  • July 12, 2025, 01:51:03 PM
Author Topic: Quick & Dirty finish for a test pig?  (Read 3845 times)
« on: August 08, 2014, 03:01:54 PM »
I'm working on a proof of concept beast for my timer project.  It's turned into a flapless profile stunter (I'm using Corehouse wings).
So what's a good finish that I can just slop onto the fuselage and have it be (a) not too heavy, (b) fuel proof, and (c) reasonably long lasting.  Ugly is OK, but cheap is desirable.  If I don't come up with anything else I'll use Polycrylic to stick on some silkspan, give it a few licks with some sandpaper, then brush on Rustoleum.  But I'm open to suggestions.
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
Re: Quick & Dirty finish for a test pig?
« Reply #1 on: August 08, 2014, 03:05:00 PM »
Spray can epoxy appliance paint.
AMA 77370
« Reply #2 on: August 08, 2014, 03:06:57 PM »
   I would use Klass Kote, sand it, spray one coat, let it cure, sand it again, put on another coat, good for 25 years. That's more-or-less what I did on the Skyray.
Online Paul Taylor
« Reply #3 on: August 08, 2014, 03:41:03 PM »
Wow just went and looked at the klass kote paint. Big $$$.
If your doing electric why are you needed to fuel proof it?
Unless your maybe doing a hybrid? In that case I would put thinned epoxy in the engine area and just put NAPA gray primer on it.
If you want color use rattle can rust-oleum and maybe a coat of clear  H^^
« Reply #4 on: August 08, 2014, 03:52:31 PM »
Who ever said a timer had to only work with electric?
Online Paul Taylor
« Reply #5 on: August 08, 2014, 03:58:12 PM »
Well for stunt I think the AMA has a rule against it. I could be so wrong on this.  H^^
Offline RC Storick
« Reply #6 on: August 08, 2014, 04:39:49 PM »
Zpoxy- prime  DC 540- paint
Online Steve Helmick
« Reply #7 on: August 08, 2014, 05:12:28 PM »
Yep, you're wrong. Perfectly legit, and has been for a long time, if not forever.  H^^ Steve
« Reply #8 on: August 08, 2014, 05:17:12 PM »
Not unless I'm missing something big.  We should probably each go off and read the rules.  Again.  Or just believe Steve, because if we don't he'll make us clean his bass boat bilge.
The FAI do not appear to rule out a timer, either, although there's some recent and ambiguous language in there about "pilot-actuated shutoff devices" that may or may not apply to fuel systems that are capable of shut-off loops, and timers that emulate that behavior.
« Reply #9 on: August 08, 2014, 06:09:31 PM »
.5 glass cloth and finishing epoxy,, done deal,,
Online Paul Taylor
« Reply #10 on: August 08, 2014, 06:18:35 PM »
Yea I figured I was wrong.
Maybe it had to with throttles. ???
« Reply #11 on: August 08, 2014, 06:36:47 PM »
   AAARGH! There has never been a rule that outlawed timers in the AMA rules. They were outlawed in FAI for no good reason but that, too, has been removed.
« Reply #12 on: August 08, 2014, 06:37:54 PM »
??? It's substantially cheaper than dope.
Joe Just
« Reply #13 on: August 08, 2014, 06:59:53 PM »
Tim for quick and dirty just mix carpenter's glue 50-50 with water and use that to0 cover the silkspan on the foam.  Then a couple of coats using the same glue.  When it dries hit it with your choice of Rustoleum spray paint. Just hit the body and other parts with the same paint. Works for me! The two Carrier planes in the attachment are still doing well after 5 years.   The grey one is 4 years old and still looks like it did the day I painted it.
Joe
Offline Douglas Ames
« Reply #14 on: August 08, 2014, 07:05:47 PM »
Joe
Good answer Joe.
Mine would be Minwax Poly and RustOleum Hi-Gloss rattle cans.
AMA 656546
Online Paul Taylor
« Reply #15 on: August 08, 2014, 08:40:35 PM »
Well I guess if you include the cost of primer and clear coats then I guess kk is cheaper.
I just looked at the cost of color and dope was cheaper.
Online Howard Rush
« Reply #16 on: August 08, 2014, 10:30:47 PM »
Tim has a lot of TUT money coming in, so cost is no big deal.
Offline Dane Martin
  • heli pilot BHOR
« Reply #17 on: August 08, 2014, 10:53:41 PM »
yep. and i hear he has an ace pilot out there advertising for him....  :D
Tim, i use this valspar spray as a sanding sealer (fuel proof also). then a coat of lustrekote spray by monokote. cheap, quick and easy
« Reply #18 on: August 09, 2014, 01:14:53 AM »
Econokote on wings or any other low temp kote, Zpoxy finishing epoxy on fuse and overlap slightly onto Kote.  Sand, apply Rustoleum Primer, then Rustoleum color.  The Silver is very fuel proof.  As are most of the Blues and Greens.
