I was an Epoxolite fan until I tried Superfil. Epoxolite was getting expensive and now I believe it has been discontinued. No problem because I prefer the Superfil.
I can't say if the age of your Superfil will make it useless. Mix a small batch and see how it goes. The directions on my jars say to stir each part well after long storage before mixing the two parts.
I like the fact that Superfil sets up in about 12 hours. Epoxolite took much longer, maybe two full days, to set up to where it could be sanded without balling up. The Superfil is easier to sand than Epoxolite. It produces a nice, smooth finish.
As far as smoothing it out, you need MEK or the new MEK substitute. This is one area where Epoxolite was better, at least for me. Superfil does not smooth out with the finger, or some other item, dipped in the MEK as well as Epoxolite with water. Maybe I just need to get a better technique but for now I can live with it.
Another thing about Superfil is the mix ratio: it is 2 to 1 by weight or volume. Epoxolite was 1 to 1 and easier to guess. Just get equal size blobs. For Superfil, I use the kitchen measuring spoons and level out what I need on the spoon for each part. For me, without the measuring spoons, it is hard to guess the 2 to 1 ratio just by looking at blobs on a mixing board.
It may be hard to give up on an old friend but new things come along all the time. I was hesitant about the Superfil at first but enough guys who have used it convinced me to try it.
