  • June 23, 2025, 01:05:58 AM
Author Topic: A couple of shots of the bones of my new ship.  (Read 1458 times)
Offline charlie
« on: January 27, 2009, 04:59:40 AM »
It is 680 square inches for Merco .61.  It is ready for covering and weighs 43 ounces with all the bits bolted in.
Charlie Stone  (The West Australian one)
Re: A couple of shots of the bones of my new ship.
« Reply #1 on: January 27, 2009, 07:15:00 AM »
Looks good Charlie!!!!
« Reply #2 on: January 27, 2009, 07:57:35 AM »
Ship looks good.  More details, like, is that a Geo-Bolt wing?  Those truss type wings are stiff, aren't they!  Keep us posted.  DOC Holliday
« Reply #3 on: January 27, 2009, 08:00:11 AM »
That's right purty! ;D
Offline Bradley Walker
    • The Urban Rifleman
« Reply #4 on: January 27, 2009, 08:11:43 AM »
That should turn a little!!! ;D
-George Bernard Shaw
Offline charlie
« Reply #5 on: January 27, 2009, 08:37:29 AM »
No Doc, it isn't a Geobolt wing.  Just a sort of home brew of my own built on a lost foam fixture that I made a few years back.
« Reply #6 on: January 27, 2009, 02:29:21 PM »
That looks really nice, Charlie. Can you give a closeup of the rudder attachment. That looks really sweet.
Offline charlie
« Reply #7 on: January 27, 2009, 04:52:22 PM »
Hi Randy, There is no separate rudders.  The two fins just slide on to the ends of the stabiliser and get glued (hopefully) straight with no offset intended.  The elevator is in one piece and consequently has to be a bit shorter than the stabiliser to fit between them.  There is a minimal gap between the elevator and the fins.  The photo may help you I hope.  The attachment is just 2 parallel 1/16th" ribs spaced to suit the stabiliser thickness with 1/16th support strips on edge above and below those ribs.  The fins have outlines laminated from 6 layers of 1/16th" steamed around a former and glued with aliphatic.  They weigh about 7 1/2 grams each.
« Reply #8 on: January 28, 2009, 11:48:30 AM »
Thanks, Charlie. Looks good.
