  • July 08, 2025, 06:17:19 PM
Author Topic: push rods  (Read 1443 times)
Offline Bill Morell
push rods
« on: November 22, 2017, 08:51:46 PM »
Any one have a source for carbon fiber push rods?
Bill Morell
Vietnam 72-73
Offline James Holford
Re: push rods
« Reply #1 on: November 22, 2017, 08:52:33 PM »
RSM
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Mike Griffin
Re: push rods
« Reply #2 on: November 22, 2017, 08:55:35 PM »
Bill,  Eric sells them.  They are 5mm OD and 3mm ID.  He also has the RH and LH threaded ends for them as well.
Re: push rods
« Reply #3 on: November 22, 2017, 09:53:20 PM »
The carbon rods and stainless steel rod ends that Eric sells come in right and left hand threads so the elevator push rod can be adjustable by just twisting it!  Slick!  Requires no extra link!  Also the rod ends slide over the rod for gluing and automatically deter splitting of the carbon rod.  No wrapping or extra gluing necessary!
Offline peabody
Re: push rods
« Reply #4 on: November 22, 2017, 10:54:30 PM »
Tom Morris also.....and Brodak....
Online Brian Hampton
Re: push rods
« Reply #5 on: November 23, 2017, 02:58:23 PM »
I use 5mm, aluminium cored arrow shafts.
Re: push rods
« Reply #6 on: November 23, 2017, 03:02:39 PM »
Your local kite shop has them also. Probably in much larger lengths for those really big models.
No local kite shop. Google "Kite supplies" and you can buy the lengths on line.
Probably save a bunch of money buying in quantity.
Offline Target
  • C/L Addict
Re: push rods
« Reply #7 on: November 23, 2017, 03:34:40 PM »
For bulk purchasing, try
www.goodwindskites.com
Kind Regards,
Target
Chris
AMA 5956
Re: push rods
« Reply #8 on: November 23, 2017, 03:48:04 PM »
Kind Regards,
Target
The bulk purchase could work, but Bill will still need the 4-40 threaded ends. I just thought about that.  Tom Morris sells these steel ends and so does a few other vendors.
There are some miner differences with these ends.
The only ends I have experience with are those from Tom Morris.