Online Howard Rush
« Reply #19 on: August 09, 2014, 06:22:03 AM »
He did say ugly is OK.
Offline Dane Martin
  • heli pilot BHOR
« Reply #20 on: August 09, 2014, 09:05:37 AM »
exactly. shoot it, an hour later, you're in the air. just get it in the air before your friends see it!
Joe Just
« Reply #21 on: August 09, 2014, 04:42:57 PM »
Will it work on raw foam cores?
Joe
« Reply #22 on: August 09, 2014, 04:51:58 PM »
Joe
I bet it'll "work" to melt them!
I got some SLC from Phil when I got the cores -- I'm going to cover the wings with that.
Joe Just
« Reply #23 on: August 09, 2014, 07:10:20 PM »
God stuff and paintable.
watch the heat when you use it on foam Tim.
Joe
Offline Dane Martin
  • heli pilot BHOR
« Reply #24 on: August 09, 2014, 09:10:26 PM »
Joe, the valspar eats through foam quickly. if you want to spray foam a cheap easy way, use krylon h2o spray.
Offline Paul Walker
« Reply #25 on: August 09, 2014, 10:05:12 PM »
Hey, you don't have time for this!!!!
Go get processed....:)
Offline Phil Krankowski
« Reply #26 on: August 11, 2014, 11:48:24 AM »
I just tested the Valspar spray lacquers against Sig champion 25%...NOT fuelproof.  Washes away instantly, just like nail polish.  I tested all 3 colors, black, white, and clear.
Phil
Offline Bruce Perry
« Reply #27 on: August 11, 2014, 12:40:42 PM »
Tim,
Will your device allow for IC throttle control?  If so, will it be able to apply throttle for a timed segment of the flight?  Or will it be able to decrease throttle at the beginning and ramp up at the end like Howards electric?
I'm interested in seeing if this could be of any benefit in the wind.  The low level maneuvers all occur early, the higher HP tricks later.  It wouldn't need to be much.  Clearly, the systems work as they are now.  Just curious about where it "could" go.
B
Offline Dane Martin
  • heli pilot BHOR
« Reply #28 on: August 11, 2014, 02:27:55 PM »
Phil
i apologize for misleading anyone, but that's what i use on my half a planes which i run 25%. I've only ever used the clear, not the colors. I've found that it can't be sprayed over anything else. but i have several 1/2a planes that are just clear for use as a test bed for trying engine setups.
« Reply #29 on: August 11, 2014, 02:52:25 PM »
The short answer is yes.
In fact, I'm doing the testing using an LA-46 for a power source.
The long answer is that in its formative stages I was taking input from Howard, Dave Trible, and my own desires.  We were basically three customers who each wanted obviously desirable things that were also obviously mutually exclusive.  The upshot is that I designed the timer so that it is very customizable -- basically, someone who can program embedded computers at a hobbyist level of competence can program Tim's Universal Timer to do a wide variety of things.
It currently does apply throttle for a timed segment of the flight, and it decreases the throttle for takeoff.  I'm not sure just how valuable that is, because electrics just seem to take off more suddenly than IC ships do.  At the moment I'm mostly using that feature to test the software thoroughly.
It could also be programmed to apply scheduled throttle adjustments during flight -- this is exactly why I made it easily programmable, by the way: customers # 1, 2 and 3 each wanted something different, so I figured that every one approaching this would have some other quirk or trick they'd want done.
Ultimately I hope to out-Igor Igor, and strictly control the inertial speed of the aircraft for both electric and IC engines.  In that event a model equipped with this should chug through all the maneuvers at the same speed as level flight, with only momentary acceleration or deceleration.  Whether my sensors and I are good enough to accomplish this is still an open question, however, so don't hold your breath.
« Reply #30 on: August 11, 2014, 03:56:35 PM »
What was your cure time?  I was at about 18 hours for my test.  I was hoping it would be fuel proof as it seems to go on very light.  Maybe you should look at the fueling spill points and see.  The paint might be exhaust proof, I did not test for that.
Phil
Offline Larry Renger
« Reply #31 on: August 11, 2014, 06:32:11 PM »
30 minute epoxy thinned to brushing consistency with denatured alcohol. Sand lightly, 2nd coat, done deal forever.
« Reply #32 on: August 12, 2014, 06:13:02 AM »
Ya beat me to it!!!!!!
