General control line discussion => Open Forum => Topic started by: Paul Taylor on November 03, 2012, 04:14:49 PM
Going to see the movie "Flight" tonight. On the trailer it shows what looks like a 727 flying inverted.
Is this just Hollywood or can it be done?
You can try it if you like. I just don't want to be in it.
F.C.
It wouldn't be exactly like and Extra or a Pitts Special, but I imagine it all depends on the nut at the wheel! y1. If you google it, I'm sure you can come up with the video of Tex Johnson rolling the prototype Boeing 707 at an air and water show in Seattle in the late 50's or early 60's. I saw an episode of an aviation program years ago where a British pilot tells of rolling a Concord at high speed. He was on a check flight and said something to his instructor about rolling it, so the instructor did so. Then he told him, "there, I wound it up, now you unwind it the other way!" If done correctly you don't even pull more than one G. Chris McMillin has a lot of time in 727s and if he sees this maybe he'll offer an experienced opinion.
Like Dan said. With the right pilot at the yoke and done properly, about most any aircraft could be rolled. Extended inverted flight would be restricted to a lack of an inverted oil and fuel systems...Oh Yeah! and the FAA.
BTW, during my years on the B-52, there was a "strong" rumor about a B-52D being rolled very nicely. :o
Norm
As noted, you could probably Slow Roll a 727, but extended inverted flight would be a computer-generated image by Hollywood. (Factual answers would come from Fancher, Fitzgerald, McMillin, Gleason, et al.)
Oh, you could do it, the question would be for how long! :##
Fuel and oil systems and flight control systems aside, sustained inverted is a negative G maneuver, whereas a barrel roll maintains positive G's. I don't know how many negative G's the airframe is designed for, but I suspect inverted flight was not within the design envelope!
Well just got back from the movie......
Spoiler Alert!!!!
He roll it in a vertical dive then pushed the nose up to inverted to get level flight. And yes the oil systems went out killing the engines.
Then rolled it back over.
Movie is so-so
...He roll it in a vertical dive then pushed the nose up to inverted to get level flight. And yes the oil systems went out killing the engines.
Then rolled it back over. . .
Again, that's Hollywood and CGI. As noted above, the real answer will come from those who've actually flown the B-727. Ted? Dave? Dale? Chris? Al? Will you folks put this one to rest?
Real Fact: Boeing's test pilot rolled 707 twice.
First thing, the movie aircraft IS NOT a Boeing 727! Geesh, it only has two engines.
It is a McDonnell Douglas MD-80 or a DC-9-50.
The Airline I work for can't even give them away, their being sold for scrap (MD-80's).
As far as rolling 727, you need to ask a couple of TWA pilots that one. It's an Airline legend - TWA Flight 841
. . . an Airline legend - TWA Flight 841
Wasn't that the late Capt. John Testrake? Didn't know he'd rolled the thing.
Did you see the RC 727 crash last night?
What a Mickey Mouse operation.! Flying a 727 from a Cessna Skymaster with a chincy toy RC transmitter. They missed the target by a mile. Lucky not to kill a lot of people. At least they did it in Mexico, not the USA. They could have stopped by any RC model field anywhere and picked up ten better pilots.
From the web:
According to producers Steve Starkey and Jack Rapke (during a Q&A session with the Producers' Guild on October 18th, 2012), the primary airplane in the film is a pastiche of several existing commercial airliners so as to not ID a particular plane or airline in the film.
Yea was not real sure of the model of plane it was I always thought that the 727 just has two engines on the tail of the fuse.
Well the movie was mostly about his drinking problem.
Sorry another spoiler alert. <=
Roll control on some of the biggies is all or partially via spoilers, not ailerons. So I'm pretty sure that it would only work with positive lift.
Waiting for someone who knows for sure to get on board...
What Mickey Mouse operation.! Flying a 727 from a Cessna Skymaster with a chincy toy RC transmitter. They missed the target by a mile. Lucky not to kill a lot of people. At least they did it in Mexico, not the USA. They could have stopped by any RC model field anywhere and picked up ten better pilots.
