  • July 19, 2025, 05:34:31 PM
Author Topic: RSM P51 Mustang  (Read 6506 times)
Offline Chris Fretz
RSM P51 Mustang
« on: August 01, 2018, 06:10:01 PM »
Anyone have a RSM P51 Mustang semi scale 56in wingspan?  Was wondering what you thought about it for stunt? Have been pondering getting this kit.
Chris Fretz
Formerly known as #Liner
AMA 1104207
Advanced
Offline Walter Hicks
Re: RSM P51 Mustang
« Reply #1 on: August 01, 2018, 07:35:43 PM »
Chris nothing wrong with this however a better one  is Pat Johnston Mustang 626 which has a better wing , nearly the same design.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #2 on: August 02, 2018, 02:46:20 AM »
Thanks for the info! Is this something you can get a kit of or is it just built from plans?
Chris Fretz
AMA 1104207
Advanced
Offline Kevin Muckleroy
Re: RSM P51 Mustang
« Reply #3 on: August 02, 2018, 01:57:56 PM »
From RSM Web ad on that P51 "SEMI-SCALE FULL STUNT! Designed by Pat Johnston & Eric Rule"
Offline Mike Griffin
Re: RSM P51 Mustang
« Reply #4 on: August 02, 2018, 02:26:39 PM »
I am pretty sure that the Kit that Eric sells is Pat Johnston's  design..
Re: RSM P51 Mustang
« Reply #5 on: August 02, 2018, 02:39:05 PM »
The kit that RSM sell is partially a Pat Johnston design. However I know Pat prettty well and we have discussed this plane.Eric Rule did not use his
wing ribs for his kit. As stated earlier the RSM kit is ok but the Pat Johnston Mustang 626 has a better wing that the RSM kit. Yes Pat does
laser cut kits but they are short kits. Again nothing really wrong with the RSM kit but if you want better preformance use PATS wing :) If you are not flying super seriously at contests then the kit is fine.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #6 on: August 03, 2018, 09:59:21 AM »
Thanks again for the info.  I tried messaging Pat on here but no answer. What is a good way to get a hold of him?
Chris Fretz
AMA 1104207
Advanced
Online Mike Palko
Re: RSM P51 Mustang
« Reply #7 on: August 03, 2018, 11:02:15 AM »
Chris,
Thanks for the nice comments about my Mustang in the Philly thread. My Mustang is the Hunt design. Is there any reason you would choose not to build it? Are you looking for a kit rather than building from plans?
Re: RSM P51 Mustang
« Reply #8 on: August 03, 2018, 11:45:25 AM »
I have built two full-body P-51 from Eric Rule's kits.  Both fly great with OS46LA.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #9 on: August 03, 2018, 02:15:13 PM »
Chris,
Hey! I don't see you comment on here much, what a treat!  Sure thing, it is an eye catcher esp if you're a mustang fan. I've been looking around all year for a mustang to build this winter. I'd really like it to be a kit. I haven't ever built from plans,  I'd pick the wrong wood grain for sure. I'd like to put a ST60 in one.
Yours has a good realistic look too, I like the wing shape and wing tips, along with the nose and tail...well ok the whole thing!
Chris
AMA 1104207
Advanced
Online Mike Palko
Re: RSM P51 Mustang
« Reply #10 on: August 04, 2018, 06:07:57 AM »
I understand not wanting to build from plans. A Pat Johnston short kit is a good compromise and will be a great flying airplane.
Re: RSM P51 Mustang
« Reply #11 on: August 04, 2018, 08:01:49 AM »
I have one it it will do the pattern.
Offline George Truett
Re: RSM P51 Mustang
« Reply #12 on: August 04, 2018, 08:08:46 AM »
I think they're talking about the larger one with a built up fuselage.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #13 on: August 04, 2018, 09:11:24 AM »
Does anyone have a picture of a Pat Johnston Mustang 626?
Chris
AMA 1104207
Advanced
Online Dave Hull
Re: RSM P51 Mustang
« Reply #14 on: August 04, 2018, 09:51:16 AM »
I believe I have a picture that Pat sent me. But it isn't smashed down to proper forum size. Two planes side by side in red, white and blue eagle livery. Pretty!
If anyone can confirm (or correct) my assumption that these are 626's, please chime in....
Offline kenneth cook
Re: RSM P51 Mustang
« Reply #15 on: August 04, 2018, 10:39:34 AM »
            Dave, they're pretty darn cool looking. Amazing when you see 2 identical models. It's tough enough to build one.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #16 on: August 04, 2018, 11:32:28 AM »
Wow if they are 626's they are rather nice looking for sure!
Chris
AMA 1104207
Advanced
Re: RSM P51 Mustang
« Reply #17 on: August 04, 2018, 12:46:07 PM »
Yes those are the Pat Johnston 626. Again if you are not a top level Advanced or an Expert flyer the RSM kit will do well.
Online Dave Hull
Re: RSM P51 Mustang
« Reply #18 on: August 04, 2018, 01:13:50 PM »
Eric shows a picture of what appears to be one of these two in the "details" section for his RSM P-51. Put side by side, these may be difficult to tell apart.
