The original Red Baron met its demise in May of 2001.
I was using it as a test bed for various 4-stroke engines.
At the bottom of the hourglass, the wings folded and it went straight in on asphalt, totalling both the plane and a brand new SAITO 80.
Turns out, the plane had gone through a number of owners. When a hard landing cracked the main spar(s), instead of fixing it properly, the then owner simply made epoxy fillets at the wing/fuselage interface.
The engine suffered a broken case, broken backplate, bent rod, bent crank, smashed valve cover and broken carb.
You can see the results. It was, by the way, a terrific flying aircraft. I flew it with an OS 52, ENYA 53, SAITO 72 and SAITO 80.
It weighed in the neighborhood of 80 ounces and the absolute best flights were with the ENYA 53.
