<snip>
The stock Twister with a Fox .35 is a bit skittish, and the additional weight of an OS .40
FP-S tends to make it smoother and easier to fly, as well as improve line tension.
L.
(clip)
- Typical prop on a model of this size is 10.5". Yaw tendencies are directly proportional to prop swept area. 10.5" prop has too small of an area to generate any significant yaw tendencies. A 10.5" prop has 1/6 area of a 13" prop. Al's models generally use large diameter props and therefore Rabe rudder is an ingenuous answer to the 6x more yaw.
Point I am trying to make is that this model does not need Rabe Rudder. Something else if off here. :-[
Hi Phil,
Neat installation! H^^
Showing my ignorance here, but it looks like your setup produces more rudder offset for outsides, and less for insides.
(clip)
A RABE rudder
on a
FANCHER plane?
Watch out, the rudder might get insulted and separate from the rest of the plane... ;D
Steve, I am not sure what you base your calculations on but there is hardly the 6x difference in area between a 10.5 inch Prop and a 13 inch prop. The 13 inch prop has only about 53% more area than a 10.5 inch prop. Your 600% is a far reach, like more than an order of magnitude, from the actual 53% difference.
Many will argue that a Rabe rudder is not necessary on any airplane, and on a Twister in particular. One thing that can be said is that properly installed, a Rabe rudder cannot hurt the performance of our stunt models. In this case, by the report of Phil Coopy, it helped correct a problem, whatever that problem was. And besides, Phil employed a rather elegant method to incorporate the movable rudder. Thanks for sharing.
"whatever works"
Oh, oh, Brad. I wasn't going to go there! I am, however, a big fan of "whatever works". Glad it helped make his plane fly better.
Ted
I just thought it was funny... I got a chuckle out of it!!!
Actually those white shiney shoes might have belonged to either Tim Dunlop, Bob Parker, Joe Dill, Ted Fancher, or Paul Walker.