I attached the summary I was working on of the different Mustang C/L'ers out there. Additions and corrections welcomed!
« Last Edit: August 04, 2018, 02:23:17 PM by Dave Hull »
Re: RSM P51 Mustang
« Reply #19 on: August 04, 2018, 03:29:51 PM »
Here are two P-51 built from RSM kits without any modifications.
Both use OS46LA engine.
Both very successful flyers,and required almost no trimming after test flight.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #20 on: August 04, 2018, 08:10:24 PM »
They look very nice, Dinger muffler.  What prop are you running?
AMA 1104207
Advanced
Offline Skip Chernoff
Re: RSM P51 Mustang
« Reply #21 on: August 04, 2018, 09:20:23 PM »
Chris is a very fine Advanced flier and would make that Mustang look great!
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #22 on: August 04, 2018, 10:23:04 PM »
Somethings telling me to go with a higher end Pat Johnston or even give the Hunt Mustang a shot.
AMA 1104207
Advanced
Offline TigreST
  • TigreST
Re: RSM P51 Mustang
« Reply #23 on: August 05, 2018, 01:35:54 PM »
I did some photo shots of the RSM Mustang plans some years ago.  Here they are, should anybody be interested in a look see.
FWIW,
T.
Tony Bagley
Ontario, Canada
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #24 on: August 05, 2018, 06:43:48 PM »
Does the Johnston 626 have a dihedral? Hunt? That sounds like a pain to build let alone getting a regular wing square.
Chris
AMA 1104207
Advanced
Re: RSM P51 Mustang
« Reply #25 on: August 05, 2018, 07:19:57 PM »
According to Pat's plan listing the 626 P-51 does have dihedral.  I have not built one but Pat makes a simple wing jig that uses arrow shafts locked in place to hold the ribs.  I really expect building a straight wing will not be a problem.
Online Mike Palko
Re: RSM P51 Mustang
« Reply #26 on: August 05, 2018, 07:23:21 PM »
Hunt’s Mustang does not have dihedral. I don’t believe Pat’s does either but it’s been a long time since I’ve seen one. Images I found on google appear to show Pat’s with a straight wing.
Offline eric rule
Re: RSM P51 Mustang
« Reply #27 on: August 05, 2018, 09:22:50 PM »
Pat Johnston's Mustang and the one I sell are very close which is not surprising as we did the basic design together. Pat actually did the AutoCAD drawing for the plan in the RSM version and used this plan with a couple of modifications in his version.
Pat's used a slightly different airfoil shape than I did and he determined that he wanted to lift the wing tip on his in order to bring the vertical C/G upwards. I agreed with Pat about the vertical C/G but elected to simply raise the wing in the fuselage rather than go with dihedral to accomplish the change. Both models achieved the same result using a different approach. Both fly exceptional well and present well on the ground and in the air.
In my opinion you can not go very far wrong if you choose to build either one.
Online Dave Hull
Re: RSM P51 Mustang
« Reply #28 on: August 05, 2018, 09:27:59 PM »
The Johnston 626 Mustang plans show one inch of dihedral per panel. Don't leave it out or it will screw up your roll trim. This plane is a true, low-wing design with the bottom of the wing pretty much tangent to the bottom of the fuselage. Other designs without dihedral are raising the wing up to the CG (to align the leadouts) and giving up a bit of scale appearance. So you have to fake your brain into believing "Mustang" with a military paint job.
PS--Good input from Eric. I see we were typing at the same time.....
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #29 on: August 06, 2018, 02:38:05 AM »
Is your wing sheeted? I don't see the ribs...
Chris
AMA 1104207
Advanced
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #30 on: August 06, 2018, 02:43:22 AM »
Ok good to know thanks for the info!
Thanks for commenting on this Eric and Dave. Very helpful!
Chris
AMA 1104207
Advanced
Offline TigreST
  • TigreST
Re: RSM P51 Mustang
« Reply #31 on: August 06, 2018, 08:36:02 AM »
So Eric,
If the above is fact (no doubt it is) was there a change in the RSM design/production between the time I purchased my kit (non-laser cut, Hobby Fasteners production) and what could be a newer RSM P-51D?  I had a visit to your web site and see the photo ad has changed (I think?) for the P-51D and as you state the built model photo shows the wing at/close to the thrust center-line in the fuselage, maybe?.   What causes me to wonder is you state no dihedral in your kit whereas my older production run states build with dihedral.  I think the dihedral will be cool btw.
Just wondering is all.
Tony Bagley
Ontario, Canada
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #32 on: August 06, 2018, 09:07:14 AM »
So Eric,
The wing area is listed as 610 on the website,  yours says 635
AMA 1104207
Advanced
Offline TigreST
  • TigreST
Re: RSM P51 Mustang
« Reply #33 on: August 06, 2018, 09:15:05 AM »
I did not notice that Chris.  Interesting, ...very interesting.
