  • June 25, 2025, 07:16:35 PM
Author Topic: Twister - FINISHED, DONE, READY TO FLY!!!  (Read 18577 times)
Offline Rusty
Re: Pushrod from Bell crank to Flap horn questions.
« Reply #50 on: April 09, 2025, 05:21:27 PM »
Thank you Dave and Dan.  I will be able to fly alone now.
The Twister is coming along.  I got the wing, mostly finished.  I made a weight box and adjustable lead outs.  I found some nylon and made a guide.  I am happy with how it turned out.  I made the fuselage and added 2" to the tail, per Francher's plans.  I am going to put 1/4" tail feathers on it.   Today I was in the process of drilling the engine mount holes, when I discovered the FP 40 I am using has the bolt holes drilled out to 6/32.  I'm not putting that large of a bolt on it.  I will find another engine with stock bolt holes so I can use 4/40.   I will post pictures
« Reply #51 on: April 09, 2025, 07:38:41 PM »
   If you can't find am acceptable replacement, see if you can bush the drilled out hole with a short length of 5/32" brass tubing. That had a 1/8" ID and a 4-40 screw should pass through that. If you can verify that the centers of the holes are accurate still, you could ream out the hole until the tubing fit snuggly and if there are any gaps, fill them with JB-Weld. Its a little work but worth it .
« Reply #52 on: April 09, 2025, 07:39:10 PM »
How about Washers .!
Thisis wotcher need .  VD~ " Socket Shoulder Screws/Shoulder Bolts 4-40 X 1/4 (Pack of 500) "
Theres electronic ones too , shoulder / stepped bolts . We can start a new trend in engine mounting bolts .  ;D
Or , Like E Says , throw a bitta brass toob onit .
Offline Rusty
« Reply #53 on: April 09, 2025, 11:54:01 PM »
Thank you Dan and Mate Spencer,   I agree and have done exactly that.  McMaster Carr sells spacers that are perfect to bush down the 6/32 hole to a 4/40.  I bought about 12 of them years ago and fixed 3 engines.  However, the spacers are reasonable, shipping is not.  It is cheaper to get a good used crankcase.  I texted Bobby and he is going to send me one.  I have successfully got a solid bolt down by putting j b weld on the bolt using the theory Mate Spencer shows.  You put a washer on the bolt and put jb weld below it, the width of the mount lug.  When that dries, put the bolt in a drill and use a file to turn it down to the right size.  I have done it and admit it, even though I have been called a "red neck engineer" for it. However, I got credit with the man!  Recently, I sent him 4 brand new 15 engines to sell in his ebay store.  Right now I can get about anything he has listed w/o cutting back on my church offerings.
Addendum:  Dan, such is not the case here.  The holes are hogged out with a dremel tool.  They are elongated and enlarged.  The spacers I had would have fixed it as you say jb welding them in.   I have used brass tubing as you suggest also, when they are not that opened up.   What is the adjective you use to describe someone who ruins the lugs on a brand new engine?
Offline Rusty
Re: Twister - Updated
« Reply #54 on: April 15, 2025, 04:20:18 PM »
Okay, Guys; I have something to discuss and show.   I have the twister framed out and make as assessment of where I am in terms of success.
1)  I deem it right now a failure.
     A.  The plane weighs 38 oz and has no covering or paint.
     B.  The plane is very nose heavy.
2)  Construction.
     A.  The plane is Francherized, i.e. weight box, adjustable leadouts, 2" extended fuselage, reduced size rudder, enlarged flaps and elevator, 1/4" flaps and tail surfaces, carbon fiber pushrods and ball links on all ends.
     B.  The plane has a OS FP .40 with tongue muffler.
3)  Correction.  (Input requested)
     A.  The nose will have to be shortened and the engine moved back.  How much??
     B.  To lighted the plane, I am thinking for using a 1" hole saw and cutting holes in the fuselage. How many and spacing?
     C.  The spinner can go.
     D.  The engine can be changed to a lighter one, but will that be needed?
4)  Where is Mate Spencer when you need him?
Offline Rusty
« Reply #55 on: April 15, 2025, 04:31:43 PM »
Online Dan Berry
« Reply #56 on: April 15, 2025, 04:41:16 PM »
Cover it, paint it, add the tailweight if needed and go fly it.
