  • June 21, 2025, 06:26:27 PM
Author Topic: question on ST V60  (Read 1131 times)
Offline Jim Nohsey
question on ST V60
« on: November 13, 2014, 02:10:19 PM »
I have an suoer tigre v60 that has been worked on by George Aldrige??It hasn't been run since we got it back from him. I trying to find out what it is worth. Thanks for any help.Jim
Jim Nohsey
Re: question on ST V60
« Reply #1 on: November 13, 2014, 09:36:30 PM »
To some extent (or other), it depends on which version of the ST .60bb it is. There were "light" and "heavy" which had thin and thick cylinder liners, without or with muffler lugs and some other subtle changes. Bent head fins, oversized mounting bolt holes and such detract quite a bit, at least on eBuy. Pictures would help.  y1 Steve
Edit: Just thought maybe posting pictures would be a problem. If you email them to me at: sbasser at yahoo dot com, I will crunch them and post them for you. Usually about 15-20 sec per picture, using IrfanView.
« Last Edit: November 14, 2014, 11:17:28 PM by Steve Helmick »
« Reply #2 on: November 17, 2014, 04:52:45 PM »
Well, Jim sent the pics, which I resized and compressed. I'm not sure if it's a light case or heavy case, but it's a Big Art muffler. And the needle appears to be bent.   H^^ Steve
« Reply #3 on: November 17, 2014, 05:28:10 PM »
Well, it's no collectors item but looks like a good serviceable ST60, and as such should fetch $150.00 to $200.00 depending on it's internal condition.
