Howdy again ..... !! I put a couple of tanks through the engine tonight and have a couple concerns. They may be minor, but maybe I'm missing a few things with this type of setup, as opposed to the 40-75 2-strokes I'm use to.
OS25LA-S, Byron's 15%, 9x4 prop, A3 plug, exhaust baffle removed, HS needle about 2 turns out.
First issue is the metal fuel tank, supplied with the FS plane. Its centerline is in-line with the venturi, and mounted right to the fuse (no padding/foam). There are 3 lines on the fuel tank. I have it hooked up .... top line goes to pressure fitting on muffler, middle goes to needle valve, and the bottom is the fill ... or what I call "useless"... but plugged off. After filling the tank (my electric pump needs to be replaced .... fills way too fast) and reconnecting the lines, if I wait a few seconds ... fuel will begin to syphon through the pressure line and into the muffler. It wont stop unless I intervene.
Second issue. Once the engine is running, if I tip the wings to either side (lets say 30-40 degrees), air bubbles immediately appear in the fuel line and the engine becomes unstable. It will quit if I hold the wings tipped. Righting the wing resumes a good flow. 3 times I ran the engine .... maybe 3-4 minutes until the tank emptied. Its plenty rich, but I've noticed fuel remaining in the tank. The engine was warmer than I would have liked as well.
The first thing that I question .... are these ARF-supplied tanks junk?? Because its metal, I can't see any of the fittings and how they are routed inside. I might be missing something here .....
As a habit, I always disassemble my mufflers, remove the baffle, and then RTV the halves together. Never have I had issues with fuel delivery, but maybe an engine this small needs the baffle for back pressure. I've since reinstalled it, but haven't run the engine. Thoughts on this?? Could this be causing the air bubbles when the wings are tipped? When the plane is flying, does centrifugal force play any roll in fuel delivery? I don't want to fly the plane until the air issue is resolved. ANY stunt at all seems like it will cause the engine to quit.
Lastly, is 15% too high for the 25LA? With as rich as it was running, it seemed to have higher temps than I would have liked.
On a positive note, the 9x4 prop seemed to provide PLENTY of pull, and the new 3" foam wheel gives me plenty of clearance.
Sorry for being so lengthy, but I wanted to get details out here. So many times I see posts with issues, but not enough info for anyone to really help out.
Appreciate all input .... Thanks! Larry (Larrys4227)