« Reply #57 on: April 15, 2025, 04:59:43 PM »
Not even close to a failure.  My Twister (in pix a few posts above) weighed in at 52 oz and balanced about 1" back from the LE.  It once put up a 535 in profile.  It has a very good airfoil and can easily carry the weight.  You are going to add 3oz (weight) of fuel and about 4-5 oz for finish.  Before you go cutting it up, take something that weighs about 1 1/2oz and put it on the wing at the flap line and see where it balances.  That is about where it will balance fueled.  The plans show the CG unfueled so do it again this time with 4oz on the wing TE.  Bet you are not still thinking it is nose heavy.
Some comments on lightening.  First, where does it balance "as is".  It should be at about the LE.  You could shorten the nose about 1/2" with out much difficulty but let's make sure you need to first.  I assume you have the wheels that far forward to fly in rough grass. You can save a bunch of weight with some lighter wheels and move them back about an inch.  If I remember right the wheel hubs on the plans are right at the LE, maybe a touch behind.   Same with the tank.  It is good to have it close to the engine but not critical.  That spinner looks huge.  If you get it covered and a few coats of dope on it and it still feels nose heavy, then is the time to start cutting.  If I remember the motor mounts are about 2 inches longer that the motor cutout.  That gives you about a half inch to play with.  The main reason I would be against cutting into the nose is that the motor mounts are the main transmitters of vibration to the rest of the fuselage.  Shortening them by moving the motor back may cause a vibration problem.  I stress "may".
Keep in mind that any weight you save aft or the intended CG will probably result in you having to add it back as tail weight and you have weakened the fuselage in the process.  Also keep in mind that the weight of these planes back when they were designed was to accommodate a Fox 35.  Todays motors are considerably more powerful.
« Last Edit: April 15, 2025, 05:50:14 PM by Ken Culbertson »
Offline Rusty
« Reply #58 on: April 15, 2025, 05:34:04 PM »
Some comments on lightening.  First, where does it balance "as is".  It should be at about the LE.  You could shorten the nose about 1/2" with out much difficulty but let's make sure you need to first.  I assume you have the wheels that far forward to fly in rough grass. You can save a bunch of weight with some lighter wheels and move them back about an inch.  Same with the tank.  It is good to have it close to the engine but not critical.  That spinner looks huge.  If you get it covered and a few coats of dope on it and it still feels nose heavy, then is the time to start cutting.  If I remember the motor mounts are about an inch longer that the motor cutout.  That gives you about a half inch to play with.  The main reason I would be against cutting into the nose is that the motor mounts are the main transmitters of vibration to the rest of the fuselage.  Shortening them by moving the motor back may cause a vibration problem.  I stress "may".
Thanks for the info.  I am going to move the engine back and reassess where I at.  I made the rudder adjustable.   With ball links the controls are amazingly smooth.
The maple mm beams are about 5 inches from nose. Somewhere I read the nose should be shortened, but plans did not call for it.   I agree moving tank back and losing spinner will help,
Thanks again
« Reply #59 on: April 15, 2025, 06:18:40 PM »
It is a simple thing to Dremel out the back of the motor cutout without having to damage the doublers.  Do yourself a favor and leave the blind nuts in for the current hole settings and drill new ones.  When I did this kind of stuff I would plug the old holes with balsa so they wouldn't become fuel soaked and could be reopened easily. You just might want to move the engine back.  The plane is looking good.  One thing I noticed, and this is really personal preference, but I think the bellcrank to flap pushrod goes in the top hole of the flap horn on a Fancherized.  You are most likely going to need less flap movement than elevator and it will be easier that way.
Offline Rusty
« Reply #60 on: April 15, 2025, 06:25:19 PM »
You don't miss anything, do you?  I struggled with that because the ball links (too large) will not allow me to locate them where it is specified.  To try and compensate for that I have the elevator in the most outside hole.   The twister plans and the francerized have them located opposite of each other on the flap horn.
I was thinking of moving the engine back to where the front lug bolt holes on the engine will use the back bolt holes on the plane.  That is moving it an inch or so.  What do you think?
