  • July 19, 2025, 06:56:58 PM
Author Topic: PT-19 by Hemstrought  (Read 2870 times)
Offline larry richards
« on: October 23, 2011, 10:10:02 PM »
I have a copy of Dave Hemstrought's PT-19 plans.  I would like to build the model and was wondering if anyone know's of a laser cut rib package for this model.  I believe the wing span is 55".  Really a nice Army aircraft.  Any help would be most appreciated.  Larry
Re: PT-19 by Hemstrought
« Reply #1 on: October 23, 2011, 11:00:33 PM »
 Larry,
 Check with Walter Umland, he offered a kit of it and may be able to supply a rib set.
« Reply #2 on: October 23, 2011, 11:22:47 PM »
Thanks for the info!  Called Walter and he can do the ribs for me.   #^
« Reply #3 on: December 02, 2011, 02:25:45 PM »
Hi Larry,
You will love the model.  I still miss seeing Dave fly his at local meets.  He's doing a lot of R/C with his son now, he told me.  His used K&B .40s set up by Stan Powell like the ones Stan built for Les Mc.  The last version I remember had been changed to an Aero Tiger .36.
« Reply #4 on: December 02, 2011, 03:59:25 PM »
Hi Larry,
« Reply #5 on: December 02, 2011, 04:03:34 PM »
Model is coming along just fine.  Fuselage is framed and the engine mounts are in.  I'll be using a LA-46.  At this time I'm carving out the cowling.  I don't have a tank yet, and am trying to figure out the size (4 or more Oz.)
Offline kenneth cook
« Reply #6 on: December 02, 2011, 05:05:57 PM »
              My son Shawn has been flying his for 5 years now. This plane flies very well. We have a Brodak .40 for power. I have a 4 oz. tank in it and it will make the pattern in the hotter months. It barely makes it when the temps get cool. This plane presents well in the air. It certainly was a great plane to build and it has several awards behind it. I'd like to thank Paul Taylor for taking the picture a few years ago. Ken
Offline Brian Massey
    • California Car Clubs
« Reply #7 on: December 02, 2011, 06:10:55 PM »
I fly a 52 oz plane powered by an LA 46 and it takes close to 5 oz of fuel for the pattern.
Brian
AMA 55421
Madera, CA
Offline Phil Spillman
« Reply #8 on: December 02, 2011, 07:48:07 PM »
Hi Larry, Nice to hear that you'll be using the LA 46 my overall most favorite engine! I fly mine on 11 X % Pro Zinger or regular Zingers of the same dimension. These engines on a rare day will do a peattern on 4 oz. of fuel most really to be comfortable use at least a 4.5 oz tank. I prefer muffler pressure others don not! I know you will be most happy!
Phil Spillman
Phil Spillman
« Reply #9 on: December 04, 2011, 12:26:41 PM »
HI Larry,
I would look at going down a little bit in size from the "stock" venturi.  Something like the OS .20-.25FP or .25LA.  Jim Lee makes slightly smaller venturis which will give the needed fuel mileage (as low as 3 1/2oz.) and not kill the power enough to notice in that size model.  Pat Johnston has led the charge in using the .20-.25 size venturi in models this size.
Offline Larry Fernandez
« Reply #10 on: December 12, 2011, 02:35:35 PM »
Here is one built from American modeler plans.
In keeping with the spirit of the classic event, it has a Johnson .32 Stunt, old Veco wheels and an old Top Flight prop.
The coolest thing about this design, is that with an open cockpit you can be pretty creative with the detailing.
This model took on a severe wing warp and I have given up hope for it to be a "World Beater" so I'm building a new one, only better.
Post pictures as you build.
Larry, Buttafucco Stunt Team
Offline David M Johnson
« Reply #11 on: December 12, 2011, 03:29:44 PM »
Interesting muffler for the Johnson .32. How well does it diffuse the noise?
David Johnson
We're havin some fun now!!
« Reply #12 on: December 12, 2011, 03:36:49 PM »
David Johnson
Not well.
It can be configured to take out a little more of the bark, but the old Johnson dosn't take kindly to mufflers.
« Reply #13 on: December 12, 2011, 04:01:51 PM »
I had to ask as that was something that was running through my head last night as I was trying to get to sleep.  In the time of "You can't fly here without a muffler"  That is a solution.
David
Offline John Kelly
« Reply #14 on: December 12, 2011, 06:14:53 PM »
   Hey Larry... Enjoy the build and please post some pics of it. It's been one of my favorites for quite some time.
AMA 11416
Offline billbyles
« Reply #15 on: December 12, 2011, 08:58:07 PM »
A PT-19 would be just the airplane to make Gordy look good!
Bill Byles
AMA 20913
So. Cal.
« Reply #16 on: December 13, 2011, 12:54:58 AM »
Gordy looks good with any airplane. He's always been one of my stunt heros.
