  • July 19, 2025, 04:20:35 PM
Author Topic: PT-19 Rebuild Finished  (Read 1862 times)
Offline Garf
    • Hangar Flying
« on: August 04, 2010, 03:23:05 PM »
The rebuild of the PT-19 is done. In the process, I removed the dihedral and stretched the fuselage. Test flight this Sunday.
« Last Edit: September 06, 2010, 11:30:40 AM by Garf »
Re: PT-19 Rebuild Finished
« Reply #1 on: August 04, 2010, 07:01:57 PM »
Looking good Phil.
Keep us posted on how she flys.
« Reply #2 on: August 05, 2010, 05:58:47 PM »
The plane looks good.  I thought that by now you would be waiting for December.  The other day I was mowing they said heat index was 120.   H^^
Offline Garf
    • Hangar Flying
« Reply #3 on: August 05, 2010, 06:10:08 PM »
I'm only managing between 2 and 4 flights on a Sunday before melting down.
« Reply #4 on: August 05, 2010, 08:43:46 PM »
Hey we have a cold front coming thru tomorrow that will cool us off here in the mid south. We will get down to the upper 90's!
Offline Garf
    • Hangar Flying
« Reply #5 on: August 08, 2010, 09:21:21 AM »
Today's test flight canceled on account of rain. This area is under a flood watch.
Offline Leester
« Reply #6 on: August 08, 2010, 09:47:19 AM »
Hey Doc, maybe in that kind of heat you should leave the grass till another day  n1 n1
Leester
ama 830538
Offline Garf
    • Hangar Flying
« Reply #7 on: August 14, 2010, 02:01:34 PM »
Took the PT-19 out today for a test flight. The McCoy 35 didn't hack it. Brought it home and swapped the McCoy for a ST 46. Lets see how that works.
Offline Garf
    • Hangar Flying
« Reply #8 on: August 15, 2010, 03:53:17 PM »
ST 46 still didn't hack it. Next is a Fox MK-6 combat special.
« Reply #9 on: August 16, 2010, 05:42:42 AM »
What prop are you trying to use on the .46?  With the warmer temps, might have to go to more diameter or more nitro in the fuel.   H^^
Offline Garf
    • Hangar Flying
« Reply #10 on: August 16, 2010, 11:17:14 AM »
Taipan 11-5. I still think it sits too level on the ground. Nothing else I fly has trouble getting off the takeoff ramp. This will do the reverse wingover with no problem.
« Reply #11 on: August 16, 2010, 03:04:36 PM »
Shorten the tail gear.  Or put on bigger wheels.   H^^
Offline Garf
    • Hangar Flying
« Reply #12 on: August 17, 2010, 01:31:10 PM »
I think I'll do both.
Offline Garf
    • Hangar Flying
« Reply #13 on: September 06, 2010, 11:30:05 AM »
My first attempt to use a Fox MK-6 combat special failed. The engine wouldn't start. It seems that I had changed the NVA and didn't establish the setting before trying to fly it. I had it way too rich, and this thing's critical. I reset it and ran it in my back yard.
Offline Garf
    • Hangar Flying
« Reply #14 on: October 11, 2010, 07:36:17 PM »
The PT-19 gear had worked loose, so I redrilled and bushed the hole. Last flight, my partner told me that my tip weight had come loose. When I got it home, I opened the compartment and everything was where it was supposed to be, so I opened the covering and checked. I found 2 wood blocks with a 1/8" hole in the middle. They were the gear reinforcing blocks. There was no trace of glue on them. Now for plan "B".