« Reply #61 on: April 15, 2025, 07:17:32 PM »
   Even at 38 ounces as it sits, a typical finish for a model that Windy built in his videos was 10 ounces and that was traditional dope finish with lots of clear. Even if you did that it would be 48 ounces and that would still be a pattern capable airplane. If you go iron on covering for the wing and tail and spray can for the fuselage, you might be 5 to 7 ounces more. Well within the "I'll take it!" range!!  Resist any temptation to cut anything until you relocate your engine and such. Keep in mind that adding any finish to the tail end has more effect that the rest of the airplane as far as balance. Look at the airplane from the top and notice how much of the finish, including iron on covering, will be behind the main spars!! That means behind the balance point. Don't put the cart ahead of the horse!! A bare bones airframe will be nose heavy with the engine and tank installed.
   The only things I might have cautioned you on was replacing the balsa spars with spruce but that wasn't much of a penalty, and not cutting out the ribs in the outboard wing like you did the inboard. Lots of airplanes wind up having too much weight out there even before the tip weight is added. I have learned to build a model where it is balanced on the roll axis if it has equal length wings. If it was something with 1 to 2" of inboard wing offset you could stand the weight better. If everything is aligned correctly, that's the first thing you want to achieve and the most important. Just do your final sanding after moving the engine and re-evaluate. I think you are going to be just fine.
« Reply #62 on: April 15, 2025, 07:19:31 PM »
Youll Need To . If you put the S T .60 in it .  ;D   S?P   LL~
Um . Mounting Plates . steel or ally , under the lugs . Tapered for offset if reqd. Spead the load . and you fill the old ( engine ) holes with ayrldite 7 file flush , when youve made up your mind !
Acly , Steel Plates say 10 x 30 metric things , drilled & tapped ( steel ) woukld spead the nut load too . CRUSHIBNG soft bearers is a bear . But Heart Oak / Maple should take it .
Weve spliced new fronts on a bearer or two . When neccesary .
MOVINGIT .
Put the C G onnit . Pull the motor back & forward. Use a elestic band . or masking tape . with the b great 3030 muffler , Itll need to go back . but Id still have it 1/4 forward . Of the plan C G .
the Tower .40 mufflers the samme . But HALF the WEIGHT .
As in use a soft pencil / marker pen , put a line under on the c.g. , or on a bit of tape . Balance on someting under each side . If it falls fwd Yr o.k. , if it falls back , yr not .
« Reply #63 on: April 15, 2025, 07:24:02 PM »
Thanks again
    Don't do anything until you have at least most of the finish on it. Almost all the finish will be behind the CG, so will move it back.
« Reply #64 on: April 15, 2025, 07:52:52 PM »
Nothing wrong with that.  It is better than having ball links colliding.  With that arrangement you pick the hole that will give you the desires flap movement.  Mine was set to 30 degrees each way.  Then you use the elevator horn to give you whatever you want.  It should be more than the flaps.  Mine was 40.  That is a lot more than you need but it is the ratio that matters.  I really wish you would hold off on the cutting the nose until you get the majority of the finish on.  If you do need to move it, it is best to know exactly how much.
Offline Rusty
« Reply #65 on: April 15, 2025, 07:53:38 PM »
Guys, I pulled the trigger and did it.  I moved the engine back to where the front holes in the engine bolt to the rear holes on the fuselage.  It went very quickly with my Craftsman scroll saw.  I cut the fuselage front off the same clearance behind the thrust washer as was before.   I put everything back on, but the spinner.  Can you believe it balances PERFECTLY about 3/16 in front of the spar, where the plans call for.   Man, I never imagined this would be so easy,.  The plane is now 35 oz and change.
As Gomer said, thank you, thank you, thank you.   I'm back in the ball game.
Rusty
« Reply #66 on: April 15, 2025, 07:56:34 PM »
Rusty
With no finish it should be about on the LE.  You are going to be terribly tail heavy.
Offline Rusty
« Reply #67 on: April 15, 2025, 08:01:23 PM »
Dan, the Fancherized Twister has spruce spars.
Offline Rusty
« Reply #68 on: April 15, 2025, 08:04:58 PM »
Okay.  Being that I did not drill any new holes, I can move it forward.  There is plenty of room to do that.  I will move on the covering it and putting some dope on it.   I will drill the final motor mount holes when I have it covered and painted.
Offline Rusty
« Reply #69 on: April 15, 2025, 08:06:20 PM »
In fact, I could use the original holes if needed.
« Reply #70 on: April 15, 2025, 08:14:22 PM »
   Just finish it, and see where it comes out, add weight if necessary.
Offline Rusty
« Reply #71 on: April 15, 2025, 08:17:17 PM »
Okay.  Thanks Brett.