Yeah, I watched this documentary. They had gotten permits and licenses to set up the plane for crashing. The work they put into testing the controls and setting up he crash dummies was a lot of work. Problem was having a chase plane fast enough to stay with the big bird. They thought they had one until the last day when trouble with the chase plane that was fast enough had trouble . They went ahead with the first chase plane and almost made it to the planned runway when the big plane went down early. They got a lot of crash data out of that crash that coul not e duplicated with computors until this data was all collected. Great peice of documetary and a lot of safety procedure followed. Yes, it was done in Mexico as it was the only place they could get permission.
Arthur Godfrey Of TV and Radio Fame is said to have rolled an Air Force B-47. Does anyone remember that? Maybe it was a loop?
http://en.wikipedia.org/wiki/TWA_Flight_841_(1979)
not the same hoot gibson as astronaut fame
727 had 3 engines in / on the aft fuselage. center engine had a big S shaped air inlet duct that routed air to its position between the 2 nacelle engines. look at the 727 from straight behind and you see 3 exhaust in a row.
Flight spoliers supplement the ailerons. Ex: RH bank - The left aileron goes down and the right spoilers go up to "spoil the lift".
It was just a repeat of what was done at Edwards decades ago. NASA or FAA did a bunch of crash tests. I think the big one was a 707. They sort of had the same results. Very hard to control that large an airplane remotely with any kind of precision. That crash currently is used as the lead in for some show I don't remember which one.
Just found this link, it was a 720.
http://www.youtube.com/watch?v=-TrOA9WiUWs
I guess one could calculate whether the control authority and structure would suffice to pull out of a vertical dive upside down. I don't remember seeing any flight test data on it. It probably wouldn't be a pilot's first choice of which direction to go.
Sounds like a big bunch of Negative G.. No way Hosea :)
I have a friend who was a B-47 pilot. He said" the plane was very high performance for its day and could out run most fighters in the early 1950's.This got many pilots in trouble as they tried many things outside the normal flight envelope. One maneuver that they practice was to come in very fast and pull up and launch a atomic bomb. Several planes had the wings come off right at the center of the fuselage. He knew of several that rolled and didn't do any damage. The wings were so flexable that they had aileron reversal above 325 MPH ~^
Rolling a plane is not the same as flying inverted. As has been mentioned the fuel pick up in most if not all commercial airplanes are designed for positive G on the fuel tanks the engines would flame out fairly soon on sustained inverted flight. It's why we put clunk pickups in our R/C fuel tanks. Now with respect to a roll as long as it is a barrel roll to maintain positive G's on the fuel system it can and has been done. The original prototype for the Boeing 707 was rolled right in from of a delegation of Air Force reps when Boeing was trying to sell the plane for air to air refueling. It later became the KC-135. The Boeing test pilot was nearly fired by the CEO of Boeing, but the guy was so good and the Air Force was so impressed that he kept his job and the Air Force bought the plane.
LL~ LL~ LL~ LL~ LL~
ED,
I have been researching Mr. Godfrey on the net. I found out that he did indeed have lots of US NAVY pilot ratings. He also was in The Air Force reserve and had flown every aircraft the Air Force had at that time. There was no mention of the B-47 nor any maneuvers he did.
I knew a B-47 pilot also, and he told me how they flew out of Europe and over Russia for the purpose of spying. They did this with out fear of being shot down because the RB-47 could fly high and was to fast for the Russians to catch it.
If it is not on youtube, it didn't happen... OK:
http://www.youtube.com/watch?v=-KNbKFMBsQE
or a slightly longer one:
http://www.youtube.com/watch?v=AaA7kPfC5Hk
ED,
If I am the Ed you are referring to I never mentioned Mr Godfrey??? I was referring to Phil Bayly I have his signature in my B-47 book . He was in the 15 AF 43rd BW 63 rd BS Davis Monthan AFB AZ We are still good friends. He is a long time CL flyer. He should be at the KOI this year.
ED,
... I knew a B-47 pilot also, and he told me how they flew out of Europe and over Russia for the purpose of spying. They did this with out fear of being shot down because the RB-47 could fly high and was to fast for the Russians to catch it.
That worked good until the MiG 17 got the afterburning engine. Once a few RB-47s came back shot up, they stopped overflights until the U-2 came online.
Here is a page out of the B-47 book telling about the A bomb launch. The 47 would pull up in to a half loop and roll out. Not mentioned here but some would do several rolls keeping at least one G on the internals so every thing kept operating. It does mention the planes coming apart at the top of the loop.
