  • July 14, 2025, 12:31:40 PM
Author Topic: Recommended elevator throw for 48 1)2" wing magician without flaps?  (Read 411 times)
Offline Matt Curtis
What is a correct throw for this plane? Will flying it with flaps make it fly way better or not really?
Re: Recommended elevator throw for 48 1)2" wing magician without flaps?
« Reply #1 on: July 08, 2025, 09:01:46 AM »
  If the airplane is straight and balanced correctly, there is no need for anything more than 30 to 35 degrees, and most of that would never get used, but may help you psychologically. Search out threads on the Magician and I think you will find about a 50-50 consensus on whether to install flaps on it airplane or not.  Leaving them off will simplify construction and flight trimming. I have an example of each version of the kit and if I ever get around to building one, I will leave them off. For the average "Joe Bellcrank" it will fly very well for them without flaps. If I would change anything, I would make the stab/elevators thicker, just because 1/8" looks too darn flimsy!!
     ( Fixed it!)
« Last Edit: July 08, 2025, 02:22:53 PM by Dan McEntee »
« Reply #2 on: July 08, 2025, 09:36:09 AM »
I had it both ways.  I originally built it w/o flaps then added them later.  I was what today would be a low-end advanced flier and the only difference I saw was in the corners.  Not tighter just better and not really worth the effort.  Control throw per Dan is good but I would not try and get 354.  350 should be enough.  LL~
Aw, he fixed it.  Now nobody knows what I am talking about, which is most of the time.  H^^
« Last Edit: July 08, 2025, 07:29:46 PM by Ken Culbertson »
Online Ty Marcucci
« Reply #3 on: July 08, 2025, 04:34:05 PM »
Since 1969 I have built and flown 9 Magicians.. On only one did I use movable flaps and it was a disaster.. Not sure what I did wrong, but it made it through 2 flights then BLAM.  I over controlled it.. But then I didn't know what I was doing back then either, so FWIW. LL~
Do as Dan suggests. I know that works. In fact I have three under construction right now  out in my shop and ALL have thicker stabs.
Ty Marcucci
« Reply #4 on: July 08, 2025, 08:38:24 PM »
   When I got started flying stunt in the Beginner class and through Intermediate back in the late 1980's, the Magician was the favorite of a lot of people at that time, but they were usually modified a bit by moving the stabilizer back to the end of the fuselage and I think most used flaps also. This may have made a difference in how the airplane responds to flap inputs. If I were to try flaps, I would probably move the stab back like it was done back then, and I would make the flap throw less than the elevator. But then it wouldn't be a Magician any more!! No longer legal for Classic competition, but still a good sport stunt airplane.
« Reply #5 on: July 09, 2025, 12:00:50 AM »
Unless the Classic rules have changed recently, there's nothing in there that allows anybody to DQ a model (pilot, yes!) for moving the stabilizer back or enlarging the horizontal tail. Throw an aluminum LG on there, too! I wouldn't make the flaps functional unless I did move the stabilizer back. That goes for the elevators, too.  :## Steve
« Reply #6 on: July 09, 2025, 09:51:26 PM »
Obviously the extra mechanisms would weigh something , so lighter unflapped .
You want no binding , a decent bellcrank instalation , etc.
Maybe the handle to elevator bits more important . Being able to somersault needs a bit off movement .
Rchened up , so aerobatic planes will do the Bi-Slob trick , if thats your thing , getting 45 deg. would be good .
Setting normally so full whack on he wrist gets you 25 Deg. or whatever .
Offline Gary Dowler
« Reply #7 on: July 12, 2025, 07:34:50 AM »
Less that you think.  If you have equal travel of 30 degrees each way, you have more than you need.  In reality we almost never use more than 20 deg in flight in any maneuver.
Gary