Please see what I did.
PS: Ken what do you see wrong with the engine?
« Reply #72 on: April 15, 2025, 08:59:32 PM »
By jove I think he's got it.
« Reply #73 on: April 16, 2025, 07:27:20 AM »
     Well it's not a big deal but look at the plan again. You can reshape the nose a bit now also. What size spinner was that yellow one you had on there?  I usually stick with a 2" or less spinner and a Tru-Turn or Great Planes aluminum spinner will have a flat backing plate that will fit easier. SIG plastic spinners had a flat back plate also if you have any of those laying around. The DuBro and Goldberg brands have that offset that has to be allowed for. A 2" spinner will let you use a starter if you want/need to, blend in nicely at the nose, and not be too heavy. An aluminum hub nut like the Higgley unit is a good substitute.
    Have fun!
Online Trostle
« Reply #74 on: April 16, 2025, 08:11:59 AM »
Cutting holes in the fuselage will not save you much weight.  I just cut a 1" disk from the heaviest 1/2" sheet balsa I have.  (It has to be the hardest and heaviest piece of balsa that I have ever had, at least 10# wood, probably a lot more - it has been in my stash for more than 50 years.)
The weight of this 1" disk is 0.9 grams.  If you cut 7  1" diameter holes from this heavy piece of wood, you would save all of about 1/4 ounce.
Offline Rusty
« Reply #75 on: April 16, 2025, 08:43:39 AM »
Hello.   Last night I did some studying and that is what I found.  I agree 100%.  No holes!  However, I discovered another way to lose weight and not hurt strength much.   Quoting Tony Montana, I said, "Say hello to my little friend" and pulled out my mouse sander and 80 grit pad.   I sanded a taper on the fuselage on the top and bottom and tapered the front top and bottom at the nose to where a 2 1/4" spinner could be used.   (I used table sander to do that.)
Okay, now for the moment of truth.  The bare airframe without horns, pushrod, engine, landing gear, motor, tank, weighs 21 ounces and some change.    Is that within useful range?
« Reply #76 on: April 16, 2025, 09:35:23 AM »
   You are worrying about this FAR TOO MUCH!. Just build it and it comes out how it comes out. You haven't done anything to make it excessively heavy, it will be fine well up into the low 50's, and you are headed to the low-mid 40's. You have a modern 40, you have such overkill power compared to the original Fox 35, you an handle A LOT of weight.
     I might even suggest you throw away the scales and don't check it any more. Weight does matter some, but I have yet to see an airplane that was unflyable strictly due to weight as long as the engine ran properly and it was in-trim. I have seen *lots* of airplane that were super-light, but nonetheless flew like crap because of inappropriate trim or engine setup - or that fell apart in a few dozen flights.
     The obsession with weight, particularly with beginners/low-time pilots, is a toxic notion in stunt, lots of people give up pre-emptively or make themselves miserable worrying about weight, when the things that matter - accuracy of construction/workmanship, control systems, trim, and engine setup are afterthoughts.
    Build the airplane the best you can, finish it the best you can, it balances where it balances, add weight to the nose or tail to balance it properly (start at about 20% of the average chord) regardless of how much it is, then trim it.  You may run into limitations due to weight eventually, but not now, and predict (after doing this to varying degrees of attention for 50+ years) that you will outgrow the airplane or build another one long before you get to the point that 3-4 ounces matter to you.
   Weight does matter, to an extent, but after reading back through this thread, I think you are applying far to much relevance to weight in what appears to be a perfectly good job that is about the norm for these sorts of airplanes.  Carry on the good work, and I wasn't kidding - put the scales away and just build it.
« Reply #77 on: April 16, 2025, 09:44:00 AM »
   I don't know about Ken, but it appears you have drilled a hole (PA spraybar-sized) in your engine. As above, carry on anyway, there are a lot of engines that fit the same mounts.
« Reply #78 on: April 16, 2025, 10:09:05 AM »
Okay.  Thanks Brett.
Rusty if you were referring to the mounting holes-don't worry the least about it.  Thats what washer are for.   Many old engines I have acquired you could drive a truck through.   Wish whoever had them didn't but it really made no difference.  Clamping bolt pressure will hold the engine down.  In regards to the idea of making lightening holes in the profile fuselage-don't.   You need that thing as stiff as possible and have enough mass to absorb some vibration.   The jest of what many here are trying to say is-don't overthink it- you got this!  Finish it, fly it and if necessary make some changes to the next one if you think it needs it.