My dad was CO of an army base in VA in the mid 60's. The base had among other things a bombing range used by TAC. I used to watch TAC F-84s, B-57s, etc practice the "over the shoulder" or "toss bombing". Three quarter loop followed by roll out. Shoulder or toss depended on the release point and angle. I could see them zooming up from a classroom of the high school I was in. I never saw a B-47 but I know they practiced doing it but not at that range. It was a nuclear bombing technique to allow the delivering airplane to flee the scene before the nuke went off. The bomb had to go way up before turning back and impacting. Although there were many hits on the target pylon from the practice bombs there was a report to the base of impacts seven miles from the target in an adjacent farm. Three 25 lb practice bombs in the same field. Apparently the pilot did toss deliveries but the mechanism was set for over the shoulder. Accurate but slightly off target!
Tex Johnston was a regular visitor to the Boeing Wind Tunnel...and was a very close personal friend of T.A Wilson who in his early career before becoming President and CEO of The BOEING COMPANY was a gifted design engineer.
Both TEX and TA WILSON would often...unannounced.... drop by our model shop just to see what was being built on the work tables...
Here is a shot that I took one morning (after working through the night on this "drop dead deadline" flutter model shown in the foreground with my "borrowed" shop camera with my hard overtime working partners in crime.
In truth...
Tex often shared many stories about special flying projects not only on his famously imfamous barrell roll. Here is a photo that Tex signed for me and my son at one of our annual wind tunnel Christmas party open houses.
Later on....I was asked to work wo with the Tex and the Boeing Archives...enhancing some of his old photographs before his Book was published.
Here is one of favorites..that was on the back of his book. To meet a deadline for the publisher I had to "airbrush out a couple of helments with my IWATA HPC because they contained the names of other test pilots. Also carefully masked off his image and covered over other distracting shop supplies etc...so that his image would STAND OUT!
REMEMBER....THIS WAS THE AGE BEFORE "PHOTO SHOP!" n~ H^^
Shot of Shultzie's airbrushed enhanced photo for Tex Johnston books back cover photo...and a photo of an article that Tex and the Archives gave me for helping them meet the book publishers dead line that ended up in a 2010 newpaper article.
Here is the video of the Dash-80,,707 doing the roll
Thanks Ed...
For sharing this video of Tex
He was truly one of the most amazingly gifted Boeing Test Pilots...in which they are many over the years. Although I have posted many times about another equally famous Boeing Test Pilot....one can not help but mention (Again and again for me) was the amazing Lew Wallick Jr. who tested soooo many airplanes and was still employed when I first began a new career as a wind tunnel flutter modelmaker in the early 70's.
He was heavily involved with the 727 program from the beginning...later 737-the first 747 757-767 and preflight programming for the 777 simulation studies.
He was so well known for his love for flying that beautifully restored old Boeing P-12 Biplane that he kept at the Boeing Flight Center Building and so often flew it during lunch (minutes--often turned in lunch hours) where we would gather on the roof tops of the Boeing Wind tunnel facility...and watch Lew demo that great little airplane for everyone...including the near by I-5 freeway...which then would often come to a traffic standstill during those performances.
He has crossed over...and sure a shootin' I would bet he is at peace...flying daily...where the angels fly...between the earth n' sky.
Here is a couple of attached photos of Lew with that amazing little Bi Plane.
I was lucky enough to talk with Lew many times during my career...and also attached is my old recognition poster that was set up at The 4 Seasons and then all around the various local Boeing programs for border signing.
After he retired he spent so much time flying his seaplanes up into the high mountain lake for fly fishing. He too was an avid ski bum and loves HIGH PLACES!
LONG LIVE HIS MEMORY! HE HAS BEEN SORELY MISSED BY SOOOO MANY!
No Ed I was not saying that you mentioned Mr Godfrey. Phil Bayley is an old friend of mine. So I know more than one ex B-47 pilots. This is am interesting subject.
Exactly...there is a derelict 727 sitting on the ramp at Chino Airport here in So Cal that is still all together & there are definitely 3 engines. The DC-9 had two engines on the sides of the rear fuselage.
I was debating wether to post a link to your response but considering this thread is going off in several tangents, here is the NTSB report on the incident. Yes, the pilot rolled it.
http://www.airdisaster.com/reports/ntsb/AAR81-08.pdf
Very simply there was an unauthorized configuration back in the day used to increase cruise speed of a 727 by extending the flaps electrically (backup to hyd.) to increase the wings chord span (Flaps move aft then down progressively) This necessitated a slight nose down trim which would fair the fuse with the airstream for an increase in airspeed without touching the throttles.
