Doug, since Randy is not available, I will give what I remember,, it was last year at the NW regionals,, the skys were dark and an air of the ominous lingering about the flight circle,, Randy was putting in a good flight when suddenly, at the bottom of the hourglass the black hole opened up and sucked all the air out of the circle under his plane,, a light smack was heard followed by a non repeatable sound from the center circle,,,,, The outboard wheel whacked the tarmac and in later inspection shattered all the ribs in the outboard portion of the wing,, He managed to fly out the tank and get it on the ground safely but it was done and in need of an overhaul,,
sad, ,I really liked the color scheme and finish on it,, He does say he will rebuild it, but I know there are at least two airplanes in the works ahead of it so not sure when,,