Offline Rusty
« Reply #79 on: April 16, 2025, 10:31:14 AM »
Yes, I was referring to lightening holes.  I'm not doing that.   The fuselage needed work because it had square edges.  I rounded the edges of the front doublers and put a taper on the top and bottom of the fuselage behind the doublers.  I do this on all my profile planes.    Now I will start the part I hate, finishing it.   I'm shooting for a -5 pointer.  If enter it in a contest they will have to deduct 5 points from my score.  That's good for me; it's better than them saying it's not a plane, it's a modern art masterpiece and I cannot enter it.
Thanks very much.
« Reply #80 on: April 16, 2025, 11:36:50 AM »
Thanks very much.
Most of the contests I attend do not award appearance points for profile.  We are even dropping them from PA at our local contests this year.
« Reply #81 on: April 16, 2025, 11:53:55 AM »
Thanks very much.
Without a builder of the model rule Rusty you can just say you bought it at a flea market......
Offline Rusty
« Reply #82 on: April 16, 2025, 02:11:08 PM »
Or, I could say it came from an art sale in the section where they sell popsicle stick  and beer can airplanes.
« Reply #83 on: April 16, 2025, 05:50:18 PM »
  Now that is art I can understand!
Offline RC Storick
« Reply #84 on: April 16, 2025, 05:59:22 PM »
I agree with Brett. Imagine that!
38 OZ no covering, you could add a concourse finish at 12oz and still be in the ballpark. If you finish with MonoKote and painting the fuse, I would be surprised if it hits 45oz
« Reply #85 on: April 16, 2025, 07:18:01 PM »
  We probably agree on almost everything.
    This airplane is plenty in the ballpark, and having an heavy airplane that is finished and flies is still better than one that is light but never gets done. As Bob says, you are headed to low-mid 40's, that's plenty good enough, particularly with massive power boost.
« Last Edit: April 16, 2025, 09:58:05 PM by Brett Buck »
Offline Rusty
« Reply #86 on: April 17, 2025, 10:40:26 AM »
I am in the process of finishing it.  Yesterday I sanded it with 2 grades of paper, filled in knicks, and sanded again.  While doing this in my mind I heard: "Danial Son, <oriental sounds - grunting> SAND AIRPLANE. Either build airplane to fly or build airplane to hang up, in between bring garbage bag."
It is coming along.  I have one coat of dope on it.   Maybe tomorrow I will put polyspan on.
Thanks for everything.   PS: Yes, I watched Sparky's polyspan video.
Rusty
Offline Rusty
« Reply #87 on: April 18, 2025, 05:26:02 PM »
Hey Guys, I have the twister covered and 3 coats of dope on the whole thing.   How many coats does it need to put color on?   It now weighs 24 oz.
« Last Edit: April 18, 2025, 05:58:25 PM by Rusty »
Online Dan Berry
« Reply #88 on: April 18, 2025, 08:06:16 PM »
Eight
« Reply #89 on: April 18, 2025, 08:45:49 PM »
Eight
Thinned I hope!  I use a quick seal with nontauting dope on polyspan and it is ready for sanding at 3, 6 to color.
A note to Rusty.  The twister wing is easily warped.  Check it after each coat.
Online Dan Berry
« Reply #90 on: April 19, 2025, 07:21:25 AM »
Paint it two rib bays at a time. Top and bottom.
Offline Rusty
« Reply #91 on: April 19, 2025, 07:12:06 PM »
Thank for that outstanding advice.  Unfortunately, I have already done 3 coats, alternating top to bottom.  Fortunately, I overbuilt the wing by using spruce spares, rock hard leading edge stock and trailing edge stock.  It appears to be okay.
Today, I had my swap meet at Sundancers.  It was very good.  I made 195.00 in sellers fees.  I bought a bunch of light weight wheels, so I will swap out the heavy wheels.   Also, I got a brand new LA 40 for 20.00.   (R/C version)
Happy Easter everybody.
« Reply #92 on: April 19, 2025, 09:46:46 PM »
The twister wing is prone to *twisting* more so than warping.  Find a way to keep it square while it is drying.  Mine was monokoted and I had to straighten it up allot, but as easily as they warp, they unwarp.  Looking good!
