I have only used the 5mm silk from Dharma. It is a very tight weave, so does not take as much dope to fill as the old model silk. I thin the first few coats of high shrink dope about 60%. That lets you put on very thin coats that will not run through and puddle, but if they do, it will not leave a blob when dry. It will fill with around three coats of this thin dope. After that run through is not a problem. On open structures it does need to be pulled very tight while very damp. Even then it will sometimes wrinkle after the first few coats of high shrink dope, but will shrink out with a little dry time. I still use good quality camel hair brushes as they seem to work the best for me with dope. Silk does go around wing tips and compound curves much easier than about any other covering I can think of, and seems to finish lighter for me than med. silkspan.