Thing is, one of the req. to accomplish this is to pull the leading edge slat motor circuit breaker to prevent deployment of the leading edges. This happened while the F/E was on a Lav. break, he came back in the cockpit and saw the breaker out and pushed it in not realizing that the Captain had extended the flaps slightly with the switches (Not the handle). This activated the standby hydraulic pump which pressurized the L/E hyd. motor and the slats deployed...#7 separated an all hell broke loose.
I remember my co-workers at Eastern duplicated this senario during a gear swing in the early 80's by putting the plane in "in flight" on jacks.
I have 19 years Overhaul experience on that jet - still miss it, it was a damn good Airliner.
SPEAKING OF GOING OFF TANGETS.... LL~ LL~ LL~ H^^
Regardless FLIGHT the movie is worth seeing. Quite entertaining with some pretty good morality sense themes thrown in~
My guess that plane might have been an old MD-80 series? DK^
I was doing quite a bit of business traveling at the time the 727 went into service and there were three crashes that came quite close together. All three were said to be pilot caused. I flew on the original smaller version before the fuselage extension.
Captain Hoot Gibson and the 727; They didn't roll, it had an autopilot malfunction at max altitude and rolled off to around 110 degrees and the nose went down to 70 degrees. They couldn't disconnect the autopilot using any of the usual means and the airplane exceeded Mach 1. At this point they were getting low and fast and put the gear down in an attempt to slow the airplane, at this point the gear doors and gear actuators tore off from air loads and this evacuated both hydraulic systems, this disconnected the auto pilot. Hoot landed the airplane and it was a heavy 727-100 that was a popular airplane for freighters and it was later bought by fed Ex and up until the late 90's was still operated by them.
The trial of the crew was not over as American, United and TWA as operators as well as Boeing and the autopilot manufacturer (can't remember who it was) had a lot of dough at stake and the crew is the best entity to blame it on, even though the airplane had a history of difficulty in autopilot disconnecting (which was very uncharacteristic in my much later experience in the airplane, it'd disconnect by snapping the wheel mounted chart holder hard) so the Flight Engineer was targeted to testify that he re-entered the cockpit after a rest room visit and found all of the slat and leading edge flap circuit breakers pulled. Seeing this he was told to say he reset them all without telling the Captain or FO. The story being that the Captain and FO pulled them in his absense, selected flaps 2, which would move the fowler flaps rearward only and increase the wing area enough to allow a higher altitude in cruise flight thus enabling a non-stop flight to destination westbound into the prevailing westerly winds. This was known as the "west coast technique" by American Airlines crews, but no one at TWA I knew had done it, or ever knew anyone that did do it.
The Fight Engineer quit after the hearings, the FO never upgraded to Captain before he retired early and the Captain was a colorful character and he did retire as an International Captain.
The crew was hung out to dry by the industry.
Chris...
P.S. I just read the Wiki article, it describes a lot of the intrigue involved, but the two rolls is in direct opposition of my training about it at TWA and my father and Hoot's stories. Hoot did say the airplane rolled in the TV Hearing and since then the instructions by all pilot unions is to NEVER make a public statement and they protect the pilots from such a circus by threat of legal action against the airlines. Works like a charm, no BS statements under stress, etc.
John was the Captain of the 1985 Beruit hijacking where a Navy SEAL was killed. The airplane number was 4339, I used to fly it all of the time.
Chris...
Yeah,
Chip Shanle, the principle in the operation on the show, is an American Airlines FO that which I have had the pleasure of him flying for me on a dozen occasions (including his very able assistance when we flew through a crop pf migrating ducks climbing out of DFW taking out our radome and several going down the intake of the left engine and returned to base making an emergency landing one fine fall morning). He is an Air Force experienced pilot, flying F-4's among other fighters. He and a team of learned men developed the operation for the crash scenario over a number of years. He was the pilot flying the 727 with the "toy" Spectrum transmitter. (Actually it's a well respected R/C unit.) It was done in an empty Mexican desert and the target area was a "nice to hit" option.