Tony Bagley
Ontario, Canada
Offline Balsa Butcher
  • High Desert Flier
Re: RSM P51 Mustang
« Reply #34 on: August 06, 2018, 09:26:18 AM »
This will either clarify or obfuscate the issue: The May 2007 issue of Model Aviation features Pat's Mustang, listed wingspan 48". The red white and blue Mustang pics may be of that version. The RSM version is most likely based on this model thus the smaller wing area.  Pat offers plans for different sizes his scale warbird stunters, both smaller and larger. The 626 version may be the "46" sized version of his published 40 sized Mustang.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Vincent Judd
Re: RSM P51 Mustang
« Reply #35 on: August 06, 2018, 03:37:36 PM »
I'm obviously spending too much time building airplanes and not enough time living.  I have to get out more.  I can honestly say that in my 71 years, I never heard the word obfuscate.  Or if I did, my mind was in an obfuscated state.
They say you never stop learning, I learned the word obfuscate today.
ob·fus·cate  (ŏb′fə-skāt′, ŏb-fŭs′kāt′)
tr.v. ob·fus·cat·ed, ob·fus·cat·ing, ob·fus·cates
1. To make so confused or opaque as to be difficult to perceive or understand: "A great effort was made ... to obscure or obfuscate the truth" (Robert Conquest).
2. To render indistinct or dim; darken: The fog obfuscated the shore.
And they say you can't teach an old dog new tricks.  Ha!    LL~
Online Mike Palko
Re: RSM P51 Mustang
« Reply #36 on: August 06, 2018, 04:16:45 PM »
Chris
The wing is built using the lost foam construction method with a sheeted center section and open bays.
Offline eric rule
Re: RSM P51 Mustang
« Reply #37 on: August 06, 2018, 05:23:28 PM »
The original RSM kit was hand cut and the original wing placement was at the bottom of the fuselage. After some more discussion with Pat where we talked about the design we decided to modify the P51D to bring the vertical CG more in line. Pat liked using dihedral and went with that idea in his version (which by the way comes in a number of different sizes). Since I had just taken delivery of my first laser machine I elected to make the change by raising the wing in the fuselage. As I said previously both methods accomplished a better vertical C/G so they both work. I think that it's easier for folks to build a straight wing so went in that direction while Pat likes a more semi-scale look so he went with dihedral even though it is a bit more difficult to build the wing.
As far as the different wing area numbers I used the AutoCAD function to get the area as stated on the web site.
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #38 on: August 07, 2018, 05:22:03 AM »
I was in total belief that it was a typo of some kind, guess the jokes on me now!
AMA 1104207
Advanced
Re: RSM P51 Mustang
« Reply #39 on: August 07, 2018, 06:24:44 AM »
Chris:
Pick whichever you want, but do not worry about the dihedral.  It makes no difference in the performance of the plane.  The Pat Johnston profile P-51B as kitted for us by Tom Morris flies great!
Offline TigreST
  • TigreST
Re: RSM P51 Mustang
« Reply #40 on: August 07, 2018, 01:28:22 PM »
A bit more chat on PJ Mustangs: A quote from a post regarding the Pat Johnston Corsair plans and such but the Mustand is mentioned:
Thanks so much Ron, Rick and all.
The RSM Mustang is a 600+ incher for the LA46 or larger.  The airfoil is from Charles Mackey "Lark".  That was the basis for my larger 626" Mustang (June 2006, MA).  The M626 has a more scale-like fuselage and my Bearcat/Mustang airfoil.  Flies spectacularly.
The Brodak Mustang is scaled down to the 560 square inch range and is very specifically designed for the LA46.  That will produce gobs of torque for the size of plane.  The result is a totally fun and competitive plane.
Rick,  I'm gratified that you followed my suggestions on the LA46 setup and are getting a 3.5 ounce fuel consumption.  That is the idea.  An engine which will do what it does on 3.5 ounces of fuel is a bargain.
Pat Johnston
Skunk Works
end quote.
That post his here:
https://stunthanger.com/smf/open-forum/brodak-corsair/
« Last Edit: August 07, 2018, 01:51:36 PM by TigreST »
Tony Bagley
Ontario, Canada
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #41 on: August 09, 2018, 07:30:55 AM »
Chris:
Very nice looking Scott. Did this kit call for a dihedral and you left it out?
AMA 1104207
Advanced
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #42 on: August 09, 2018, 07:35:10 AM »
Pat Johnston
Skunk Works
end quote.
That post his here:
Is this Pat holding the airplane?
Good thread thanks for sharing
AMA 1104207
Advanced
Re: RSM P51 Mustang
« Reply #43 on: August 09, 2018, 11:56:02 AM »
Yes, that is the man. H^^
Re: RSM P51 Mustang
« Reply #44 on: August 09, 2018, 02:19:15 PM »
It has dihedral.  It just isn't evident in the photo.
A little more visible here....
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #45 on: August 09, 2018, 02:39:28 PM »
Ohhh, I see... you ment no sweat building a dihedral.
Cool looking all 3 of them together!
AMA 1104207
Advanced
Offline Chris Fretz
Re: RSM P51 Mustang
« Reply #46 on: August 09, 2018, 02:41:02 PM »
AMA 1104207
Advanced
