Gil,
On NEW abc/abn type engines I have sometimes used a heat gun to warm the top of the cylinder and head a bit before the first start. This causes the liner to expand away from the piston a bit to make the first few flips easier than when cold.
It is very important to not turn the engine over when it is new and cold---serious wear usually results. At this point, I would suggest that you flush out the cylinder to be certain that no very tiny metal particles are present, then attempt to start the engine. Maybe it will be OK; if not, new piston/liner sets area vailable from Tower.
If you must remove the liner from the case, try very hard to reinstall the liner exactly as it was to match up the liner/piston wear areas.
Not mentioned very often, there is a "GOTCHA" with break in of ABC/ABN engines. To avoid damage to the rod, it is necessary to have enough fuel flowing through the case for good lube and heat removal. To avoid damage to the piston/liner, it is necessary to get the top end up to operating temp very quickly. This is usually done by running a fairly light prop load (to help protect the bottom end) at a slightly rich two stroke mixture setting to help get the top end up to temp quickly. I usually use the same fuel that I plan to fly on........with a prop one inch shorter and or one inch less pitch than normal.
The OS La engines and the Brodak 25 and Brodak 40 can be difficult to start the first few times because thay are fitted so tight. Using the heat gun will help, as will being very careful to not get them flooded.
Probably more than you wanted to know........
Cheers,
Jim