Mr. Smith is an opinionated person for sure, but in this case is completely out of his depth commenting at all about said operation, let alone speaking of a pilots abilities. Regardless of Mr. Smith's posted comments, for those that haven't seen the show, no one was hurt. Let alone killed.
Just another of his typical troll-like antics.
Chris...
As I stated earlier, I have seen the documentary and it was very well done. They followed all the safety practices they knew about. It is also why they chose the site they did. The crash airplane was under control of a pilot and co-pilot, minimum crew, until they got within a certain range of the target area. A simulated airstrip carved out of the Mexican desert. If the pilot and co-pilot had stayed with the plane a little longer, it would have made the target. Too bad they had to have trouble with the chase plane that could keep up with the big plane.
Chris...
Yep, I confused the flight numbers. John Testrake (a real hero) was Capt. of TW 847, not 841.
Balderdash.
<snip> Captain Hoot Gibson and the 727; ~ Hoot did say the airplane rolled in the TV Hearing and since then the instructions by all pilot unions is to NEVER make a public statement and they protect the pilots from such a circus by threat of legal action against the airlines. Works like a charm, no BS statements under stress, etc.
Chris, I was just repeating what was told to me 30 yrs ago, but it is plausable. I realize the truth is there somewhere. The Flight Data recorders of the age were lacking in data collection compared to today. One of the mods I've done over the years is adding sensors to the MD-80 series to bring them into compliance. Today's FAA is staffed with alot of former Airline Pilots who bump heads with the NTSB over flight safety data and who controls it.
The Airline I currently work for overhauled FedEx 727's in the mid/late 90's, so I probably worked on that airframe. I know I came across some ex-EAL "Shorties" in FedEx livery on that line. Geesh, we (EAL) got rid of them in 1984, they were in rough shape with high cycles back then.
Balderdash.
Howard!!!! H^^
I JUST LOVE THAT WORD "BALDERDASH!" LL~ LL~ LL~ LL~ DV^^
Balderdash.
Said by one of those protected by the crew's being blamed.
You may have, Doug! EAL had a bunch of DC-9-50's that TWA leased from Guiness-Peat or someone in the late 90's, they were a mess too.
I didn't participate in the investigation, but I heard about it from those who did. It was pretty much a slam dunk, even with the voice recorder erasure.
Howard,
Please drop it, it's personal for me.
Chris...
Not a slow roll, Mike but, as Tex has shown dramatically, a barrel roll done properly is a one G maneuver all the way around and so the relationship of the CG, and the required download on the tail never changes.
Older Boeing airplanes require a significant download on the tail to stabilize their more forward Center of Gravity. The slower they go (for a given flap setting) the more "nose up" trim has to be applied...in this case by lowering the leading edge of the horizontal stabilizer and producing downward (negative) lift of the tail to hold the nose up.
As I understand it, later model Airbuses are design to fly with further aft trim requiring little or (perhaps) no download on the tail in an ideal state (pax and fuel in the "ideal spread" fore and aft). It is probably conceivable that such a ship could be flown in one g inverted flight although if the tail could drive the wing to a positive angle of attack while inverted (consider the cambered airfoil's need to be pitched "up" relative to the airflow to produce lift when inverted).
It is highly unlikely (although Mr. Rush will correct me if I'm too far out on a limb) that any Boeing with which I'm familiar could be driven to a high enough angle of attach when inverted to maintain level flight.
Whoever mentioned fuel feed is pretty much on the money. The fuel pumps and pickups are located in the lower portions of the tanks and sustained inverted flight...if aerodynamically possible...would be a short lived exercise.
Ted
Bill,
Inverted flight is a one G maneuver and air carrier aircraft are certified to well beyond that. Minus three or so sounds sort of familiar but my books are all at work. Shoot. I might have "experienced" a couple of 2g (at a minimum) landings in my career! One of which was in a 727. By the way. I've only seen a quick glance at that trailer once and my visual memory was more like a DC-9 or MD-80. Not at all sure.
Ted
I'd agree 100% Dan. Again, it "may" be possible to stop a barrel roll while inverted and apply enough down elevator to keep the nose from dropping at 1g but there just doesn't seem to me to be anyway to pull out of a steep dive inverted without exceeding: A. the control forces (lift) necessary to do so or, B the negative g limits of the structure if there was enough control authority.
Again, I find it unlikely that sustained inverted flight even with the power sticking around somehow would be possible given the range of trim adjustments available in the stabilizer and the normal CG range against which the tail would need to work to hold the nose up.