Offline Rusty
Re: Twister - FINISHED - DONE - IT'S OVER!!!
« Reply #93 on: June 05, 2025, 01:48:23 PM »
Hello Guys, I finally got the Twister finished.
I'm not all that happy with how it turned out, but what happened, won't  happen again.  What I'm not happy has to do with our discussion of it balancing.   I reported I thought it was nose heavy, which was before it was painted.  In a knee jerk reaction due to some saying I needed to move the engine back, I did cut the fuselage to where the engine would move back and cut the front off for that location.  Then someone said, it was a big mistake because when I paint it the reverse will be true and it will be tail heavy.   WOW!!!!  Was that person EVER on the money.  That is exactly what happened.  I did not move the engine from it's original location, but the grave error I made was cutting off the front of the fuselage to where I could not move the engine forward to balance it.   That means I had to add about 3 to 4 ounces to balance the plane.   Instead  of the light weight tongue muffler, I put the stock muffler on and had to put a 1.25 oz heavy prop nut under the spinner.    Because of all this stupidity on my part the plane weighs 47 ounces.   It could have been around 44 or less if I didn't cut the nose off.   (Quoting Gomer, dumb, dumb, dumb)
I am happy with the finish.   I don't have much money in it.  I used Michael's acrylic paint with was less than 5 bucks.  I put 2 part urethane over that.     The controls work perfect and very smooth.   I did not have to put any tip weight because I didn't cut lead out holes in those ribs.   I did have to adjust the lead out slider to get the nose to lean out when suspending the plane by the lead outs.   I have an adjustable rudder and put a slight amount of right rudder.   I put a 1 degree shim under the engine lugs.
Anyway, I appreciate all the help (good and not so good) I was given.
Rusty
Re: Twister - FINISHED, DONE, READY TO FLY!!!
« Reply #94 on: June 05, 2025, 02:13:53 PM »
  Rusty, I think you will be pleased at how well it will fly at that weight. If everything is straight and aligned well, just put a few short tank flights on it to feel it out. Have someone eyeball to see if it flies level with the lines and once you have tried inverted flight and feel comfortable, have them eyeball that also. Ease into how it feels up high in the 45 degree range, try a few loops and such as you move along. Start out with some 60 foot, .015"  lines and a  lap time about 5 to 5.4 seconds or so and adjust from there for your comfort zone. The model looks great!! Have fun with it!! The next one can be a 40 ounce wonder!!  When you start adding in all the wood for the Fancher mods, it does add up in the final weight unless you have all 4 pound Ecuadorian gold in it!! I think you did OK.
« Reply #95 on: June 05, 2025, 04:42:46 PM »
Love the traditional colors. Doesn't the push rod from the bellcrank usually go on top of the flap horn?
« Reply #96 on: June 05, 2025, 05:48:10 PM »
Twister looks great.  remember this was not designed to be a full fledg nationals aerobatic plane.  Just go fly and have fun. D>K
Offline Rusty
« Reply #97 on: June 05, 2025, 06:04:32 PM »
See screen shot of fancherized twister flap horn. It is different than stock plans.  I had to move the clevis closer to the elevator because I was getting more flap movement than elevator.
Offline Colin McRae
  • Are we having fun yet??
« Reply #98 on: June 06, 2025, 02:20:50 PM »
Rusty
Looks like the fuel tank could go a bit further north which will help a little. Plus, there is nothing wrong with shorter fuel lines. And maybe use an APC sport prop which is way heavier than wood. Then decrease the spinner nut weight as appropriate.
And the model looks great nonetheless!
« Last Edit: June 06, 2025, 02:39:29 PM by Colin McRae »
Offline Rusty
« Reply #99 on: June 08, 2025, 12:50:40 PM »
Thanks.  Actually, I have and am stil considering putting heavier wheels and an APC prop.  I will have to cut the spinner opening if I do.  However, I don't have an appropriate size APC. The prop on it now is a new TF wood 11 x 5 (old school) prop.   I would like to see if the heavy prop nut gives a smoother engine run, due to the flywheel affect.
BUT, I still have no solution to getting somebody to fly with.  My flying buddy (Jim) is still too sick to participate.   I have a back log of planes to test.   I have my ringmaster that I did fly twice and made some changes to that needs flying.  I have my Vector that I have never flown and now the Twister is waiting.  I'm not complaining, this better than having no planes.  What size APC do I use for a FP40?
