  • July 17, 2025, 03:37:53 AM
Author Topic: Rebel Rally - Nov. 11 & 12th - Starke, FL General Combat Info  (Read 876 times)
Offline howard shenton
« on: November 02, 2006, 05:09:01 PM »
Southeast Combat Fliers
Bill Duane asked me to help, run / fly, combat, at this years Rebel
Rally to which I agreed (Humm senior moment).
Speed Limit - 1/2a and - Fast Combat are planned so bring everything.
In order to speed up registration I will have pre-printed
registration sheets, for each event, prepared for each contestant
which will have your AMA#, Name, Address, Tel.# and email
information. All you need to do is check/update the info.and show
your 2006 AMA card. Please let Bill or me know if you plan to attend
and what event(s) you plan to fly in.
All combat events will be flown using either Double or Triple
elimination formats,
This means you must lose 2 or 3 times before being eliminated from
placing first.
1/2a will be run by the current AMA High Performance rules rules with
the exception of allowing Norvel .061's to be used. .012 dia. 42ft +/-
3in lines & starters OK.
Fast will be run by the current AMA rules.
Speed Limit will use slow rules with the following exceptions:
Speed: 74.99mph (Timed at 6.86sec for two laps)
ANY: engine, aircraft, fuel system
Starters OK
Midair will not end match
.018 dia lines 60' */- 6"
Howard Shenton
Mauldin, SC
Howard Shenton AMA 83412
Mauldin, SC 29662
Re: Rebel Rally - Nov. 11 & 12th - Starke, FL General Combat Info
« Reply #1 on: November 07, 2006, 01:11:03 PM »
4 more days.
Mauldin, SC 29662
