got cheap fluorescent lights that do not fire and run without flicker in the sub 60F range...Yes there are better options and ballasts or even now LED fixtures ---but my 7 each  8' two tube fixtures are still providing good light as long as I do not try to light them at 40~50F indoor temp
MY dad did a very similar rafter set of plane hangers, but using 3 inch W x 4 foot L strips of Peg board nailed to the 2x4s
Fred von Gortler IV
« Reply #13 on: October 05, 2016, 11:44:46 AM »
for some reason I dont really have a fleet of airplanes to worry about hanging?
Offline Pat Chewning
« Reply #14 on: October 05, 2016, 03:28:40 PM »
These lines are for raising and lowering my kayaks to the garage ceiling and they come in handy for storing planes.  I rotate the prop through the lines.
« Reply #15 on: October 05, 2016, 06:25:46 PM »
So Mark, what's the correct stunt saying for this situation: "If you have a fleet of stunt-ships you are not pulling out low enough...."
I guess on the other hand, if you only have one or two, maybe pull out a little higher?   :D