Ted
p.s. My guess is that the engines would fail due to lack of fuel long before lubrication became an issue. Not so, necessarily with a recip but jets aren't nearly as susceptible to rapid disassembly due to reduced levels of lubrication.
Whoops...semantics there, Ted. I meant to say 'barrel' roll, not 'slow' roll.
That said, I still wish you'd consider writing a book about your experiences....everything from coastal runs with the CV-440 to the Dash-400 finale. So many of us ground-bound 'wannabes' enjoy those tales. Case-in-point being Len Morgan's "View From The Cockpit" (Sunflower University Press, June 1985).
We'd love to hear more, if only you would.
Cheers....
Cheers....
Thanks for the suggestion, MIke, but.... I'm afraid you'd find my 38 years at the helm (or close to it) pretty boring. Which is exactly the way we wanted it. Thanks to Boeing, Douglas, some great flight training and excellent maintenance throughout my career.
Good to hear from you, my friend.
Ted
....I'm afraid you'd find my 38 years at the helm (or close to it) pretty boring. Which is exactly the way we wanted it.... Ted
<chuckle>...Seems reasonable, Ted. 'Boring' is good in that business (said as a frequent PAX!)
See you in Tucson next March?
Some of you guys really need to pay attention when things are
explained by those that know what they are speaking about. Not one
of you is on a level field with either Chris or Ted so you may want
to re-evalute how you phrase your comments as they indicate the
lack of knowledge and expertise of the subject under discussion. I have
flown with both of them and they are as good as it gets. If you want
to make flatout statements try to get them right or it makes you
look, well, you know, not really up to speed...I'm just sayin'. RJ
I think what he's trying to say is that you can believe whatever Ted and/or Chris tells you about flying high-performance passenger aircraft.
Everything else is B.S.
Ted
I think Mike's point was that you make the "boring" very entertaining. (Tales of the approach into Kai Tak come to mind)
Ah, Yes. Steve. Kai Tak!
All I can tell you about that approach is that you could tell which of the very pretty Chinese gals wore thongs because you could see them hanging on the clothes lines out their apartment windows to dry as you turned close final!
How's that for entertaining? <= <= n1
Ted
p.s. I might add, for the heck of it, that the dearth of accidents at Kai Tak--despite the infamous approach (google it for videos for a few hours of entertainment)--was a testament to the ability of stress to bring out the best in people. Believe me, nobody ever flew that approach with their mind on something else. Everyone in the cockpit paid attention and said something if something needed to be said. Reminds me of how overwhelmingly good were the people I flew with for all those years. Very proud of those associations.
Ah, Mike and Bob. Not B.S., just discussion. By definition, the guys on SH are fascinated by flying things and have one degree or another of knowledge about the subject. Not all have the same degree but none of us have all the answers (as Mr. Rush is often pleased to point out). A forum is for discussion out of which, from time to time, wisdom will surface and other times not. I note that, generally, somebody will note that guys with a bit more experience might add more to the discussion which is a tacet acknowledgement that they're mostly aware that the discussion to date might not have provided all the answers.
I love it when these discussions take place and often sit back and see if somebody doesn't eventually hit the nail on the head. There were a few near misses in this thread, each of which added a bit of value to the mix.
Ted
p.s. Here's a bit of observable info on the subject of air carrier "pitch trim settings" which those of you living near airports can check out which will help explain the problem with Denzel's heroic efforts in the film.
If you can get to an observation spot near the end of a runway where jetliners are starting their takeoff roll take a close look at the horizontal stabilizers as they take the runway. For the most part Boeing airplane will have the stabilizer set with the leading edge well below the trailing edge, sort of like giving up elevator to a flying tail on a combat ship. (big jets trim pitch by changing the angle of incidence on the stab, not by using trim tabs on the elevators).
The exact angle at which the stabilizer is set is computed for each takeoff and, if correct, will result in an initial climb attitude that requires no elevator input and delivers an indicated airspeed of "V2+10 knots" (V2 being one of three speeds computed for each takeoff considering aircraft weight, density altitude, runway length, flap setting and so forth. The other two speeds are V1 (the "go"/"no go" speed to either safely reject the takeoff on the remaining runway or, if above that speed, continue the takeoff following an engine failure and cross the far end of the runway at a minimum of 35 feet and meet all the angle of climb requirements for terrain, etc. while climbing out at V2+10K. The third speed is Vr, the speed at which the flying pilot rotates the nose to break ground and establish the climb) Sorry, TMI and not exactly pertinent to the discussion.
This significant Nose Up trim is required by the Boeing jets because they are designed so as to require significant download on the tail to maintain an "in trim" condition for any given speed and/or vertical flight path--i.e. climb/level flight/descent. The download is required because the Center of Gravity is located forward of the Center of where the lift to support it is generated. (By the way if this is starting to sound familiar it's part and parcel of the discussion of aft CGs with stunt ships that has been a subject of great interest and discussion in the last 15 or 20 years.)
You can see the effects of this CG/CL relationship when watching Boeing jets on final approach (ideally inside five miles or so from the end of the runway when they are stabilized at approach speed with landing flap settings). Boeings will be in a noticeably nose high attitude and with high thrust settings in this configuration and the stab setting will be close to the maximum leading edge down (nose up trim) setting to maintain this attitude with no pilot elevator input.
To get a mental feel for what I'm talking about here, imagine adding more and more weight to the nose of your stunt ship. At some point in time the CG will be so far ahead of where the lift to support it is generated that it will take all the up elevator available just to fly level and maneuvering will not be an available option. The Boeing operates in that direction but, of course, not to that extreme.
By the way, if you look closely at the Boeings as they roll onto the runway you'll see the "track" in which the mechanism drives the leading edge of the stab up and down to adjust trim. You'll easily see that there is lots of "nose up" movement available but very little nose down (A great amount of "nose down" trim would be required to even pretend to fly inverted in the Boeing and is simply not available to the best of my guess!) The overall design concept of the Boeing is to minimize download required in cruise with the flaps up and at high speed to minimize SFC (Specific Fuel Consumption) while sacrificing any such fuel efficiency during slow speed regimes.
(A caveat, I'm uncertain about the CG/CL relationships on late model Boeings like the 777 and 787. They could well be more like the Airbusses which I'll touch on next)
Late model airbuses are substantially different in this regard. A large part of their popularity with airlines is the design concept that more approximates the aft CG stunt ship. Tail authority (and computerized control inputs for stabilitly and maneuvering) that allow aft CGs which even further minimize the need for tail download which reduces SFC to an even greater degree (the single biggest selling factor to airlines is, understandably, how much gas the jets will burn for each butt in the seat mile).
Airbuses on short final will tend to have "flatter" body angles and not require as much thrust (as a for instance, a Boeing 727 with full flaps at approach speed required on the order of 80% of maximum N1 (forward rotor speed) just to maintain a three degree glide slope. For another "recent stunt dialogue" comparison that high thrust is also a result of the great drag and negative pitching moment from the huge triple slotted flaps! They're all airplanes...some's just bigger than others!)
If you watch the Airbuses taxi out you'll notice a distinctly different stab trim setting situation. The stab angle of incidence (its angle with respect to the fuselage) will be much closer to zero/zero with respect to the wing (that relationship, wing angle of incidence in relation to stab angle of incidence is sometimes termed decalage although I understand that term is not universally embraced by engineers...not sure why).
The bottom line of all this with respect to Denzel's wonderful adventure is that Boeings (and probably DC9s, although I've no personal experience with them) are extremely ill suited to negative g (inverted) flight as the combined elevator and trim forces necessary to maintain the necessary high angle of attack inverted are almost certainly not available. The Airbus model might have a modestly better potential but I wouldn't want to be the test pilot.d\
Hope this didn't put you all to sleep.
Ted
Except, for some reason, the A330 (and I guess the A340). They fly down final significantly more nose-up than comparable Boeings - about 4 degrees NU vs 2.5. I guess it's to do with the relationship between the leading edge and trailing edge devices, but someone smarter than me would have to answer that one.
A couple of my colleagues had a very nasty incident in an A330 where erroneous air data signals caused some dramatic pitch excursions, despite the fact that they disconnected the autopilot straight away (there's something to be said for old-tech, non-FBW aircraft...). I don't remember the exact numbers, but the thing was overstressed in both positive and negative G, and went to more than -1G.
That could well be, Steve. The ones I watch out my den window (I'm just about abeam the outer marker at SFO) are mostly 319s and 320s.
Ted
